![](/i/fill.gif) |
"jr" <cre### [at] gmail com> wrote:
> hi,
> "Mike Miller" <mil### [at] gmail com> wrote:
> > Scene file and .x3d to POV converter. ... x3d_blender_points.exe ...
> thanks, any chance of a different format (or source) ? have no Microsoft OS.
> regards, jr.
I'm using PureBasic for this. ...I'm leaning on free programs.. haha
I did see Unix & Mac OS versions available. I'm using 64bit Windows 11.
I have another compile that parses most of the other Blender types (blobs,
cubes, cylinders, torus, etc.) if you can compile to your OS.
Below is the PB code. I also attached the .PB file
good luck,
Mike
; Read .x3d
; m.miller 3.20.23
; 8.8 revised to handle multiple POV types from the same pointData
; removed all other blender types
StandardFile$ = "C:\file.x3d" ;
Pattern$ = "x3d (*.x3d)|*.x3d"
Pattern = 0 ; use the first of the three possible patterns
x3d_File$ = OpenFileRequester("open x3d file", StandardFile$, Pattern$, Pattern)
Path$ = GetPathPart(x3d_File$)
fileName$ = GetFilePart(x3d_File$)
fileName$ = Mid(fileName$, 1, Len(fileName$) -4)
exportFile$ = Path$ + fileName$ + ".inc"
objectCount = 0
pointDataCount = 0
arraySize = 5000
Dim aName$ (arraySize)
Dim aPosX$ (arraySize)
Dim aPosY$ (arraySize)
Dim aPosZ$ (arraySize)
Dim aPos_POV$ (arraySize)
Dim aScaleX$ (arraySize)
Dim aScaleY$ (arraySize)
Dim aScaleZ$ (arraySize)
Dim aScale_POV$ (arraySize)
Dim aRotX$ (arraySize)
Dim aRotY$ (arraySize)
Dim aRotZ$ (arraySize)
Dim aRot_POV$ (arraySize)
If x3d_File$
File = ReadFile(#PB_Any, x3d_File$)
While Eof(File) = 0
search_1$ = "Transform DEF="
search_2$ = "ifs"
search_3$ = "_TRANSFORM"
quote$ = Chr(34) ; "
space$ = Chr(32) ; space
equal$ = Chr(61) ; =
lineStr$ = ReadString(File, #PB_Ascii)
p = FindString(lineStr$, search_1$, 1)
p2 = FindString(lineStr$, search_2$, 1)
p3 = FindString(lineStr$, equal$, 1)
; find transform def without IndexedFaceSet
If p > 0 And p2 = 0
;found object
objectCount +1
l = Len(lineStr$) - p
s$ = Mid(lineStr$, p, l)
; find first quote
q = FindString(s$, quote$, 1)
; find _TRANSFORM
t = FindString(s$, "_TRANSFORM", 1)
name$ = Mid(s$, q+1, (Len(s$) - q+1)-11)
; ----- find types
If Mid(name$, 0, 9) = "pointData"
pointDataCount+1
EndIf
; read TRANSLATION (position)
temp$ = ReadString(File, #PB_Ascii)
; find first quote mark
p = FindString(temp$, quote$, 1)
; trim from quote mark
trans$ = Mid(temp$,p+1,l)
; remove end quote mark
trans$ = Mid(trans$, 0, Len(trans$) - 1)
; find first space
p1 = FindString(trans$, space$, 1)
; x data
x$ = Mid(trans$, 0, p1)
x$ = Left(x$, FindString(x$,".")+3)
; ---flip X ?? .x3d exported as Z-forward Y-up outputs -X
pN = FindString(x$, "-", 1)
If ( pN > 0 )
x$ = Right(x$, Len(x$) - 1)
Else
x$ = "-" + x$
EndIf
; re-trim
temp$ = Mid(trans$,p1+1)
;find second space
p2 = FindString(temp$, space$, 1)
; y data
y$ = Mid(temp$, 0, p2)
y$ = Left(y$, FindString(y$,".")+3)
; z data
z$ = Mid(temp$, p2+1)
z$ = Left(z$, FindString(z$,".")+3)
aName$(objectCount) = name$
aPosX$(objectCount) = x$
aPosY$(objectCount) = y$
aPosZ$(objectCount) = z$
aPos_POV$(objectCount) = "<" + x$ + ", " + y$ + ", " + z$ + "> "
; read SCALE
; find first space
; x data
; re-trim
;find second space
; y data
; z data
aScaleX$(objectCount) = x$
aScaleY$(objectCount) = y$
aScaleZ$(objectCount) = z$
aScale_POV$(objectCount) = "<" + x$ + ", " + z$ + ", " + y$ + "> "
; read ROTATION
; find first space
; x data
; re-trim
;find second space
; y data
; z data
aRotX$(objectCount) = x$
aRotY$(objectCount) = y$
aRotZ$(objectCount) = z$
aRot_POV$(objectCount) = "<" + x$ + ", " + y$ + ", " + z$ + "> "
EndIf
Wend
CloseFile(File)
; write header
; Create temp file name.
