POV-Ray : Newsgroups : povray.unix : Return code 11 Server Time
28 Sep 2024 18:02:33 EDT (-0400)
  Return code 11 (Message 1 to 4 of 4)
Subject: Return code 11
Date: 2 Aug 2004 01:49:19
Message: <410dd5df$1@news.povray.org>
I'm running Linux 2.2 with 96MB RAM, 200MHz Pentium. I run the following
line from my CGI script:
/home/bob/povray-3.5/povray +I/usr/local/apache/htdocs/cgi-out/in.pov +W400
+H300 +O- +A0.1  +FN
And I the program exits with return code 11. When I run it normally at the
prompt, it runs fine. And I'm quite sure it isn't a file access issue,
because I've set my server to run as myself. What does return code 11 mean?
How do I fix it?
Thanks in advance,
Robert
Subject: Re: Return code 11
Date: 2 Aug 2004 03:47:12
Message: <410df180@news.povray.org>
> How do I fix it?
Use POV-Ray 3.6 or make sure your 3.5 does not want to access an X display.
    Thorsten
Date: 2 Aug 2004 07:12:31
Message: <410e219f@news.povray.org>
> display.
I tried installing 3.6, I encountered the problem mentioned in the thread
"make error: problem solved". I couldn't find any C_INCLUDE_PATHs anywhere,
so I tried the procedure given in INSTALL 4.1.3, but after a fair while, it
died:
../source/libpovray.a(radiosit.o): In function `pov::ra_gather(double *,
double
*, double *, float *, double)':
radiosit.o(.text+0x5b7): undefined reference to `Frame'
radiosit.o(.text+0x5cb): undefined reference to `Frame'
radiosit.o(.text+0x5e1): undefined reference to `Frame'
radiosit.o(.text+0x1092): undefined reference to `Frame'
radiosit.o(.text+0x10a6): undefined reference to `Frame'
../source/libpovray.a(radiosit.o)(.text+0x10bc): more undefined references
to `F
rame' follow
collect2: ld returned 1 exit status
I think I'll just wait till the patch is ready. Will it be announced on this
group :)
Thanks,
Robert
Date: 2 Aug 2004 07:30:02
Message: <cel8ee$4ri$1@chho.imagico.de>
>>display.
> died:
Please follow the instructions in INSTALL for reporting possible
compilation problems.  Especially you have to say what commands you
exactly were executing that led to the error.
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
