POV-Ray : Newsgroups : povray.unix : Permission options? Server Time
31 Mar 2026 15:14:29 EDT (-0400)
  Permission options? (Message 1 to 4 of 4)
Subject: Permission options?
Date: 6 Aug 2002 18:48:30
Message: <3d50523d@news.povray.org>
The permission options which allow pov-script to do everything have been
repeated over and over again a million times.
  However, has anyone thought that perhaps not everyone would want to allow
*everything*?
  What are the options to allow reading but not writing, for example? Is
there a list somewhere?
Subject: Re: Permission options?
Date: 7 Aug 2002 00:02:46
Message: <slrnal16va.4kv.ron.parker@fwi.com>
Read unix.cpp, in the function UNIX_Process_Povray_Conf (which probably
needs a little work.  Case-sensitive, Mark?)
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 7 Aug 2002 10:01:30
Message: <slrnal2a1v.7et.ron.parker@fwi.com>
Okay, I made this quick-and-dirty guide to what can be in povray.conf.
Note that this is case-sensitive.
[File I/O Security]
none | read-only | restricted
[Shellout Security]
allowed | forbidden
[Current Directory Read/Write]
allowed | forbidden
[Permitted Input Paths]
nn=<dir>
[Permitted Output Paths]
nn=<dir>
For the lines that say "nn=<dir>" you may specify any number from 0 to 64
for nn, and give the name of a directory for <dir>.  Note that <dir> can
be an absolute path, a path relative to the install directory (use
"%INSTALLDIR%"), or a path relative to the current working directory (which
changes depending on where you invoked POV from; obviously this is of
limited usefulness.)  POV does not currently support the '~' character,
either by itself or with a username (e.g. ~ron -> /home/ron).
Date: 7 Aug 2002 10:39:18
Message: <3d513115@news.povray.org>
This should definitely be included in the official distribution somewhere
where it can be easily found (eg. a file called "permissions.readme" or
whatever, besides the documentation of course).
