POV-Ray : Newsgroups : povray.unix : Pyvon 1.2 Server Time
29 Sep 2024 00:15:08 EDT (-0400)
  Pyvon 1.2 (Message 1 to 10 of 16)
Subject: Pyvon 1.2
Date: 5 Jan 2003 16:30:03
Message: <3E18B1B8.7040906@caramail.com>
I have fixed the remaining bugs left (as far as I know)
- Multilinecomments highlights works as on POVWin the /* and */.
- When there is an error in a file, pyvon switch to that file if it is
in the file selector or display a message if not.
- Fixed a stupid mistake I left with the user rights
Added automatic word expansion :
For example, just type 'hy' or 'hei' in pyvon, and it will automatically
puts 'hypercomplex' or 'height_field' instead.
The Ctrl+<space> key combination ( for the other keywords) still works
of course.
http://pyvon.sourceforge.net
As always, comments, suggestions, flames, congratulations are welcome
Fabien HENON
Subject: Re: Pyvon 1.2
Date: 5 Jan 2003 22:45:46
Message: <3e18fbe9@news.povray.org>
this quote from fabien Henon of Monday 06 Jan 2003 11:29 am:
Hi
thanks for an update to the package.
Unfortunately, I'm still getting the same problem.
This is with Mandrake 9, python 2.2.1, KDE 3.0.3
I tried installing with the script in the .gz file, and with the rpm file
(rpm -e followed by rpm -i).  The rpm install gave many many warnings that
user Fabien does not exist.
In each case, the symptom is that running pyvon brings up the black streams
box but then everything disappears.  This command
$python /usr/local/pyvon/d35.py
gives error message
$ python /usr/local/pyvon/d35.py
Traceback (most recent call last):
  File "/usr/local/pyvon/d35.py", line 2252, in ?
    menu1.add_command(label=x[:-4],command= lambda nom=longname :
insert_example(nom),font=police)
NameError: name 'menu1' is not defined
Any suggestions much appreciated.
TIA
Peter
Date: 6 Jan 2003 05:05:04
Message: <web.3e19549d84d5eda27ff7c9e30@news.povray.org>
Could you tell me what you have in the Insert directory (just the first 10
items will be enough). It might be because of the way your files are sorted
in your directory.
Something else : edit the file d35.py, goto line 2252 and replace
menu1.add_command(label=x.......
with :
menu.add_command(label=x.......
Tell me if it works better.
Fabien H
>Hi
>gives error message
>TIA
>Peter
Date: 6 Jan 2003 18:53:50
Message: <3e1a170d@news.povray.org>
this quote from HENON fabien of Monday 06 Jan 2003 11:04 pm:
> sorted in your directory.
$ls -l
 total 980
drwxrwxrwx    2 root     root         4096 Jan  6 16:37 00 - Scene
templates/
-rw-rw-rw-    1 root     root           82 Sep 20  2001 10 - background.txt
-rw-rw-rw-    1 root     root         1156 Aug 16  2001 10 - Basic scene.txt
-rw-rw-rw-    1 root     root          265 Aug 30  1998 10 - clock.txt
-rw-rw-rw-    1 root     root          524 Apr 27  2001 10 - Fog
definition.txt
drwxrwxrwx    2 root     root         4096 Jan  6 16:37 10 - Headers/
-rw-rw-rw-    1 root     root           67 Aug 30  1998 10 - rgb.txt
-rw-rw-rw-    1 root     root          121 Apr 25  2001 10 - Scene File
Header.txt
-rw-rw-rw-    1 root     root          477 Apr 27  2001 10 - waveform
attribute.txt
-rw-rw-rw-    1 root     root          456 Apr 27  2001 20 - additional
animation variables.txt
-rw-rw-rw-    1 root     root           57 Sep 26  2001 20 - Ambient fog.txt
-rw-rw-rw-    1 root     root          111 Apr 27  2001 20 - frequency
attribute.txt
-rw-rw-rw-    1 root     root          106 Sep 20  2001 20 -
global_settings.txt
drwxrwxrwx   26 root     root         4096 Jan  6 16:37 20 - Include files/
-rw-rw-rw-    1 root     root          926 Jul 19  2001 20 - Orthographic
scene.txt
---snip---------
> with :
ok tried that, but no change.  Just the black streams box comes up for a
second or so, then all disappears.  When I try running d35 direct with
python, it gives a similar error to previous ...
    menu.add_command(label=x[:-4],command= lambda nom=longname :
NameError: name 'menu' is not defined
anything else I can try?
thanks
Peter
Date: 7 Jan 2003 06:19:29
Message: <3e1ab7c1@news.povray.org>
One thing:
  The installation instructions say: "log as root : su"
  Problem: Not every unix user (such as myself) is a sysadmin, ie. has root
access.
