Fade out of a grid with a semitransparent mask.
See the TRON Game Grid thread in p.newuser
Sebastian
#include "screen.inc"
#declare CLOCK = clock;
* Scene control settings
#declare ANIMATION = off;
#declare USE_PHOTONS = off;
#declare USE_RADIOSITY = off;
* Scene parameters
#declare G_W = 35; // Width and depth for detailed ground
* Global settings
global_settings {
charset utf8
max_trace_level 16
assumed_gamma 2.2
#if (USE_RADIOSITY)
radiosity {
pretrace_start 0.08
pretrace_end 0.04
count 35
nearest_count 5
error_bound 1.8
recursion_limit 1
low_error_factor 0.5
gray_threshold 0.0
minimum_reuse 0.015
brightness 1
adc_bailout 0.01/2
#if (USE_PHOTONS)
photons {
count 20000
autostop 0
jitter 0
background { rgb <1, 1, 1> }
* Camera
#declare cam_pos = <-5, 4, -13>;
#declare cam_look_at = <1, 1.0, 0>;
#declare cam_angle = 45;
#if(ANIMATION)
#declare cam_pos = vaxis_rotate(cam_pos, <0,1,0>, CLOCK*360);
#declare cam_look_at = vaxis_rotate(cam_look_at, <0,1,0>, CLOCK*360);
Set_Camera(cam_pos, cam_look_at, cam_angle) // set location, look_at and angle
Set_Camera_Aspect(16,9) // set width in relation to height
Set_Camera_Sky(<0,1,0>) // set the sky vector
* Static lightsources
light_source {
<100, 200, -100> rgb <1, 1, 1>
fade_distance 800
fade_power 2
* Objects
#declare O_Ground_Plane =
plane { y, 0 }
* Textures
// Not used but intended for to be the
// center point of the fade-out mask
#declare ground_camera_focus =
trace(
O_Ground_Plane,
cam_pos,
vnormalize(cam_look_at - cam_pos)
#declare grid_line_width = 0.1;
#declare grid_line_col = rgb <0.95, 0.95, 1.00>;
#declare grid_area_col = rgbt <0.00, 0.00, 0.10, 1.0>;
#declare grid_fade_disc_rad = 40.0;
// #declare grid_fade_disc_pos = ground_camera_focus;
#declare grid_fade_disc_pos = <cam_pos.x, 0, cam_pos.z>;
#declare P_Lines =
gradient x
color_map {
[0.0 grid_line_col]
[grid_line_width grid_line_col]
[grid_line_width grid_area_col]
[1.0 grid_area_col]
#declare T_Grid =
texture { pigment {Black} }
texture { pigment {P_Lines} }
texture { pigment {P_Lines rotate 90*y} }
#declare T_Actual_Grid =
texture { T_Grid finish {ambient 0.1}}
cylindrical
color_map {
[0.0 rgb grid_line_col]
[1.0 rgbt 1.0]
scale grid_fade_disc_rad
translate grid_fade_disc_pos
* Scene Object collection
sphere {
0, 1/4
pigment {Red}
object {
O_Ground_Plane
T_Actual_Grid
#declare w_dist = 50;
#declare O_Wall =
plane {
-x, 0
pigment {hexagon rgb 1.0, rgb 0.8, rgb 0.6 rotate 90*z}
finish {ambient 0.45}
translate w_dist*x
no_shadow
object { O_Wall }
object { O_Wall rotate 90*y}
object { O_Wall rotate 180*y}
object { O_Wall rotate 270*y}
