![](/i/fill.gif) |
I recently installed POV on Linux (Red Hat 6.1). Problem is, x-povray does not
create a preview window while rendering. If I force this with +d x-povray exits
with an error about being unable to initialize the display. Both POV and the X
server are running on the same machine, so -display <name> should not be needed.
Has anybody else had this problem or could recommend a solution? I'm a total
Linux newbie so the cause could be something silly...
Thanks
Margus
![](/i/fill.gif) |
![](/i/fill.gif) |
On Sat, 12 Feb 2000 04:11:14 +0200, Margus Ramst <mar### [at] peak edu ee> wrote:
>Thanks
Margus
Are you running this from an xterm window, that's the way I do it, don't
think it will work from a console with x-povray. By default it displays
the render window, make sure that these lines are in your '.povrayrc' file
which should be in your home directory to get there do cd by itself.
;; Display the image while tracing controls.
Display=true ;; (+/-D)
Pause_When_Done=false ;; (+/-P)
Did you use the binaries or compile your own?
I used the binaries because I know they work.
Hope this helps, if not let me know.
Steve email mailto:sjl### [at] ndirect co uk
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
4:50am up 2 days, 10:47, 8 users, load average: 1.47, 1.41, 1.38
![](/i/fill.gif) |
