POV-Ray : Newsgroups : povray.unix : Memory crash under Debian Sidux Server Time
3 Jun 2024 12:11:37 EDT (-0400)
  Memory crash under Debian Sidux (Message 1 to 8 of 8)
Subject: Memory crash under Debian Sidux
Date: 30 Apr 2010 02:08:32
Message: <4bda73e0$1@news.povray.org>
High!
Recently, I tried to render a mesh2 generated from an image file 1200 x
1200 pixels large. After reading in all color values (using
eval_pigment()), POV-Ray crashed... as the same thing occurred when I
tried it on my second computer running Windows, I drew the conclusion
that 1.5 gigabytes of RAM is not enough for such a huge mesh. Is there a
way to configure swap memory usage with POV-Ray 3.6 for Linux? Or could
it be that my swap partition (currently 2 gigabytes) is too small?
Smaller meshes like the 800 x 400 ones from my Solar System project
parse and render without problems... seems that I need at least 7
gigabytes... can this be true? I wonder that mesh2 objects are that much
RAM-consuming!
See you in Khyberspace!
Yadgar
Now playing: The Politics Of Dancing (Re-Flex)
Yadgar
Subject: Re: Memory crash under Debian Sidux
Date: 30 Apr 2010 03:43:31
Message: <4bda8a23$1@news.povray.org>
> High!
   IIRC, you can use more than one swap partition... but of course, the only
real solution would be to add more RAM.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 30 Apr 2010 04:31:30
Message: <4bda9562$1@news.povray.org>
> High!
You do /not/ want to use swap memory for POV-Ray. Never ever.
> RAM-consuming!
Q: How's POV-Ray's memory consumption with the 800 x 400 mesh?
I can't imagine the crashes being due to memory overflow. From a rough
guesstimate, a contiguous mesh should not take more than ~200 bytes per
triangle - probably more like ~150 bytes. That should be something
around 250 Mbytes for a 1200 x 1200 mesh.
That is, unless you assign an individual texture to each and every vertex.
There is some possibility that the memory heap gets too fragmented
during mesh parsing, but while I have no idea how likely this is, I
don't expect it to happen in your case.
Maybe you could send me the offending scene and image file, so I could
check with a debugger what's happening.
Date: 30 Apr 2010 06:35:44
Message: <4bdab280$1@news.povray.org>
   I do that all the time ;)
Date: 4 May 2010 08:02:37
Message: <4BE00BE6.3090405@gmx.de>
Yes, here it is!
Download 'ghurghusht360_n05_040.png' (3431 KB) Download 'us-ascii' (24 KB)
Preview of image 'ghurghusht360_n05_040.png'
Date: 4 May 2010 10:56:21
Message: <4be03595$1@news.povray.org>
> High!
> RAM-consuming!
Giving the scene a test on Windows, as far as I could see memory
consumption of POV-Ray reached roughly 1.5 GB during parsing (which
should still be ok with 1.5 GB RAM + 2.0 GB swap, at least it shouldn't
cause a crash), then parsing stopped due to an error in the line reading
	  #if(b<(l-2))
because l is undefined.
Date: 7 May 2010 13:36:58
Message: <4be44fba$1@news.povray.org>
High!
> cause a crash),
But could it be that with my installation of POV-Ray, usage of swap is
somehow disabled?
Yadgar
Date: 7 May 2010 14:03:06
Message: <4be455da$1@news.povray.org>
> somehow disabled?
Unless you disabled swap altogether in your OS, I can't imagine how that
should happen.
(...thinks...)
Then again, maybe I'm wrong with the assumption that available memory =
physical memory + swap memory; if linux keeps space reserved on the swap
partition for every page that is currently kept in physical memory, then
2 GB might indeed be just a bit too small.
