POV-Ray : Newsgroups : povray.unix : Terminal handling bug? Server Time
31 Oct 2024 08:18:43 EDT (-0400)
  Terminal handling bug? (Message 1 to 8 of 8)
Subject: Terminal handling bug?
Date: 6 Nov 2002 15:48:05
Message: <3dc98005@news.povray.org>
Trying to get 3.50c to work on linux, Debian 3.0 systems (dual Pentium |||
systems). It actually works *great* (kudos to the devels)... except (you
*did* expect an 'except' in a bug report, right?) when doing something like
rsh othermachine ~/pov/pov.sh
or
qsub ./pov.sh
where pov.sh is something akin to
cd ~/pov
povray [params]
It dies with a Segmentation Fault.
Debian's packaged 3.0 does not have that problem. Redirecting output doesn't
seem to help at all. The +GA command option is not helping either.
Can anyone confirm the bug on other linuxes? Provide a fix? (Setting TERM to
something magic?)
Have fun,
Chris
Subject: Re: Terminal handling bug?
Date: 6 Nov 2002 16:21:10
Message: <3dc987c6$1@news.povray.org>
In article <3dc98005@news.povray.org> , Christian Lavoie
You are not by any chance trying to use display without having X configured
or something similar?  Essentially your problem is most likely related to
the fact that the 3.5 binary is a kind of hybrid, while the Debian package
might just be a plain command line version without X output support.
In any case, as you may have noticed this group not being filled with notes
that the Linux version does not work Linux systems, you may want to check
your system configuration carefully, and regarding the X issue, check older
messages in this group.  I can't promise it will help you solve your
problem, but probably give you some pointers what to check first...
    Thorsten
Date: 6 Nov 2002 17:23:25
Message: <3dc9965c@news.povray.org>
>> doesn't seem to help at all. The +GA command option is not helping
>> either.
> configured
Not as far as I know. Been thru the manpages repeatedly, nothing there
sounds like it could cause this.
/usr/local/bin/povray +Ibasic.pov +Obasic.tga +H800 +W800
What exactly could go wrong with *nothing* turned on?
X -- nope. $DISPLAY is not set anyway.
Stream redirection -- didn't help.
UNIX stdout/err redirection, etc -- didn't help.
In any cases, a segfault wasn't what I expected.
3.5 works great *unless* I have some sort of non-terminal usage. If I rsh to
a machine and THEN start it, it works. If I rsh to the *same* machine and
pass the script to rsh as the command to execute, it dies.
If I throw it through the queueing system (PBS as it happens), it dies. If I
rsh to the same machine pbs scheduled it and then run it -- wonderful.
I've compared the environment variables. There wasn't anything that could
cause segfaults in there -- as far as I could tell.
> notes that the Linux version does not work Linux systems, you may want to
> check your system configuration carefully, and regarding the X issue,
> check older
Thanx anyway.
Have fun,
Chris
Date: 6 Nov 2002 21:51:31
Message: <pan.2002.11.07.02.50.53.580728@povray.org>
> (you *did* expect an 'except' in a bug report, right?) when doing
> something like
> or
> qsub ./pov.sh
> cd ~/pov
> povray [params]
Can you confirm that this works on this machine otherwise? I want to make
sure the rsh isn't a red herring.
> either.
A number of things have changed since 3.0.
> TERM to something magic?)
I am unable to confirm using ssh from Mandrake 8.2 to Red Hat 7.3.  Then
again, it's passing my xauth and display, so it's even displaying properly
(though very slowly).  You may want to try ssh as an alternative to rsh (I
try to avoid rsh unless I'm very, very far from the Internet, which I'm
not at the moment).
-Mark Gordon
Date: 7 Nov 2002 10:27:33
Message: <3dca8665@news.povray.org>
  Have you tried with -d
Date: 7 Nov 2002 12:13:23
Message: <3dca9f33@news.povray.org>
Yes, it works if I do
workstation:~$ rsh somecomp
somecompe:~$ ~/pov/tut/pov.sh
but not if I do
workstation:~$ rsh somecomp ~/pov/tut/pov.sh
or
workstation:~$ qsub ./pov.sh
and it's scheduled on somecomp
Lemme repeat myself: It works *great* on somecomp unless I use rsh to
execute the script directly or the queueing system. It works *great* on
workstation too, for all that's worth.
It would seem the common factor would be login vs non-login sessions. And
since my .bash_profile sources bashrc directly, I can't see this changing a
thing.
>> either.
Hopefully :)
> not at the moment).
I'm carefully avoiding X and all that on purpose. I *don't* want it to
render to an X screen if I do it thru a queue =P.
Have fun,
Chris
Date: 10 Nov 2002 20:18:34
Message: <r0d3a-f41.ln1@orion.netgate.net.nz>
I'm also getting same effect.
here's what I'm seeing.
If I run on the local machine with X - sweet
if I run on the same machine with a remote X (16bit) seg fault, have to run
with a -d option.
If i run via a vncserver (24 bit) same problem. Again have to use the -d
option.
This is running on a Duron 900 with 512 M Ram, running Debian Linux
unstable.
Fran.
>> something like
>> or
>> qsub ./pov.sh
>> cd ~/pov
>> povray [params]
>> either.
> not at the moment).
> -Mark Gordon
Date: 11 Nov 2002 19:10:53
Message: <7ht5a-lg2.ln1@orion.netgate.net.nz>
Addition to this...
The vncserver method seems to be ok, BTW.
> run with a -d option.
> option.
> unstable.
> Fran.
>>> something like
>>> or
>>> qsub ./pov.sh
>>> cd ~/pov
>>> povray [params]
>>> either.
>> properly
>> (I try to avoid rsh unless I'm very, very far from the Internet, which
>> I'm not at the moment).
>> -Mark Gordon
