POV-Ray : Newsgroups : povray.unix : Turn off text messages Server Time
27 Jul 2024 18:36:16 EDT (-0400)
  Turn off text messages (Message 1 to 9 of 9)
Subject: Turn off text messages
Date: 31 Jan 2006 11:22:30
Message: <43df8ec6$1@news.povray.org>
Hello
If I understood right giving povray the -GA argument should turn off
all console messages. I tried
povray +Iscene.pov -GA
but all messages appear on the console. povray even tells that
everything is turned off (which is very polite but a bit weird).
<povray-output>
Redirecting Options
   All Streams to console..........Off
   Debug Stream to console.........Off
   Fatal Stream to console.........Off
   Render Stream to console........Off
   Statistics Stream to console....Off
   Warning Stream to console.......Off
</povray-output>
All messages go through stderr with -GA *enabled* or not.
Why do messages streams not take their way through stdout?
And why do the stream to console flags do not affect the
output at all?
Does anyone has clue about this?
Sebastian
Subject: Re: Turn off text messages
Date: 31 Jan 2006 11:32:44
Message: <43df912c$1@news.povray.org>
	This is a known bug in the 3.6 series that has been already
discussed in this group.  If you want a fix, you can try the Unix
frontend patch (latest version is 0.2.1) described in some recent
messages here.
	Because stdout can be used to output the rendered image,
using e.g. 'povray +o-'.  Check the user manual.
	- NC
Date: 31 Jan 2006 14:33:48
Message: <43dfbb9c$1@news.povray.org>
> messages here.
Ah yes, I'll give it a try.
Thank you very much.
Sebastian
Date: 2 Feb 2006 17:05:25
Message: <pan.2006.02.02.20.30.47.639518@almost.bestweb.net>
On Tue, 31 Jan 2006 17:27:06 +0100, Sebastian H. wrote:
> Hello
> <povray-output>
> Redirecting Options
> </povray-output>
> output at all?
> Sebastian
 povray -iscene.pov 2>/dev/null
The "2>" forces stderr to be redirected instead of stdout.
Date: 23 Mar 2006 09:35:00
Message: <web.4422b134b0114831c71d6360@news.povray.org>
"...giving povray the -GA argument should turn off all console messages. I
tried but all messages appear on the console. Povray even tells everything
is turned off. All messages go through stderr, -GA *enabled* or not."
Try, taking care for the Ampersand:
    xterm -T DEBUGWINDOW -e tail -f ./DEBUG.txt &
    povray +GD./DEBUG.txt ./INPUT.pov
Lines in INPUT.pov like e.g.:
    #debug concat( "nHALLO SEBASTIAN: ", str(clock,0,0), "n" )
will produce their output in DEBUGWINDOW and, nearly, nothing else. Does
work for pov3.6 on SuSE9.0
Best regards: WellenZillich
Date: 7 Apr 2006 06:20:01
Message: <web.44363bf4b011483292a70ad0@news.povray.org>
SORRY: Replace "n" with "\n":
   povray +GD ./DEBUG.txt ./INPUT.pov
   #debug concat( "\nHUHU: Linebreak after two:", "one,"two","\n","three")
   will produce output in DEBUGWINDOW.
Best Regards: WellenZillich
Date: 8 Apr 2006 04:17:56
Message: <443771b4$1@news.povray.org>
Hmm, interesting idea though I would prefer a fifo instead of invoking
tail. However this does not cure the problem with the current inability
of linux-POV-Ray to turn off stderr output. This requires a patch as
mentioned somewhere else.
Sebastian
Date: 12 Apr 2006 21:09:42
Message: <pan.2006.04.13.01.09.24.403693@almost.bestweb.net>
<<snippage>>
<<snippage>>
 povray -iyour_pov_file 2>/dev/null
	"2>" redirects stderr.  Redirecting it to /dev/null
effectively turns it off.
Date: 4 May 2006 06:35:01
Message: <web.4459d7f5b0114831c71d6360@news.povray.org>
bob <bob### [at] almostbestwebnet> wrote on SebastianH. & WellenZillich:
"2>" redirects stderr to /dev/null & turns it off.
No question bob is right and console messages could be get rid off this way.
BUT: Working around the problem this way would cause the next questions
concerning textconsole output switches GD, GF, GR, GS, GW. My "Catching the
debug stream" should have been read as the pragmatic answer to the first4me
important one of these not yet asked questions.
Apropos FIFO: Yet anybody really has tried get it2work? Seems not2be doable
as easy as first thought by me, regrettable.
Regards from the ascending branch:
Wellenzillich
