POV-Ray : Newsgroups : povray.unix : Linked pov files Server Time
28 Jul 2024 06:12:21 EDT (-0400)
  Linked pov files (Message 1 to 10 of 10)
Subject: Linked pov files
Date: 30 Sep 2002 17:33:46
Message: <3d98c33a@news.povray.org>
hi, I am having a problem with running povray from a seconf pc via nfs.
I have linked my /usr/lb/povray-3.5 from one machine to the actuall
directory on the other machine, and done the same for the directory that
I am workingfrom,
So from a terminal I can do "less /usr/local/Rendering/some_pov_files" on
both machines and it works/.
same for the /usr/lib/includes.
yet running povray from the lnked machine it tells me it cant open any
include files like colors.inc etc.
Yet as the user i can read them but povray cant
Any clues?
 *   nelson sandalwood
 *       zoism.org
Subject: Re: Linked pov files
Date: 1 Oct 2002 03:04:10
Message: <3D9948EA.8030607@free.fr>
> I am workingfrom,
> Any clues?
Yes, what does your local ~/.povrayrc gives as library path ?
Date: 1 Oct 2002 04:03:26
Message: <3d9956ce$1@news.povray.org>
it list /usr/lib/povray-3.5 and /usr/lib/povray-3.5/includes
This is the same on both machines,
/usr/lib/povray-3.5 on one machine is a link via nfs to the
/usr/lib/povray-3.5 on theother machine.  Readble as normal users.
 *   nelson sandalwood
 *       zoism.org
Date: 2 Oct 2002 06:18:12
Message: <slrnaplgoq.s5.steve@zeropps.org.uk>
What happens if you try rendering a short scene that dowsn't require
include files?
camera{
       location <0,0,-13>
       look_at <0,0,0>
box{
    <-1,-1,-1>,<1,1,1>
    pigment{color rgb <1,0.5,0.5>}
    rotate<45,45,45>
    translate x*-5
sphere{0,1
       translate x*4
       pigment{color rgb <0.5,1,1>}
light_source{<-40,30,-30>,1}
light_source{<40,-10,-10>,1}
                                             or http://start.at/zero-pps
 10:45am  up 96 days, 21:11,  2 users,  load average: 1.02, 1.01, 1.00
Date: 2 Oct 2002 16:15:44
Message: <3d9b53f0@news.povray.org>
> include files?
Works fine, (your example had a few extra '}' in it for some reason)
 *   nelson sandalwood
 *       zoism.org
Date: 3 Oct 2002 05:25:59
Message: <slrnapo37q.3uv.steve@zeropps.org.uk>
>> include files?
Strange did you post it into an old scene or create a new POV file?
If it now renders fine without include files then I'd suggest that you
have a permission problem with the include files, make those directories
and files world readable.
Beware I had an include problem that looked like something different but
it turned out that I had entries like:
Library_Path=/usr/local/lib/povray31                 ;; (+Ldir)
Library_Path=/usr/local/lib/povray31/include
Library_Path=/usr/local/lib/povray-3.5/include
Library_Path=/home/sjlen/pov
When I commented out the 3.1 library paths then the problem went away.
This issue is probably addressed in the docs I had't got as far as
checking when I found the solution.
 10:19am  up 97 days, 20:46,  2 users,  load average: 1.20, 1.25, 1.12
Date: 3 Oct 2002 15:42:49
Message: <3d9c9db9$1@news.povray.org>
A new file.
Yes, I had thought that but Ican do less
/usr/lib/povray-3.5/include/colors.inc without a problem.
Yes. Iencountered that problem on the main machine some time ago.  What I
am trying to do isget a basic two machine render farm (or farmlet I guess
;-) goingwithout needing to copy changes to each machine but I can'teven
get a second one going. Sad.
 *   nelson sandalwood
 *       zoism.org
Date: 3 Oct 2002 15:48:01
Message: <3d9c9ef1@news.povray.org>
Ok, I can makeit workby doing +L/usr/lib/povray-3.5/include
Why wontit read the ini file commands on one machine but it will on the
other. They are the same file. not just copies.
 *   nelson sandalwood
 *       zoism.org
Date: 3 Oct 2002 18:08:32
Message: <slrnappfnu.59p.steve@zeropps.org.uk>
But when you're logged into a different machine your home directory is
different so it'll be using a different .rc file try consolidating your
account so that you have one login and one home direcotry or a common
home directory.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 3 Oct 2002 20:16:44
Message: <3d9cddec@news.povray.org>
> home directory.
I have taken care of that, they are different users, but useing identical
rc files.
I am worndering if it's something about povray not following links maybe?
I removed the /usr/lib/povray-3.5 link (that linked tothe same
ontheoriginal machine via nfs) and straight copied the directory over.
Now it works.  What I wantto do is save having multiple copies of files,
that way I know each machineis rendering from the same data.  While it
works with my own files one day I imagine there will be a change to the
standard includes andI'll have toremeber to copy them to each machine.
 *   nelson sandalwood
 *       zoism.org
