Hi, I'm by no means a hardware expert, so please be
gentle...
I'm sure many of us have browsed
http://www.haveland.com/index.htm?povbench/index.php
and seen the (to me) astonishing 00:07:34 for a single
Pentium Xeon on a Dell Precision 450 running Lunar Linux.
By comparison my old Pentium III coppermine running
SuSE 8.2 and a gcc-optimized PovRay 3.50c took 02:12:59.
Anyway I thought "I gotta get one of those" and forked
out for a brand new box (bespoke built) with 2 P4 Xeons
and 4Gb of core memory, and put Lunar on it.
Generally I'm extremely pleased with it, but dissappointingly
my benchmark (pov 3.6.1 this time) comes nowhere close.
With a gcc optimized build I measured 00:35:30 and after
getting hold of the Intel Compiler and rebuilding with that
I got it down to 00:30:28.
here's some of my /proc/cpuinfo
billh@Tarragon ~ $ cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 15
model : 2
model name : Intel(R) Xeon(TM) CPU 3.06GHz
stepping : 9
cpu MHz : 3056.924
cache size : 512 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 2
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca
cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe cid
bogomips : 6029.31
... x4
I'm happy enough with my vast improvement, but when the
time comes to upgrade I'd like to know what I really should
have bought -- though I now suspect I couldn't have afforded
it :-)
Any comments?
Bill Hails
http://thyme.homelinux.net/
The result is either bogus (do the povbench maintainers really
corroborate the submissions?) or the result of rendering the
benchmark with non-standard parameters (eg. without antialiasing,
with a lower resolution or whatever) thus being invalid.
There's simply no way that processor can render the benchmark that
fast with genuine benchmark settings.
I don't believe there exists currently *any* processor which can
singlehandedly render the benchmark that fast. All the other <15min
results in that page are probably bogus as well. I'll believe it
when I see it myself live (with me running the benchmark and checking
the results).
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
> gentle...
Well - the problem about these benchmark results is that there is no way
to proove their validity - people could enter any time and no one would
notice.
You can find some accurate results in the tests Nicolas made recently:
http://pov4grasp.free.fr/articles/fastpov1/
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
I'm sorry to say I don't believe in any of these benchmark results
(at least those below the 20 minutes barreer on a single processor). Even
in those that give some sort of notes on how they prepared the binary and
ran the benchmark.
Your results agree pretty well with what I got myself for
the Intel Xeon @ 3.06 GHz:
http://pov4grasp.free.fr/articles/fastpov1/xeon_3.06.png
GCC 3.4.x gives at best 00:32:30, and ICC 8.1 about 00:28:10 in
my tests -- so you may have a look at which compiler flags I used if you
want to gain another two minutes :-)
- NC
> - NC
I can't seem to close that 2 minutes gap :-), the same options
you used make no appreciable difference, my best time is 00:30:03.
I guess it's down to kernel build and/or libraries.
Thanks for your comments and especially for that report, very
informative.
Bill Hails
>>- NC
> informative.
As you are speaking about librairies, something noticable is that
staticaly linked libraries offers better performances ... perhaps this
can explain your 2 minutes ?
>>>- NC
>> informative.
Hmm, maybe, but I thought dynamic linking only had a performance hit
while an executable was starting up, I wasn't aware of any penalty
once an executable is up and running.
I was thinking more about optimizations that might have been done
better while building the kernel and libc, libpng etc, though since
my whole system was gcc-compiled with switches optimised for my
hardware (Lunar builds itself from source), I would have expected
a slightly better result than the published benchmark, if anything.
Bill Hails
