POV-Ray : Newsgroups : povray.text.scene-files : Op Art Image Server Time
23 Jan 2025 19:54:55 EST (-0500)
  Op Art Image (Message 1 to 1 of 1)
Subject: Op Art Image
Date: 16 Aug 2001 13:11:09
Message: <Y9wdyBA9U$e7EwV8@econym.demon.co.uk>
/* OpArt.pov
Render the image to a size that fills your screen (don't worry, it's
pretty quick).
Your eye will want to find simple patterns in the arrangement but the
arrangement is derived from a bozo pigment pattern which isn't quite
simple enough for the eye to cope with.
Why not try some variations, such as:-
   Using an orhtographic camera (simplifies the image)
   Using different pigment pattern
   Using V to affect the size of the spots
         e.g.    scale (1+V)/2
   Using different shaped spots
The scene can be animated. As 'clock' varies, the control information
is obtained from a different Y-plane cutting through the bozo pattern.
So the image changes smoothly, but non cyclically, as clock changes.
camera { location  <0, 6, 0> look_at <0, 0, 0>}
light_source {<40,100,40> colour rgb 1.5}
background {rgb 1}
#declare p = pigment {
  bozo scale 3
  colour_map {[0 rgb 0.9][1 rgb 0.2]}
#declare D=0.25; // separation of spots
#declare spot=box{-0.3*D,0.3*D pigment {rgb 0} no_shadow}
#declare X=-5;
#while (X<5)
  #declare Z=-4;
  #while (Z<4)
    #declare V = vlength(eval_pigment(p,<X,-1+clock*10,Z>));
    object {spot
       rotate <0,180*V,0>
       translate<X,-1,Z>
    #declare Z=Z+D;
  #declare X=X+D;
//Mike Williams
