POV-Ray : Newsgroups : povray.unix : Possible permission problem. Server Time
27 Jul 2024 20:28:23 EDT (-0400)
  Possible permission problem. (Message 1 to 7 of 7)
Subject: Possible permission problem.
Date: 7 Nov 2005 22:14:57
Message: <43701831@news.povray.org>
I've got a problem where when I run as root:
povray  zini.ini,
where the zini.ini includes among other things a line of:
Output_File_Name=/home/greg/images/
It runs fine.
But when I run it as non-root, I get
"Scene File Parser Initialization Error: Cannot open input file."
And I have a foggy memory if it once complaining about not being able to
open output file. (just not this time as I went to type).
Of course, i've done a lot of things as root on this kanotix linux box. How
do I fix this prob?
Subject: Re: Possible permission problem.
Date: 8 Nov 2005 02:18:00
Message: <43705128@news.povray.org>
> do I fix this prob?
At first we should know how the file permissions are set. What does a
ls -la
say?
Maybe the file belongs to root and no other users can read it...
Just my two eurocents,
Bonsai
    ___ __ __  _ ___ ___  _
   | _ )  \  \( )  _) _ )( )
   | _ \() |\ \ |\ \/ _ \| |
   |___/__/_)\__)___)/ \_)_)
        www.b0n541.net
Date: 8 Nov 2005 12:01:45
Message: <pan.2005.11.08.17.01.34.57808@nospam.com>
What have you got your I/O Restriction settings set to?
Jim
Date: 8 Nov 2005 22:10:16
Message: <43716898@news.povray.org>
-rw-rw-r--   1 greg greg     557 Nov  7 22:46 zini.ini
> ls -la
> say?
> Bonsai
Date: 9 Nov 2005 01:17:34
Message: <4371947e@news.povray.org>
> povray  zini.ini,
> It runs fine.
> do I fix this prob?
ls -ld /home/greg   ?
Date: 9 Nov 2005 09:03:39
Message: <437201bb$1@news.povray.org>
This should be fine, when you're logged in as user greg. Maybe you try
to read other .ini files in your scene? Are you sure that you can read
the .ini files that come with POV-Ray? They are located in
/usr/share/povray*/ini on my linux box. Have you tried to render a
sample scene from POV-Ray as user greg?
Even more eurocents from my side... ;-)
So long,
Bonsai
        www.b0n541.net
Date: 9 Nov 2005 22:50:43
Message: <4372c393@news.povray.org>
stephen parkinson wrote:
> ls -ld /home/greg   ?
drwxr-xr-x  85 greg greg 21048 Nov  9 21:25 /home/greg
