POV-Ray : Newsgroups : povray.unix : Povray and Apache Server Time
28 Jul 2024 06:10:31 EDT (-0400)
  Povray and Apache (Message 1 to 4 of 4)
Subject: Povray and Apache
Date: 9 Sep 2002 13:40:12
Message: <3D7CDCFA.74FEDDC0@hitchcock.org>
Hi All,
I just installed Povray 3.5 on my linux box (SUSE 8.0), and want to get
it running from a CGI script within Apache. The CGI script works very
nicely until I try to run it within Apache. In that case, the povray
image is not created. I've checked to make sure that the Apache user
(wwwrun, nogroup) can read the following:
/tmp/image.pov                             - my  input povray script.
/usr/local/httpd/cgi-bin/povray.ini   - my ini file.
and wwwrun has write access to /tmp since the CGI script creates the
image.pov file. I have modified the $PATH environment variable to search
the povray directories. I use the +I and +O options for imput and
output.
For some reason the /tmp/image.png output file is not created. I have
the feeling it's probably something obvious that I've overlooked.
What unix environment variables must be defined in order for Povray to
work?
Has any one gotten povray to work from within apache? What am I missing?
Thanks for any help on this matter.
-James
Subject: Re: Povray and Apache
Date: 9 Sep 2002 13:53:23
Message: <3d7ce012@news.povray.org>
  I/O permissions, perhaps?
Date: 9 Sep 2002 13:58:36
Message: <3d7ce14b@news.povray.org>
 What says POV? You can get POV strams in a file with +GA, so you can
examine the posible error message.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 9 Sep 2002 18:02:51
Message: <slrnanq6jq.lju.steve@zeropps.org.uk>
Run your CGI with -w so that you get all the warnings, check your http
error_log and see what it says in there, also use:
use CGI::Carp 'fatalsToBrowser';
and as someone else said see what pov is saying about it too.
                                             or http://start.at/zero-pps
 10:59pm  up 74 days,  9:24,  2 users,  load average: 1.04, 1.16, 1.08
