Hi all,
With the official binary I have had no problems, though it is slow.
I compiled my own and whether I compile static or dynamic, with or
without any optimisation it always dies trying to render benchmark.pov.
I have tried Ken's and Micha's binaries and they also die on benchmark.pov.
I can render a 40x30 image but not a 400x300.
The program either seg faults or locks the box up totally.
Many other scenes will render ok.
I tried compiling the program with electric fence. This shows no errors
on simpler scenes but I do not have enough memory to render
benchmark.pov while using efence.
Anyone else see this problem?
Geoff
What CPU?
http://objects.povworld.org - the POV-Ray Objects Collection
On 08/06/2002 04:38 AM, Micha Riser wrote:
> What CPU?
It's an Athlon 2000 XP running Mandrake 8.2.
gcc 3.1.1 or 3.2 makes no difference.
Motherboard A7V333 with kernel 2.4.19-rc3-ac2 compiled with gcc3.1.1
Seems stable otherwise, quake3 will run as long as I can be bothered
letting it run, ditto memtest86.
Geoff
I just did a 400x300 rendering of benchmark.pov which worked fine.
Hmm.. strange. Have you tried on a bit-more-official linux kernel? Have you
tried other sences that use photons (e.g. optics.h)?
- Micha
> - Micha
> - Micha
I can render optics.pov ok.
I am using such a new kernel because the original Mandrake one doesn't
have drivers for the southbridge chip on the motherboard but I will give
it a go when I reboot next.
I noticed you have produced some more binaries so I will try those too.
Cheers for making them available.
Geoff
