POV-Ray : Newsgroups : povray.text.scene-files : Bevelled text macro Server Time
12 Oct 2025 14:44:27 EDT (-0400)
  Bevelled text macro (Message 1 to 5 of 5)
Subject: Bevelled text macro
Date: 20 Dec 2000 16:56:31
Message: <chrishuff-CF42D9.16573920122000@news.povray.org>
This version is slightly more complete than the version posted in
povray.text.scene-files.
#macro ShearTrans(A, B, C)
    matrix <    A.x, A.y, A.z,
                B.x, B.y, B.z,
                C.x, C.y, C.z,
                0, 0, 0>
#macro BevelText(Font, String, Cuts, BevelAng, BevelDepth, Depth, Offset)
    #local BBox = text {ttf Font, String Depth, Offset}
    union {
        text {ttf Font, String Depth-BevelDepth, Offset}
        intersection {
            #local J=0;
            #while(J<Cuts)
                #local A = 2*pi*J/(Cuts);
                #local CA = cos(radians(BevelAng));
                #local SA = sin(radians(BevelAng));
                text {ttf Font, String BevelDepth, Offset
                    translate -z*(BevelDepth+J*0.0001)
                    ShearTrans(x, y, < cos(A)*SA, sin(A)*SA, CA>/CA)
                #local J=J+1;
        translate z*BevelDepth
        bounded_by {box {min_extent(BBox), max_extent(BBox)}}
Font: the name of the font file.
String: the text of the text object.
Cuts: the number of intersections to use to bevel the edges, more is
better, but slower. You can use any positive number, but multiples of 4
work well.
BevelAng: the angle of the bevel.
BevelDepth: the distance the bevel extends front-to-back.
Depth: the total front-to-back thickness of the final object.
Offset: the offset vector of the text object. Using an offset along the
z-axis won't work, but other offsets should be fine.
Note that this macro doesn't work well with sharp corners, though using
more cuts will reduce the problems.
Christopher James Huff
Subject: Re: Bevelled text macro
Date: 24 Dec 2000 12:37:12
Message: <3a463448@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-CF42D9.16573920122000@news.povray.org...
With a slight modification, this macro works with any object, not just
text... Excellent macro, Chris!
Dave
Date: 24 Dec 2000 14:17:59
Message: <chrishuff-C90F05.14191224122000@news.povray.org>
In article <3a463448@news.povray.org>, "Dave Blandston"
Well, depends on what you mean by "bevelling" for those other
objects...a bevelled box would require very different calculations than
a bevelled cylinder , and there are far more efficient ways of doing
those objects than shearing and CSG'ing a bunch of pieces(and how do you
bevel the edges of a sphere or torus?). Also, your object needs to be
aligned so that the part being bevelled is up against a plane and no
other parts are on the other side or within the bevelling depth of that
plane. This is what kept me from writing a general "BevelObject()" macro.
Date: 24 Dec 2000 20:04:10
Message: <3a469d0a@news.povray.org>
news:chrishuff-C90F05.14191224122000@news.povray.org...
Ummm... yeah, that's what I meant - I used the macro to bevel a frame around
some text, and it works very well. I'll put up another picture in the images
group to illustrate.
-Dave
Date: 24 Dec 2000 21:41:42
Message: <chrishuff-CBA501.21425724122000@news.povray.org>
In article <3a469d0a@news.povray.org>, "Dave Blandston"
> around some text, and it works very well. I'll put up another picture
> in the images group to illustrate.
I see...I was thinking in more 3D terms, where a bevelled cylinder would
be a short cylinder and two capping cones, and a bevelled box would have
bevels on all 12 edges. For stuff aligned on a plane, like this, it will
work fine.
