POV-Ray : Newsgroups : povray.unix : Global INI-File Server Time
28 Jul 2024 02:18:21 EDT (-0400)
  Global INI-File (Message 1 to 10 of 10)
Subject: Global INI-File
Date: 4 Dec 2003 06:36:44
Message: <3fcf1c4c$1@news.povray.org>
I recently switched from Windows to Linux, and now I finally found time
to set up POV. Everything is fine, but I don't find a "global INI-file"
like the Windows-version has (IMHO it is <POVDIR>/renderer/povray.ini).
This file is parsed before every render, so it's a good place to store
global parameters, line output format, global include paths, etc. Does
the Un*x/Linux version also have such a nice file?
Thanks for your help
Florian
Subject: Re: Global INI-File
Date: 4 Dec 2003 06:45:40
Message: <3d7usvoirl3kevv5amlds3e7ega9haoqv1@4ax.com>
On Thu, 04 Dec 2003 12:37:32 -0500, Florian Brucker <tor### [at] torfboldcom> wrote:
I don't have much experience with Unix version but I suppose the answer is in
first paragraph of 1.5.2 chapter in your manual.
ABX
Date: 4 Dec 2003 06:47:38
Message: <3fcf1eda@news.povray.org>
~/.povrayrc
Date: 4 Dec 2003 09:13:18
Message: <3FCF40FD.6050101@free.fr>
> Does the Un*x/Linux version also have such a nice file?
	There are actually two INI files in the UNIX/Linux version
of povray: a system-wide file (usually /usr/local/etc/povray.ini)
and an user file called .povrayrc in your home directory (note: it
is usually "hidden" due to the first dot in its name).  The second
file does not exist by default, and you should create it by copying
the first one.  If you use a non-root account on your machine (which
is recommanded anyway), you should not touch the system-wide INI file,
but edit your ~/.povrayrc instead.
	- NC
Date: 4 Dec 2003 15:16:23
Message: <3fcf9617@news.povray.org>
Nicolas Calimet <pov### [at] freefr> wrote:
> (note: it is usually "hidden" due to the first dot in its name)
  It's debatable whether a file can be called "hidden" simply because
ls doesn't list it by default.
  I'm not aware of any other program which would not "see" it as any
other file. Even "echo *" lists all files.
Date: 4 Dec 2003 15:25:38
Message: <3fcf9842$1@news.povray.org>
You're right. I did check the other sections of the manual (those about
INI-options), but I didn't even know there was a platform specific
section...
Thanks for the help!
Florian
Date: 4 Dec 2003 16:18:05
Message: <pan.2003.12.04.21.18.05.168351@lionsanctuary.net>
Nautilus' default configuration (in fact, most of GNOME's default
configuration; I can't speak for KDE) is to hide .files and .directories.
Date: 4 Dec 2003 19:59:12
Message: <cjameshuff-27D72F.19584304122003@netplex.aussie.org>
In article <3fcf9617@news.povray.org>, Warp <war### [at] tagpovrayorg>
It *is* a convention that files beginning with "." are considered
invisible. "echo *" doesn't list all the files, it echos a string of all
files matching "*" to standard output...dot files match that expression,
so they are included.
http://tag.povray.org/
Date: 5 Dec 2003 09:04:57
Message: <3fd09089@news.povray.org>
  The difference being...?-)
Date: 6 Dec 2003 11:23:33
Message: <cjameshuff-30C09B.11231106122003@netplex.aussie.org>
In article <3fd09089@news.povray.org>, Warp <war### [at] tagpovrayorg>
Visibility has nothing to do with matching regular expressions...unless
you set up the expression to depend on a leading dot. (though I do think
this method is stupid...a meta-data flag would be far more appropriate)
