POV-Ray : Newsgroups : povray.text.scene-files : A little something fun to play with Server Time
14 May 2025 19:14:34 EDT (-0400)
  A little something fun to play with (Message 1 to 9 of 9)
Subject: A little something fun to play with
Date: 18 Apr 2001 16:08:24
Message: <slrn9drt1q.d97.ron.parker@fwi.com>
A little something I've been messing around with... try different numbers
for the 91671 in the second-to-last line.  Requires some flavor of MegaPOV
(though if you don't have MegaPOV you can still play... just delete the
pigment called C and replace the [.05 C] with [.05 rgb 1] )
#macro Arabesque( Param )
  #declare Sd = seed(Param);
  #declare Rv = <rand(Sd),rand(Sd),rand(Sd)>*500;
  #local C=pigment{crackle solid
    color_map{
      [1/12 red 1]
      [1/12 red 1 green 1][3/12 red 1 green 1]
      [3/12 green 1][5/12 green 1]
      [5/12 green 1 blue 1][7/12 green 1 blue 1]
      [7/12 blue 1][9/12 blue 1]
      [9/12 blue 1 red 1][11/12 blue 1 red 1]
      [11/12 red 1]
  #local G=pigment{crackle
    pigment_map{[.05 rgb 0][.05 C]}
    scale .2
    translate Rv
    warp {repeat z flip z}
  #local B=pigment{
    radial
    pigment_map{
      #local i=0;
      #while(i<6)
        [i/6 G rotate(30+60*i)*y]
        [(i+1)/6 G rotate(30+60*i)*y]
        #local i=i+1;
  #local T2=sqrt(3)/2;
  radial
  pigment_map{
    [1/3 B translate<.5,0,-T2>]
    [1/3 B translate<-1,0,0>]
    [2/3 B translate<-1,0,0>]
    [2/3 B translate<.5,0,T2>]
  translate x
  warp{repeat 1.5*x flip x}
  warp{repeat .5*sqrt(3)*z flip z}
plane {y 0 pigment {Arabesque(91671)} finish {ambient 1}}
camera {location 5*y sky z look_at 0}
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Subject: Re: A little something fun to play with
Date: 18 Apr 2001 17:10:07
Message: <Xns9087EC0547A6Fseed7@povray.org>
Ahhh, I like! It will be disected first thing tomorrw morning.
A very small rotation around x or z gives a nice "fading" effect.
Ingo
Date: 18 Apr 2001 17:47:25
Message: <slrn9ds2rg.dd2.ron.parker@fwi.com>
Hey, that's pretty cool.  Now I know why I keep posting stuff like this
here; it always seems to grow.
Try replacing this bit:
      #while(i<6)
        #local i=i+1;
with this:
      #while(i<12)
        [i/12 G rotate(15+30*i)*y]
        [(i+1)/12 G rotate(15+30*i)*y]
        #local i=i+1;
Date: 18 Apr 2001 22:31:46
Message: <3ADE4E48.B82EAEF5@pacbell.net>
I'm not sure I can make it grow but I am sure I can damage it :)
Ken Tyler
Date: 18 Apr 2001 23:22:30
Message: <3ADE5A2D.15C88B83@pacbell.net>
Ok, I damaged it...
P.S. A little rotation and a bit of turbulence makes a passing chipboard
pigment for the wood crafters in the group.
#declare P1=pigment { wood turbulence .05
             color_map {
                         [ 0 rgb<.35,.20,.15>]
                         [.5 rgb<.50,.35,.23>]
                         [ 1 rgb<.35,.20,.15>]
#declare P2=pigment { wood turbulence .05
             color_map {
                         [ 0 rgb<.45,.30,.25>]
                         [.5 rgb<.60,.45,.33>]
                         [ 1 rgb<.45,.30,.25>]
#declare P3=pigment { wood turbulence .05
             color_map {
                         [ 0 rgb<.55,.40,.35>]
                         [.5 rgb<.70,.55,.43>]
                         [ 1 rgb<.55,.40,.35>]
#declare P4=pigment { wood turbulence .05
             color_map {
                         [ 0 rgb<.65,.50,.45>]
                         [.5 rgb<.80,.65,.53>]
                         [ 1 rgb<.65,.50,.45>]
#declare P5=pigment { wood turbulence .05
             color_map {
                         [ 0 rgb<.75,.60,.55>]
                         [.5 rgb<.90,.75,.63>]
                         [ 1 rgb<.75,.60,.55>]
#declare P6=pigment { wood turbulence .05
             color_map {
                         [ 0 rgb<.85,.70,.65>]
                         [.5 rgb<.90,.85,.73>]
                         [ 1 rgb<.85,.70,.65>]
pigment_map{
      [1/12  P1 scale .10]
      [1/12  P1 scale .10]
      [3/12  P2 scale .10]
      [3/12  P2 scale .10]
      [5/12  P3 scale .10]
      [5/12  P3 scale .10]
      [7/12  P4 scale .10]
      [7/12  P4 scale .10]
      [9/12  P5 scale .10]
      [9/12  P5 scale .10]
      [11/12 P6 scale .10]
    scale .2
    translate Rv
  #local B=pigment{
    radial
    pigment_map{
      #local i=0;
      #while(i<6)
        #local i=i+1;
  radial
  pigment_map{
  translate x
plane {y 0 pigment {Arabesque(91671) turbulence 0 rotate 0} finish {ambient 1}}
Date: 19 Apr 2001 04:26:30
Message: <MPG.1548bfb6c0e6737a989744@NEWS.POVRAY.ORG>
In article <slr### [at] fwicom>, Ron Parker says...
It's neat! I don't grasp the code, but why does the pattern widen
towards the left?
Regards,  Sander
Date: 19 Apr 2001 05:09:25
Message: <3adeab44@news.povray.org>
For a nice variation, try replacing the plane with this one:
plane
{ y 0 pigment {Arabesque(91671) warp{black_hole 0,3 strength -1}}
  finish {ambient 1}}
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 19 Apr 2001 07:59:14
Message: <3aded312@news.povray.org>
Very, very clever.  I like it a lot.  Looking over the code, I can see how
it's done, but not how you came up with it.  Changing from a material map to
a pigment map could easily allow for all kinds of tiling patterns.
Now I want to do an Arabian Nights style image.... ;)
Geoff
Date: 19 Apr 2001 09:21:00
Message: <slrn9dtpht.efv.ron.parker@fwi.com>
Well, the inspiration came from a paper I ran across, about a third of the
way down this page:
http://www.iro.umontreal.ca/~ostrom/publications/abstracts.html
under the heading "Mathematical Tools for Computer-Generated Ornamental
Patterns."
The actual implementation was ripped off from my hextiles pattern of long
ago, which I'd been working on this week for unspecified reasons.  The
combination of the two gave rise to this.
