POV-Ray : Newsgroups : povray.unix : MDK 8.2 & POV3.5 Server Time
31 Oct 2024 12:18:26 EDT (-0400)
  MDK 8.2 & POV3.5 (Message 1 to 8 of 8)
Subject: MDK 8.2 & POV3.5
Date: 12 May 2002 20:11:46
Message: <3CDF04AC.6070906@psu.edu>
Hi folks, I am happy  to finally be able to actually write to this
group, I am a Linux Convert! (from windows 2000, which is still on my
drive, but used only bu my wife :-)
Anyway, I have used pov for windows for eons. I just downloaded the new
beta (RC4 I think) for linux and can't get the d%mn thing to work!
After extractin the tar, I installed it "./install", as su. This put it
in /usr/local/lib/povray-3.4.99.4
Then added the environment variable
"POVINI=/usr/local/lib/povray-3.4.99.4/" to /etc/profile (for BASH)
then added the line
"Library_Path=/usr/local/lib/povray-3.4.99.4/include" to povray.ini.
Having done all this, nothing renders, well, nothing that relies on an
include file. So POV is not seeing the include files, what else do I
need to do?
thanks
paul
Subject: Re: MDK 8.2 & POV3.5
Date: 12 May 2002 21:03:51
Message: <3cdf10f7@news.povray.org>
Well,  it's not a real solution, but I've just been adding
+L/usr/local/lib/povray-3.4.99.2/include/ to my command-line which solves
the problem :)  Haven't dug into how to do this correctly yet though with
.povrayrc or something like that.
Ken
> then added the line
> need to do?
> thanks
> paul
Date: 12 May 2002 23:22:21
Message: <3CDF3156.4070805@psu.edu>
Thanks Ken,
That works great. I guess I am not smart enough yet to figure out how to
get povray.ini working :-)
Could anyone explain to me how to get povray.ini and .povrayrc etc all
working together?
Please forgive my questions, I haven't used a command line since 1991!
-paul
solves
with
 > Ken
 >>then added the line
 >>need to do?
 >>thanks
 >>paul
Date: 13 May 2002 02:05:12
Message: <3cdf5798@news.povray.org>
Paul,
POVINI should point to the defaults ini-file, not to a directory.
> then added the line
This should be fine, so probably povray doesn't find povray.ini.
What I do is to put a povray.ini in the current directory where I run
povray. So, I don't have to change any system files (and rechange them the
next time I upgrade the system).
Happy tracing
Date: 13 May 2002 08:56:02
Message: <3cdfb7e2@news.povray.org>
paul wrote:
> [problem with library path]
OK, my suggestions:
Let POVINI point to the file itself (as Thomas said).
Put a linefeed behind the last line of povray.ini.
Don't use povray-3.4.99.4 but povray35. It expects to find povray.ini
there, so it might be much easier to just rename the directory than to
set environment variables.
Felix Wiemann
Date: 13 May 2002 18:44:31
Message: <slrnae0d25.ck6.steve@zeropps.org.uk>
On Sun, 12 May 2002 23:21:58 -0400, paul wrote:
> Thanks Ken,
> working together?
I don't know anything about povray.ini, but I have .povrayrc in my home
directory and use that the way I would use a povray.ini file in windows.
I don't have to do anything special on the command line to use include
files, in .povrayrc I have:
Library_Path=/usr/local/lib/povray31                    ;; (+Ldir)
Library_Path=/usr/local/lib/povray31/include
Library_Path=/usr/local/lib/povray-3.4.99.2/include/
Library_Path=/home/sjlen/pov/
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 14 May 2002 13:17:33
Message: <3ce146ad$1@news.povray.org>
paul wrote:
> Thanks Ken,
> working together?
> -paul
Paul,
The .povrayrc file in your home directory *is* your povray.ini file.  It
is the first file that povray looks for to sort out what it's supposed
to do (for lack of a better way to put it).
To get povray working, simply install as you did, copy the povray.ini
file included in the installation to your home directory as .povrayrc,
[yoursys@localhost povray35]$ mv povray.ini ~/.povrayrc
and edit the new .povrayrc file to your specifications.
I don't know about setting all the environments as you have been.  I've
never done it and things have worked well for me.
Here's what my .povrayrc file looks like for RC4:
+FN
+O/home/jgentry/povfiles/
+P
+A0.3
+L/usr/local/lib/povray-3.4.99.4
+L/usr/local/lib/povray-3.4.99.4/include
+L/home/jgentry/povfiles/include
Everything above these lines are stock from the original povray.ini file.
Good luck and good tracing.  I hope you're better at it than I am! :-)
--Jeff
Date: 15 May 2002 08:30:15
Message: <3ce254d7$1@news.povray.org>
Thanks everyone, I have finally gotten POV to work really well!! The trick
was using the .povrayrc file in my home directory.
thanks again!
-paul
