POV-Ray : Newsgroups : povray.text.scene-files : bounding box calculator Server Time
30 Mar 2026 15:57:28 EDT (-0400)
  bounding box calculator (Message 41 to 43 of 43)
Subject: Re: bounding box calculator
Date: 4 Oct 2020 07:15:01
Message: <web.5f79ad6734d8ef06f5e85bab0@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> find attached the second update of the 'Bounder'.
> things have changed a little.  now, if the object's BB is found to be "(near)
> optimal", the macro prints that and ends, otherwise, ie having some "slack", the
> macro prints the difference lines as before, plus the optimised extents and
> dimensions, as per Thomas's feedback.
> also new, if "slack" is reported, two variables with the differences from the
> BB's min/max extents are declared, to allow use of the info from in-scene.
> after 'Bounder' has run, one can for instance:
> #ifdef(Bounder_min_diff)
>   // do something
> #end
> so.  version 3.  fingers crossed.
posting the 4th, and probably final, version of the 'Bounder', which ties up a
couple of loose ends.
an addition to the code removes existing 'Bounder_{min,max}_diff' variables,
whenever the macro is run.  this means that if you call the macro multiple
times, you can be confident that existing variables were created by the most
recent call.  this then allows automating the (re)bounding of objects, as
illustrated in the code below.
second, I added a thanks to TdG, whose input was (is) appreciated.  kept
forgetting.  :-(
enjoy, jr.
jr@crow:5:bounder$ c### [at] bt1apov
#version 3.8;
global_settings {assumed_gamma 1}
background {color srgbt 0}
#ifndef (global.I)
  #declare I = 0;
#declare R = <20,20,20>;
#switch (I)
  #case (0)
    #debug concat("cylinder","\n")
    #declare O = cylinder {
      0, 1, .25
      translate 5
  #break
  #case (1)
    #debug concat("box","\n")
    #declare O = box {
      0, 1
  #break
  #case (2)
    #debug concat("sphere","\n")
    #declare O = sphere {
      0, 1
  #break
  #case (3)
    #debug concat("blob","\n")
    #declare O = blob {
      threshold .6
      sphere {0, 1, 1}
      scale 2
    #declare R = <25,25,25>;
  #break
  #case (4)
    #debug concat("superellipsoid","\n")
    #declare O = superellipsoid {
      <.5,3.5>
      translate 5
  #break
  #case (5)
    #debug concat("superellipsoid rotated","\n")
      <.5,3.5>
      rotate 45
      translate 5
  #break
  #else
    #error concat("oops, no object for I=",str(I,0,0),".\n")
#include "bounder.inc"
Bounder(O,R)
#ifdef (Bounder_min_diff)
  #local nlb_ = min_extent(O) + Bounder_min_diff;
  #local nub_ = max_extent(O) - Bounder_max_diff;
  #declare O = object {
    O
    clipped_by {box {nlb_, nub_}}
    bounded_by {clipped_by}
Bounder(O,R)
jr@crow:6:bounder$ povparse bt1a.pov declare=I=5
Persistence of Vision(tm) Ray Tracer Version 3.8.0-alpha.10064268.unofficial
==== [Parsing...] ==========================================================
----------[Bounder info]------------------------------------------------
  resolutions (per POV unit): <25, 25, 25>
       min_extent "as is" BB: <3.499850, 3.499850, 3.292722>
       max_extent "as is" BB: <6.500150, 6.500150, 6.707277>
       BB aligned dimensions: <3.000300, 3.000300, 3.414555>
    'X' axis scan resolution: 75
              scans per face: 6375
         scan axis increment: 0.04000400
          face col increment: 0.04017124
          face row increment: 0.04000400
                           -: ...scanning...
Parsing 5069K tokensParsing 10221K tokens
              inside() calls: 280500
    'Y' axis scan resolution: 75
          face col increment: 0.04000400
          face row increment: 0.04017124
                           -: ...scanning...
Parsing 15363K tokensParsing 20530K tokens
              inside() calls: 153000
    'Z' axis scan resolution: 85
              scans per face: 5625
         scan axis increment: 0.04017124
                           -: ...scanning...
