POV-Ray : Newsgroups : povray.unix : qtpoveditor 0.2.2b beta Server Time
28 Sep 2024 20:11:15 EDT (-0400)
  qtpoveditor 0.2.2b beta (Message 1 to 9 of 9)
Subject: qtpoveditor 0.2.2b beta
Date: 29 Jan 2004 16:38:07
Message: <40197d3f$1@news.povray.org>
gRRominet has released the 0.2.2b beta :
http://sourceforge.net/project/showfiles.php?group_id=92021
ZeSly
http://perso.wanadoo.fr/zesly/
Subject: Re: qtpoveditor 0.2.2b beta
Date: 30 Jan 2004 20:54:08
Message: <401b0ac0@news.povray.org>
Thanks for the info!
Florian
Date: 31 Jan 2004 15:07:26
Message: <401c0afe@news.povray.org>
I was unable to connect to the news and that's why I've ask ZeSly to
tell you about this new version. I already have found a few bugs in this
new feature and these will be corrected in the final v0.2.2.
Additionaly, you'll find a documentation on the website and in the
"Ressources" directory of the package (and that would be fine if you
could help me to correct it).
Thierry
> Florian
Date: 1 Feb 2004 08:18:58
Message: <401cfcc2@news.povray.org>
already known bugs (corrected for the final version) :
- completion for key-words does only works on new files
- completion doesn't work when there is a #
- another one, but I can't remember ;-P
> Thierry
>> Florian
Subject: Stable release here :
Date: 2 Feb 2004 17:12:55
Message: <401ecb67@news.povray.org>
From gRRominet :
the stable release of qtpoveditor v0.2.2 has been published.
http://qtpoveditor.sf.net
Subject: Re: Stable release here :
Date: 3 Feb 2004 05:55:58
Message: <401f7e3e@news.povray.org>
However, I got some problems running it with Povray 3.6b1:
This is the output of POV-Ray when a render is started via QtPOVEditor:
Parsing Options
   Input file:  +MV3.5 +Q9 +W1024 +H768 +B001 +Ocircles.pov.png
  +GA/tmp/povrendering_log2455 +P circles.pov (compatible to version 3.60)
   Remove bounds........On
   Split unions.........Off
   0:00:00 Parsing
Possible Scene File Parser Initialization Error: Could not find file '
+MV3.5
  +Q9 +W1024 +H768 +B001 +Ocircles.pov.png +GA/tmp/povrendering_log2455 +P
  circles.pov'
Scene File Parser Initialization Error: Cannot open input file.
Somehow it won't take the correct input file, but I don't know why.
Anybody else got this problem? If I start the render from the command
line (without QTPOVEditor), with the same arguments, it works o_O
BTW: Using 3.5 everything works fine, so I'll use this till I find the
source of the problem ;)
Florian
Date: 6 Feb 2004 09:56:47
Message: <4023ab2f@news.povray.org>
"ZeSly" <zes### [at] wanadoofr> wrote in message
news:40197d3f$1@news.povray.org...
I messed with it a bit and like some of the new functionality. I am
still using 1.4 until proper tabs are re-implemented, however.
 -Shay
Date: 6 Feb 2004 11:26:53
Message: <4023c04d@news.povray.org>
It seems that the last functionnality have destroyed the "automatic"
tabulation mode ... I'll correct this as soon as possible.
=> ooops ... I have forget to do this :-/
Date: 6 Feb 2004 13:50:09
Message: <4023e1e1@news.povray.org>
"gRRosminet" <pov### [at] les-charlesnet> wrote in message
news:4023c04d@news.povray.org...
Thanks for all of the work on the editor. I'm still hoping for the
return of true tabs instead of spaces.
 -Shay
