POV-Ray : Newsgroups : povray.unix : Another small compilation problem. Server Time
28 Jul 2024 02:26:46 EDT (-0400)
  Another small compilation problem. (Message 1 to 5 of 5)
Subject: Another small compilation problem.
Date: 14 Nov 2003 14:14:26
Message: <3FB536DF.4060506@yahoo.com>
Hi all,
The code rely on the define X_DISPLAY_MISSING to avoid inclusion of X stuff.
Unfortunalty, it doesn't work because, on my SS5, X isn't installed, it
shown by configure ("X ... no") but this define is not set so the
compilation fails.
The workaround is obvious but perhasp something can be done in configure
script ;-D
Bye
Lolo
Subject: Re: Another small compilation problem.
Date: 15 Nov 2003 08:26:06
Message: <3FB6296E.4030200@free.fr>
> script ;-D
	As Warp told you before, those kind of problems will be handled
correctly (or at best) in the next version. Meanwhile, since you know
the workaround, do it  ;-)
	- NC
Date: 15 Nov 2003 09:04:20
Message: <3FB63FB1.1090605@yahoo.com>
>> configure script ;-D
Yes, I done it and povray is currently working on benchmarch.pov on my
SS5 under NetBSD (I don't expect anything before ... monday ;-D).
I'm fighting now with linking problem against TIFF library on my Ultra
under Solaris ...
Bye
Lolo
Date: 15 Nov 2003 11:44:37
Message: <3fb657f5@news.povray.org>
> under Solaris ...
  Link the tiff library statically. That should fix the problem.
  That is, locate the libtiff.a file in your system and then replace
"-ltiff" with "/the/location/of/libtiff.a".
  There is a really strange problem in some Solaris systems where the
dynamic version of the tiff library is not compatible with the static
library, which is the correct one.
Date: 16 Nov 2003 07:33:20
Message: <3FB77BDA.3090900@yahoo.com>
>>under Solaris ...
This is the problem : there is another "old" TIFF library flying in
openwin directories. So, to solve this problem, you MUST have
/usr/local/lib (or whatever) before other system directories.
-r--r--r--   1 laurent  staff    1284230 nov  14 18:57
/usr/local/lib/libtiff.a
-r-xr-xr-x   1 laurent  staff     526973 nov  14 18:57
/usr/local/lib/libtiff.so
but I got the same thing w/ other library :
-rw-r--r--   1 laurent  other     212436 sep  16  2001
/usr/local/lib/libpng.a
-rwxr-xr-x   1 laurent  other     179308 sep  16  2001
/usr/local/lib/libpng.so.3.1.2.0
and it seems everything is working fine w/ PNG in both static or dynamic.
Anyway, now it's working and I've done "Benchmark.pov" in ... 10h14m !
Fare from fastest PCs but not so bad for an old machine w/o strong
optimisation (GCC done the compilation).
Bye
Lolo