Parsing 25672K tokensParsing 30802K tokens
              inside() calls: 225000
  object bounding box has at least 5% "slack".
      difference from BB min: <0.800080, 0.400040, 0.723082>
      difference from BB max: <0.800080, 0.400040, 0.723082>
     min_extent optimised BB: <4.299930, 3.899890, 4.015805>
     max_extent optimised BB: <5.700070, 6.100110, 5.984195>
     BB optimised dimensions: <1.400140, 2.200220, 1.968391>
       min_extent "as is" BB: <4.299930, 3.899890, 4.015805>
       max_extent "as is" BB: <5.700070, 6.100110, 5.984195>
       BB aligned dimensions: <1.400140, 2.200220, 1.968391>
    'X' axis scan resolution: 35
              scans per face: 2695
                           -: ...scanning...
              inside() calls: 10780
    'Y' axis scan resolution: 55
              scans per face: 1715
                           -: ...scanning...
              inside() calls: 6860
    'Z' axis scan resolution: 49
              scans per face: 1925
                           -: ...scanning...
              inside() calls: 7700
  object bounding box is (near) optimal.
File 'bt1a.pov' line 295: Parse Warning: No objects in scene.
==== [Rendering...] ========================================================
Rendered 1024 of 1024 pixels (100%)
POV-Ray finished
jr@crow:7:bounder$ povparse bt1a.pov declare=I=0
cylinder
  resolutions (per POV unit): <20, 20, 20>
       min_extent "as is" BB: <4.750000, 4.750000, 4.711325>
       max_extent "as is" BB: <6.250000, 6.250000, 6.288675>
       BB aligned dimensions: <1.500000, 1.500000, 1.577350>
    'X' axis scan resolution: 30
              scans per face: 960
         scan axis increment: 0.05000000
          face col increment: 0.04929219
          face row increment: 0.05000000
                           -: ...scanning...
              inside() calls: 3840
    'Y' axis scan resolution: 30
              scans per face: 960
          face col increment: 0.05000000
          face row increment: 0.04929219
                           -: ...scanning...
    'Z' axis scan resolution: 32
              scans per face: 900
         scan axis increment: 0.04929219
                           -: ...scanning...
              inside() calls: 5400
  object bounding box is good, less than 5% "slack".
      difference from BB min: <0.000000, 0.000000, 0.049292>
      difference from BB max: <0.000000, 0.000000, 0.049292>
     min_extent optimised BB: <4.750000, 4.750000, 4.760617>
     max_extent optimised BB: <6.250000, 6.250000, 6.239383>
     BB optimised dimensions: <1.500000, 1.500000, 1.478766>
       min_extent "as is" BB: <4.750000, 4.750000, 4.760617>
       max_extent "as is" BB: <6.250000, 6.250000, 6.239383>
       BB aligned dimensions: <1.500000, 1.500000, 1.478766>
              scans per face: 900
                           -: ...scanning...
              inside() calls: 3600
              scans per face: 900
                           -: ...scanning...
    'Z' axis scan resolution: 30
              scans per face: 900
                           -: ...scanning...
Download 'bounder.inc.txt' (9 KB)
Date: 5 Oct 2020 00:35:01
Message: <web.5f7aa1c334d8ef06d98418910@news.povray.org>
I'm coming late to this discussion, sorry that I never saw it earlier.
This looks useful for my current 'city buildings' scene, particularly for my
'rooftop greebles' and their correct placement.
Thanks for all the hard work (and Thomas too for his earlier testing and
suggestions.)
Date: 12 Jul 2022 08:35:00
Message: <web.62cd696434d8ef061be3cd4b6cde94f1@news.povray.org>
hi,
posting the 5th, and probably final, version :-) of the macro.  a simple demo
scene is included, it uses the 'declare=I=N' syntax, where N is from '0' to '5'.
it's been a while, so what happened?  ;-)
enjoy, jr.
Download 'bounder.zip' (5 KB)
