POV-Ray : Newsgroups : povray.unix : pov-mode.el Server Time
29 Mar 2026 12:17:25 EDT (-0400)
  pov-mode.el (Message 1 to 6 of 6)
Subject: pov-mode.el
Date: 7 Aug 2002 15:24:30
Message: <3d5173ee$1@news.povray.org>
I have updated it now, here are the changes:
;;    Added Insert menu, it uses the directory structure of the winpov
;;           insert menu.
;;    Moved the toolbar icons out to separate xpm-files.
;;    Added some missing keyword expansions
;;    Fixed so that box, cylinder... has their own face, object-face,
;;            removed unused faces
;;    Cleaned up the code and removed unused parts.
;;    It works in versions 21, can't test in 20, font-lock is borked for me.
If you experience problems please let me know, and if you are able to use
it in Emacs20 I want to know that too.
It's available at http://www.acc.umu.se/~woormie/povray/pov-mode.tgz
/Peter Toneby
Subject: Re: pov-mode.el
Date: 7 Aug 2002 23:47:58
Message: <3d51e9ee@news.povray.org>
Just thought I'd note - when I tried to byte-compile pov-mode.el, I got the
error "Variable binding depth exceeds max-specpdl-size", which I resolved
by adding the line '(setq max-specpdl-size 1000000)' to my .emacs file
(don't ask me what this means - I just found it on google).
Ken
> ;;           insert menu.
> me. ----
> /Peter Toneby
Date: 8 Aug 2002 07:27:22
Message: <3D525599.45382B8E@gmx.de>
The toolbar uses "~/lib/emacs/view.xpm" and "~lib/emacs/render.xpm" which
only works if pov-mode is installed into that dir.  I'm not sure if that
could be fixed easily, but at least there should be a variable for
defining a different location.
Last updated 03 Aug. 2002 _____./\/^>_*_<^\/\.______
Date: 10 Aug 2002 12:30:32
Message: <3d553fa8$1@news.povray.org>
I've noted (and fixed) this error when interpreting the code, but since I
don't bytecompile (I use the same pov-mode.el for emacs and xemacs) I
never realised that bytecompiling would be affected too. I'll see if I can
get this fixed somehow.
Emacs has this variable set ridicusly low, around 300, Xemacs has it at
1000. My fix is to see if it's <1000 then set it too 1000. I wonder how to
fix it properly for bytecompiling as well...
/Peter
Date: 10 Aug 2002 12:32:10
Message: <3d55400a@news.povray.org>
Whoospie... me bad... I forgot about that... I'll fix it, it's a nobrainer
/Peter
Date: 10 Aug 2002 14:22:21
Message: <3d5559dd$1@news.povray.org>
There, a new version is uploaded, should work now, at least it does for
me...
And there are no other "lib/emacs" in the file :)
/Peter
