![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I have updated it now, here are the changes:
;; Added Insert menu, it uses the directory structure of the winpov
;; insert menu.
;; Moved the toolbar icons out to separate xpm-files.
;; Added some missing keyword expansions
;; Fixed so that box, cylinder... has their own face, object-face,
;; removed unused faces
;; Cleaned up the code and removed unused parts.
;; It works in versions 21, can't test in 20, font-lock is borked for me.
If you experience problems please let me know, and if you are able to use
it in Emacs20 I want to know that too.
It's available at http://www.acc.umu.se/~woormie/povray/pov-mode.tgz
/Peter Toneby
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Just thought I'd note - when I tried to byte-compile pov-mode.el, I got the
error "Variable binding depth exceeds max-specpdl-size", which I resolved
by adding the line '(setq max-specpdl-size 1000000)' to my .emacs file
(don't ask me what this means - I just found it on google).
Ken
> ;; insert menu.
> me. ----
> /Peter Toneby
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The toolbar uses "~/lib/emacs/view.xpm" and "~lib/emacs/render.xpm" which
only works if pov-mode is installed into that dir. I'm not sure if that
could be fixed easily, but at least there should be a variable for
defining a different location.
Last updated 03 Aug. 2002 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I've noted (and fixed) this error when interpreting the code, but since I
don't bytecompile (I use the same pov-mode.el for emacs and xemacs) I
never realised that bytecompiling would be affected too. I'll see if I can
get this fixed somehow.
Emacs has this variable set ridicusly low, around 300, Xemacs has it at
1000. My fix is to see if it's <1000 then set it too 1000. I wonder how to
fix it properly for bytecompiling as well...
/Peter
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Whoospie... me bad... I forgot about that... I'll fix it, it's a nobrainer
/Peter
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
There, a new version is uploaded, should work now, at least it does for
me...
And there are no other "lib/emacs" in the file :)
/Peter
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
