POV-Ray : Newsgroups : povray.unix : Segmentation Fault During Parsing Server Time
28 Sep 2024 22:19:20 EDT (-0400)
  Segmentation Fault During Parsing (Message 1 to 3 of 3)
Subject: Segmentation Fault During Parsing
Date: 1 Aug 2003 12:35:40
Message: <3F2A96DE.1090903@csumb.edu>
I am trying to render a polymer that has 250k atoms.  I wrote a script
to convert the xyz file into pov code.  There are around 1 million
lines.  I get a segmentation fault during parsing.  Is there a way to
fix this or am I just trying to render to many lines?
Also if anyone has any suggesting on other posible programs that could
animate large xyz files.
I am doing my rendering on a unix cluster.
dual 2.4 mhz 2gigs ram.
Please Email me at: Dan### [at] csumbedu
Subject: Re: Segmentation Fault During Parsing
Date: 1 Aug 2003 14:02:13
Message: <3F2AAB24.5CB3B61D@gmx.de>
There is no limitation in POV for the number of lines a scene file can
have (at least not in the order of one million).
On a cluster - then probably not the official version - in that case the
problem could lie just anywhere.
If you really want support for your problem you should:
- see if it happens with the latest official unmodified version.
- tell what hardware you are using.
- tell what the scene file contains (type of objects and other features
used).
- tell at what size of scene (number of objects) this starts.
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Date: 1 Aug 2003 14:22:40
Message: <3f2aaff0@news.povray.org>
I think this Windows program can:
http://www.accelrys.com/dstudio/ds_viewer/
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
