POV-Ray : Newsgroups : povray.unix : X-povray render diplay Server Time
29 Mar 2026 10:44:52 EDT (-0400)
  X-povray render diplay (Message 1 to 3 of 3)
Subject: X-povray render diplay
Date: 11 Feb 2000 21:08:59
Message: <38A4C142.DE3274EF@peak.edu.ee>
I recently installed POV on Linux (Red Hat 6.1). Problem is, x-povray does not
create a preview window while rendering. If I force this with +d x-povray exits
with an error about being unable to initialize the display. Both POV and the X
server are running on the same machine, so -display <name> should not be needed.
Has anybody else had this problem or could recommend a solution? I'm a total
Linux newbie so the cause could be something silly...
Thanks
Margus
Subject: Re: X-povray render diplay
Date: 12 Feb 2000 01:10:36
Message: <slrn8a9q4k.acv.sjlen@zero-pps.localdomain>
On Sat, 12 Feb 2000 04:11:14 +0200, Margus Ramst <mar### [at] peakeduee> wrote:
>Thanks
Margus
Are you running this from an xterm window, that's the way I do it, don't
think it will work from a console with x-povray.  By default it displays
the render window, make sure that these lines are in your '.povrayrc' file
which should be in your home directory to get there do cd by itself.
;; Display the image while tracing controls.
Display=true                    ;; (+/-D)
Pause_When_Done=false           ;; (+/-P)
Did you use the binaries or compile your own?
I used the binaries because I know they work.
Hope this helps, if not let me know.
  4:50am  up 2 days, 10:47,  8 users,  load average: 1.47, 1.41, 1.38
Date: 12 Feb 2000 09:08:05
Message: <38A569CB.8B2203E0@peak.edu.ee>
Never mind, after a restart it works fine now.
Hell, I had hoped to avoid all that restarting with Linux :)
Thank you anyway.
Margus
