POV-Ray : Newsgroups : povray.unix : POV-Ray 3.1e on Sun UltraSparc for Solaris 2.5.1 running well ... Server Time
28 Jul 2024 18:13:10 EDT (-0400)
  POV-Ray 3.1e on Sun UltraSparc for Solaris 2.5.1 running well ... (Message 1 to 1 of 1)
Subject: POV-Ray 3.1e on Sun UltraSparc for Solaris 2.5.1 running well ...
Date: 14 May 1999 01:24:45
Message: <373B265F.4CC4D9A3@interlog.com>
From what I can tell my build of POV-Ray 3.1e seems to be running in
fairly good form.  I checked with the benchmark times for this system
and I appear to be in the ballpark.
http://www.haveland.com/cgi-bin/getpovb.pl?search=ultra&submit=Submit
The only thing left to do to enhance performance a tad would be to get
this in parallel across a few systems ...
Anyone have any thoughts on my compiler flags ?
Dennis Clarke
dcl### [at] interlogcom
------------------- compile snippet ------------------------------
$ vi makefile
$ make newunix
gcc -O3 -ansi -c -v -Wall -mcpu=ultrasparc -mtune=ultrasparc
-DCOMPILER_VER=\".`uname`.gcc\" -I. -I.. -I../libpng -I../zlib
-I/usr/openwin/include ../povray.c -o povray.o
Reading specs from
/usr/local/lib/gcc-lib/sparc-sun-solaris2.5.1/2.8.1/specs
gcc version 2.8.1
 /usr/local/lib/gcc-lib/sparc-sun-solaris2.5.1/2.8.1/cpp -lang-c89 -v
-I. -I.. -I../libpng -I../zlib -I/usr/openwin/include -undef
-D__GNUC__=2 -D__GNUC_MINOR__=8 -trigraphs -D__STRICT_ANSI__ -D__sparc__
-D__sun__ -D__unix__ -D__svr4__ -D__SVR4 -D__sparc -D__sun -D__unix
-Asystem(unix) -Asystem(svr4) -D__OPTIMIZE__ -Wall -D__sparc_v9__
-D__GCC_NEW_VARARGS__ -Acpu(sparc) -Amachine(sparc)
-DCOMPILER_VER=".SunOS.gcc" ../povray.c /var/tmp/cca0024z.i
GNU CPP version 2.8.1 (sparc)
#include "..." search starts here:
#include <...> search starts here:
 ../libpng
 ../zlib
 /usr/local/include
 /usr/local/sparc-sun-solaris2.5.1/include
 /usr/local/lib/gcc-lib/sparc-sun-solaris2.5.1/2.8.1/include
 /usr/include
End of search list.
 /usr/local/lib/gcc-lib/sparc-sun-solaris2.5.1/2.8.1/cc1
/var/tmp/cca0024z.i -quiet -dumpbase povray.c -mcpu=ultrasparc
-mtune=ultrasparc -ansi -O3 -Wall -ansi -version -o /var/tmp/cca0024z.s
GNU C version 2.8.1 (sparc-sun-solaris2.5.1) compiled by GNU C version
2.8.1.
 /usr/ccs/bin/as -V -Qy -s -xarch=v8plusa -o povray.o
/var/tmp/cca0024z.s
/usr/ccs/bin/as: WorkShop Compilers 4.2 dev 13 May 1996
End result ...
$ file povray
povray:         ELF 32-bit MSB executable SPARC32PLUS Version 1, V8+
Required, UltraSPARC1 Extensions Required, dynamically linked, not
stripped
$ ./povray -V
Persistence of Vision(tm) Ray Tracer Version 3.1e.SunOS.gcc
  This is an unofficial version compiled by:
    Dennis M. Clarke  dcl### [at] interlogcom
  The POV-Ray Team(tm) is not responsible for supporting this version.
Copyright 1999 POV-Ray Team(tm)
System ...
$ uname -a
SunOS gigaflop 5.5.1 Generic_103640-24 sun4u sparc SUNW,Ultra-2
$ psrinfo -v
Status of processor 0 as of: 05/13/99 21:08:52
  Processor has been on-line since 03/03/99 19:24:38.
  The sparc processor operates at 296 MHz,
        and has a sparc floating point processor.
Status of processor 1 as of: 05/13/99 21:08:52
  Processor has been on-line since 03/03/99 19:24:42.
benchmark ...
$ /usr/local/povray31/povray -Iskyvase.pov +Oskyvase.tga
+L/usr/local/povray31/include +v1 -d +ft -x +a0.300 +r3 -q9 -w640 -h480
-mv2.0 +b1000 +GA
Parsing Options
  Input file: skyvase.pov (compatible to version 2.0)
  Remove bounds........On  Split unions........Off
  Library paths: /usr/local/povray31/include
Output Options
  Image resolution 640 by 480 (rows 1 to 480, columns 1 to 640).
  Output file: skyvase.tga, 24 bpp Targa, 1000 KByte buffer
  Graphic display.....Off
  Mosaic preview......Off
  CPU usage histogram.Off
  Continued trace.....Off  Allow interruption..Off  Pause when
done.....Off
  Verbose messages.....On
Tracing Options
  Quality:  9
  Bounding boxes.......On  Bounding threshold: 25
  Light Buffer.........On  Vista Buffer.........On
  Antialiasing.........On  (Method 1, Threshold 0.300, Depth 3, Jitter
1.00)
  Radiosity...........Off
Animation Options
  Clock value....   0.000  (Animation off)
Redirecting Options
  All Streams to console..........On
  Debug Stream to console.........On
  Fatal Stream to console.........On
  Render Stream to console........On
  Statistics Stream to console....On
  Warning Stream to console.......On
Parsing...........skyvase.pov:83: warning: CSG union unnecessarily
bounded.
Creating bounding slabs.
Scene contains 4 frame level objects; 3 infinite.
  -:--:-- Rendering line    0 of  480Camera is inside a non-hollow
object.
Fog and participating media may not work as expected.
  0:01:39 Rendering line  480 of  480 supersampled 10 times.
Done Tracing
skyvase.pov Statistics, Resolution 640 x 480
Pixels:          307840   Samples:          396160   Smpls/Pxl: 1.29
Rays:           1519529   Saved:                 9   Max Level: 5/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder                  2382548         1281629     53.79
CSG Intersection               3664177          396353     10.82
CSG Union                      2563258          738033     28.79
Plane                         26388738        14489618     54.91
Quadric                        2563258         1571892     61.32
Sphere                         2563258          664606     25.93
Bounding Object                2382548         1281629     53.79
Calls to Noise:            1445139   Calls to DNoise:        2816194
Shadow Ray Tests:          3726696   Succeeded:                90401
Reflected Rays:            1123369
Smallest Alloc:                 12 bytes   Largest:          1024008
Peak memory used:          1112366 bytes
Time For Trace:    0 hours  1 minutes  40.0 seconds (100 seconds)
    Total Time:    0 hours  1 minutes  40.0 seconds (100 seconds)
