POV-Ray : Newsgroups : povray.unix : make failure Server Time
27 Jul 2024 14:23:19 EDT (-0400)
  make failure (Message 1 to 5 of 5)
Subject: make failure
Date: 7 Mar 2011 04:26:40
Message: <4d74a4d0@news.povray.org>
I use the Unix version on MacOS.  I recently got a new Intel Mac and it
occurred to me that Povray might run faster if I recompile it, rather
than running a PPC version under emulation.  But make failed:
$ make
make  all-recursive
Making all in libraries
Making all in png
make[3]: *** No rule to make target `all'.  Stop.
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
Clues?
Anton Sherwood *\\* http://bendwavy.org/
Subject: Re: make failure
Date: 7 Mar 2011 06:06:37
Message: <4d74bc3d$1@news.povray.org>
> $ make
> make  all-recursive
> Making all in png
> Clues?
Which version of povray are you trying to compile ? (3.7RC3 or 3.6.2, or
even older ?)
My classical usage of the recent tar-balls (3.7):
 1. extract the tar
 2. go into the first level directory
 3. ./configure COMPILED_BY="Anton Sherwood <...>"
(I also add --disable-io-restrictions , but that's personal)
 4. make -j 12
 5. sudo make install
(assuming the file ./unix/povray has been created by step 4)
Instead of 5, you can also try "./unix/povray --benchmark" if you have
installed at least once (so that the include files are at the right place)
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 7 Mar 2011 16:44:38
Message: <4d7551c6@news.povray.org>
>> ...  But make failed:
r
> even older ?)
3.6.1 is what I downloaded.
>   1. extract the tar
>   3. ./configure COMPILED_BY="Anton Sherwood<...>"
... did that ...
>   4. make -j 12
I used plain "make", but -j 12 did not change the result.
Anton Sherwood *\\* www.bendwavy.org
Date: 8 Mar 2011 02:54:52
Message: <4d75e0cc$1@news.povray.org>
>> even older ?)
>>   1. extract the tar
> ... did that ...
>>   4. make -j 12
It looks like png is provided in libraries/png for 3.6, and is the 1.2
version of the library.
You might try to compile it by itself first:
 * in libraries/png, execute ./configure
 * then make
Either it works, or you have now a smaller issue to solve for your
system and libpng.
around.
it's free.
Date: 13 Mar 2011 14:31:03
Message: <4d7d0d67@news.povray.org>
>   * then make
Thanks.  I did that (success); and then the same in libraries/jpeg
(success); and then the same in libraries/tiff (hideous failure).
Anton Sherwood *\\* www.bendwavy.org *\\* www.zazzle.com/tamfang
