![](/i/fill.gif) |
FYI:
Since having installed openSUSE 11.2 a few months ago, I had encountered
problems compiling POV-Ray with the Intel icpc compiler, causing error
messages like:
/usr/include/c++/4.4/cmath(500): error: identifier
"__builtin_fpclassicy" is undefined
Apparently this was a problem with incompatibilities between the Intel
icpc 11.1 compiler (11.1.059 here) and the GNU g++ 4.4 (and allegedly
also g++ 4.3) header files.
I now succeeded as follows:
- Installed old GNU gcc/g++ 4.1 (4.2 should do as well) alongside the
newer version
- Configured POV-Ray with CXXFLAGS="-gcc-name=gcc-4.1 -gxx-name=g++-4.1"
(or whatever older version of the GNU compiler you use)
(Possibly CXXFLAGS="-gxx-name=g++-4.1" might suffice, but I didn't test.)
I thoughg I'd share this, just in case anyone else runs into the same
problem. It might also be helpful to include this information in the
INSTALL "manual".
According to forum postings on the Intel Software Network, Intel
apparently promised to provide a fix for icpc to cooperate with g++ 4.3
and newer in August 2009, but as of version 11.1.064 (February 2010) no
such fix has been released yet.
![](/i/fill.gif) |
