POV-Ray : Newsgroups : povray.unix : KDE install apparently successful; where should I see pov links now? <eom> Server Time
16 Mar 2026 05:28:42 EDT (-0400)
  KDE install apparently successful; where should I see pov links now? <eom> (Message 1 to 2 of 2)
Subject: KDE install apparently successful; where should I see pov links now? <eom>
Date: 11 May 2005 22:53:35
Message: <4282c52f$1@news.povray.org>
Subject: Re: KDE install apparently successful; where should I see pov links now? <eom>
Date: 12 May 2005 10:46:13
Message: <42836c35$1@news.povray.org>
Did you click on the K button?  You should see a POV-Ray 3.6
entry in the main menu.  If you don't, then the installation did
not succeed for some reason (the most common cause being a distro
that uses a non-standard $HOME/.kde/share/applnk pathname).
	- NC
