![](/i/fill.gif) |
/* OpArt.pov
Render the image to a size that fills your screen (don't worry, it's
pretty quick).
Your eye will want to find simple patterns in the arrangement but the
arrangement is derived from a bozo pigment pattern which isn't quite
simple enough for the eye to cope with.
Why not try some variations, such as:-
Using an orhtographic camera (simplifies the image)
Using different pigment pattern
Using V to affect the size of the spots
e.g. scale (1+V)/2
Using different shaped spots
The scene can be animated. As 'clock' varies, the control information
is obtained from a different Y-plane cutting through the bozo pattern.
So the image changes smoothly, but non cyclically, as clock changes.
camera { location <0, 6, 0> look_at <0, 0, 0>}
light_source {<40,100,40> colour rgb 1.5}
background {rgb 1}
#declare p = pigment {
bozo scale 3
colour_map {[0 rgb 0.9][1 rgb 0.2]}
#declare D=0.25; // separation of spots
#declare spot=box{-0.3*D,0.3*D pigment {rgb 0} no_shadow}
#declare X=-5;
#while (X<5)
#declare Z=-4;
#while (Z<4)
#declare V = vlength(eval_pigment(p,<X,-1+clock*10,Z>));
object {spot
rotate <0,180*V,0>
translate<X,-1,Z>
#declare Z=Z+D;
#declare X=X+D;
//Mike Williams
![](/i/fill.gif) |