  I have not yet tried to install the Pyvon package for myself here, but
I'm going to try it now. It's just that when I read the installation
instructions I knew that it would not be as simple as depicted.
  Suggestion: Either add support for local installation to the installation
script (to a user-specified directory or optionally to a default directory
in the home directory of the user) and document this option in the
installation instructions, or if there's an easy way of using the program
locally without running the installation script, describe this in the
instructions.
Date: 7 Jan 2003 06:30:43
Message: <3e1aba63@news.povray.org>
  I "installed" the package in the same way as the install.sh script does,
but to another directory.
  The first problem was that the 'pyvon' script assumes that it has been
installed in /usr/local/pyvon.
  Fixing that didn't help: When I run it, it opens a small window which
immediately closes and the program terminates. No error messages, nothing.
It just immediately terminates and that's it.
  What could be the problem? Perhaps more places which assume that the
program is installed under /usr/local/pyvon?
  (And no, I don't have access to /usr/local nor I can install anything
there. I'm no root.)
Date: 7 Jan 2003 09:15:08
Message: <web.3e1addfc84d5eda27ff7c9e30@news.povray.org>
This is getting interesting...
I downloaded the rpm file from the pyvon web site and installed it after
removing the previous installation with a 'rpm -e pyvon'
And it worked fine.
Things you might try :
- Run pyvon as root
- Check you reading permissions on the Insert directory
- Move all your folders and files from the Insert directory to a backup
directory ( just leave the 'Insert' with nothing in it), run pyvon
directory except for one folder and all its files, run pyvon
directory except for one *.pov file located in the Insert directory, run
pyvon
One more thing near line 2252 :
Replace this
----snip----------
for x in listeobjets :
        longname = os.path.join(InsertDir,x)
        if os.path.isdir(longname) :
            menu1 = Menu(menu_insert_popup,tearoff=0,font=police)
            menu_insert_popup.add_cascade(label=x,menu=menu1)
            importedir(longname,menu1)
        if os.path.isfile(longname) :
            if x[-3:] == 'txt' or  x[-3:] == 'pov' :
                menu1.add_command(label=x.............
------snap --------------
with this :
----snip----------
Please pay attention to the indentation (very important in Python)
Tell me which one works (at least one should) to understand what's going on.
Thanks
Fabien H
>$ls -l
> total 980
>templates/
>definition.txt
>Header.txt
>attribute.txt
>attribute.txt
>global_settings.txt
>scene.txt
>> with :
>thanks
>Peter
Date: 7 Jan 2003 14:05:23
Message: <3E1B32C0.2040101@caramail.com>
I have updated the installation page and made a safer version ( with a
few modifications in the Insert directory).
For those who got stuck, tell me if it's better now.
Fabien
Date: 7 Jan 2003 14:19:03
Message: <3E1B3603.9010305@caramail.com>
I guess you untarred the d35.tgz file in you home directory.
I used /usr/local because that's the directory used by POV-RAY when
using the install.sh script contained in the povlinux.tgz archive.
What message do you get when you type python d35.py in the pyvon directory?
Fabien H
Date: 8 Jan 2003 04:33:37
Message: <3e1bf06d@news.povray.org>
this quote from HENON fabien of Wednesday 08 Jan 2003 3:10 am:
> And it worked fine.
I don't know.  I tried rpm -e pyvon when Daniel suggested it for pyvon 1.1.
Also tried it with pyvon 1.2.  But no luck.
I'll try these out in the morning.  (10:30pm so a bit late for me to start
now.)
> Replace this
> ----snip----------
> with this :
> ----snip----------
Yes, move the menu1= line to above the if statement.  I tried that earlier
with 1.1 and recently with 1.2, and it lets pyvon start (and it appears to
function ok).  Except the insert pull down menu in pyvon doesn't function
properly - it flashes up and disappears as soon as I let go of the mouse
button.  Other menus stay up after one click so you can select a menu item.
(I tried looking through an earlier pyvon for how menus are handled, but it
was too different for me to make sense of it.)
cheers
Peter