File = CreateFile(#PB_Any, exportFile$)
Debug exportFile$
Debug ".x3d convert to POV object types"
Debug "pointData Count: " + pointDataCount
; write header
tab$ = " "
s0$ = "// pointData from " + fileName$ + ".x3d"
s1$ = "// m.miller 8.8.2023" + Chr(13)
s2$ = "// note: lathe requires positive x for all points"
s3$ = "// prisms are plotted on z plane and extrude in y"
s4$ = "" + Chr(13)
WriteStringN(File, s0$, #PB_Ascii)
WriteStringN(File, s1$, #PB_Ascii)
WriteStringN(File, s2$, #PB_Ascii)
WriteStringN(File, s3$, #PB_Ascii)
WriteStringN(File, s4$, #PB_Ascii)
; write ARRAY
If pointDataCount > 0
n=0
WriteStringN(File,"//--- pointArray " , #PB_Ascii)
WriteStringN(File,"#declare pointDataCount = " + pointDataCount + " ;" ,
#PB_Ascii)
WriteStringN(File,"#declare pointArray = array mixed [pointDataCount][2]" + "
;", #PB_Ascii)
For i = 1 To objectCount
If Mid(aName$(i), 0, 9) = "pointData"
s0$ = "#declare pointArray[" + n + "][0] = " + aPos_POV$(i) + " ;"
s1$ = "#declare pointArray[" + n + "][1] = " + aScaleX$(i) + " ;"
n+1
EndIf
Next
WriteStringN(File, "", #PB_Ascii)
EndIf
; write PRISM Z
n=0
c=pointDataCount+1
s0$ = "//--- prism Z"
s1$ = "#declare " + fileName$ +"_prism_z ="
s2$ = "prism {"
s3$ = " linear_spline"
WriteStringN(File,Chr(13), #PB_Ascii)
s$ = " 0, 1, " + c + ","
WriteStringN(File,s$ , #PB_Ascii)
s$ = " <" + aPosX$(i) + "," + aPosZ$(i) + ">,"
If i = objectCount
s$ = " <" + aPosX$(i) + "," + aPosZ$(i) + ">"
EndIf
WriteStringN(File, s$, #PB_Ascii)
n+1
EndIf
Next
s$ = " <" + aPosX$(1) + "," + aPosZ$(1) + ">"
s1$ = "}"
EndIf
; write PRISM Y
n=0
c=pointDataCount+1
s0$ = "//--- prism Y"
s1$ = "#declare " + fileName$ +"_prism_y ="
s2$ = "prism {"
s$ = " <" + aPosX$(i) + "," + aPosY$(i) + ">,"
If i = objectCount
s$ = " <" + aPosX$(i) + "," + aPosY$(i) + ">"
EndIf
n+1
EndIf
Next
s$ = " <" + aPosX$(1) + "," + aPosY$(1) + ">"
s1$ = "}"
EndIf
; write Lathe
s0$ = "#declare " + fileName$ +"_lathe ="
s1$ = "lathe{ "
s2$ = " cubic_spline"
s3$ = " " + Str(pointDataCount) + ","
s4$ = " }"
; write Lathe header
WriteStringN(File, "//--- lathe", #PB_Ascii)
For i = 1 To objectCount-1
s0$ = " <" + aPosX$(i) + "," + aPosY$(i) + ">, "
Next
s0$ = " <" + aPosX$(objectCount) + "," + aPosY$(objectCount) + ">"
EndIf
; write Sweep Cubic
c=pointDataCount+2
s0$ = "#declare " + fileName$ + "_sweep_cubic ="
s1$ = "sphere_sweep {"
s3$ = " tolerance 0.000001"
s4$ = " }"
WriteStringN(File, "//--- cubic spline sweep", #PB_Ascii)
WriteStringN(File, "#declare sf=1;", #PB_Ascii)
WriteStringN(File, " " + c + ",", #PB_Ascii)
s0$ = " " + aPos_POV$(1) + "," + " " + aScaleX$(1) + "*sf, "
s0$ = " " + aPos_POV$(i) + "," + " " + aScaleX$(i) + "*sf, "
Next
s0$ = " " + aPos_POV$(objectCount) + "," + " " + aScaleX$(objectCount) +
"*sf"
EndIf
; write Sweep linear
c=pointDataCount+2
s0$ = "#declare " + fileName$ + "_sweep_linear ="
s2$ = " linear_spline"
s4$ = " }"
WriteStringN(File, "//--- linear spline sweep", #PB_Ascii)
Next
"*sf"
EndIf
;--- Plot spheres
s0$ = "#declare " + fileName$ + "_spheres ="
s1$ = "union {"
s2$ = " }"
WriteStringN(File, "//--- plotted spheres", #PB_Ascii)
s0$ = " sphere{<0,0,0>, " + aScaleX$(i) + " translate " + aPos_POV$(i)
Next
EndIf
;--- Plot cones
s0$ = "#declare " + fileName$ + "_cones ="
s1$ = "union {"
s2$ = " }"
WriteStringN(File, "//--- plotted cones", #PB_Ascii)
s0$ = " cone{" + aPos_POV$(i) + "," + aScaleX$(i) + "," +
aPos_POV$(i+1) + "," + aScaleX$(i+1) + "}"
Next
EndIf
;--- close file
CloseFile(File)
;--- Verbose message
s$ = fileName$ + ".inc created " + Chr(13)
s1$ = "" + pointDataCount + " points" + Chr(13)
s2$ = "- array added" + Chr(13)
s3$ = "- prism added" + Chr(13)
s4$ = "- lathe added" + Chr(13)
s5$ = "- cubic sweep added" + Chr(13)
s5$ = "- linear sweep added" + Chr(13)
s6$ = "- spheres added" + Chr(13)
s7$ = "- cones added" + Chr(13)
MessageRequester(".x3d to POV 0.5 m.miller 8.8.23",
s$+s1$+s2$+s3$+s4$+s5$+s6$+s7$, 0)
Else
MessageRequester("Info:", "canceled", 0)
EndIf
Download 'x3d_blender_points.pb.txt' (15 KB)
![](/i/fill.gif) |
