POV-Ray : Newsgroups : povray.unix : problem with ./install kde Server Time
28 Jul 2024 00:36:16 EDT (-0400)
  problem with ./install kde (Message 1 to 3 of 3)
Subject: problem with ./install kde
Date: 14 Jun 2004 14:32:16
Message: <40cdef30$1@news.povray.org>
I try to install the panel entries with :
1 - ./install ou ./install user
then
2 - ./install kde
I obtain this message :
installing KDE integration for user 'seb'...
   copying POV-Ray icons...
   generating POV-Ray file types...
   installing main POV-Ray 3.6 submenu...
   installing ini file link...
   installing configuration file link...
   installing documentation link...
   installing sample scene render links...
   modifying povray.conf...
   checking conf file /home/seb/.povray/3.6/povray.conf
     - file does not need to be modified
Finished installing KDE panel entries
But no entries where found in my KDE menu ! What's wrong ?  :-(
Subject: Re: problem with ./install kde
Date: 14 Jun 2004 14:59:10
Message: <40cdf57e$1@news.povray.org>
You're problem is certainly due to the fact that you are using a
mandrake modified version of KDE and that's why menus are not in the
same location :-/
> then
> 2 - ./install kde
Date: 14 Jun 2004 17:00:02
Message: <cal3ht$afp$1@chho.imagico.de>
Make sure you run './install kde' as normal user, it is also possibly
necessary to restart KDE after the installation.  Apart from that it
might be that gRRosminet is right and your distribution uses a
nonstandard configuration for the KDE panel - the script has only been
tested on SuSE and Redhat (and Redhat needed a special location as
well).  Redhat uses $HOME/.kde/share/applnk-redhat/ instead of
$HOME/.kde/share/applnk/ - you can see if there is a similar dir on your
system and then you can fix it with:
ln -s $HOME/.kde/share/applnk/povray-3.6 \
$HOME/.kde/share/applnk-foo/povray-3.6
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
