POV-Ray : Newsgroups : povray.unix : smooth_triangle mesh not alway working? Server Time
29 Mar 2026 00:21:00 EDT (-0400)
  smooth_triangle mesh not alway working? (Message 1 to 3 of 3)
Subject: smooth_triangle mesh not alway working?
Date: 21 Sep 2000 10:04:31
Message: <39CA156E.CAFF0DA9@psi.ch>
I wrote programs which are able to convert MATLAB patch objects into
povray mesh objects, using either 'triangle' or 'smooth_triangle'
commands to build the mesh. I'm using this to picture proton clouds of a
simulation, so the objects are actually isosurfaces of a discreet volume
function.
In the smooth_triangle mesh object there are often holes. If I render
the same object with 'triangles' using the exactly same vertex data the
object looks ok and all the holes are closed.
Has anybody had the same problems with 'smooth_triangle'? Is there a fix
to it?
Thanks,
Derek
Subject: Re: smooth_triangle mesh not alway working?
Date: 21 Sep 2000 10:14:23
Message: <slrn8sk6na.564.ron.parker@fwi.com>
>function.
So the function keeps its personal life to itself?
Is it possible that some of your normals are inverted?  That is, might
you have triangles whose normals are more than 180 degrees from each
other?
By the way, you might find more answers in .general; this isn't really
a Unix question.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Proudly not helping RIAA and SDMI steal my rights --
  http://www.eff.org/Misc/EFF/Newsletters/EFFector/HTML/effect13.08.html
Subject: Re: Solved. Just a format problem
Date: 21 Sep 2000 10:37:45
Message: <39CA1D38.DD0D2A81@psi.ch>
It was just a numerical problem. The pov functions are ok. Sorry.
If anybody is working with MATLAB and would like to transfer patches to
povray, drop me a note. I will send you the MATLAB routines.
