POV-Ray : Newsgroups : povray.text.scene-files : Gamut-mapped spectral rendering Server Time
4 Mar 2026 13:26:14 EST (-0500)
  Gamut-mapped spectral rendering (Message 1 to 2 of 2)
Subject: Gamut-mapped spectral rendering
Date: 8 May 2017 13:14:57
Message: <5910a791$1@news.povray.org>
I have made two sets of changes to the file SpectralComposer.pov in
Lilysoft's spectral rendering rig.
The first set of changes was converting it to a proper include file.  In
its standard form, SpectralComposer.pov must be edited every time you
create a new scene, or even render the same scene with different
parameters; and the final output image must be renamed.  With my
changes, you can #declare the scene name and other parameters in your
scene file, and then #include the composer file without having to edit
it every time.
The second set of changes was to use gamut mapping to deal with colors
that are too rich for standard computer monitors.
So as not to step on Ive's toes, I am only posting the changes I made,
and not the entire file.
Change 1:  Insert the following comments under the header block:
----------[BEGIN CODE]----------
// Modifications by Richard Callwood III:
// 2013-Nov-26  Converted to parameter-driven .inc file.
// 2013-Nov-26  Converted npow() to NPow().
// 2013-Dec-02  Does gamut mapping (CIE.inc's method 2).
// 2013-Dec-11  Corrected a grammatical error.
-----------[END CODE]-----------
Change 2:  Replace the FName section with the following.  (Note that,
notwithstanding how it may appear in your newsreader, the #error string
should be all on one line.)
// FName: change this to match the name of your set of 36 spectral files
//#declare FName = "";
#ifndef (FName)
   #error "String FName must be set to the name of your 36 .exr files
(without the frame number and \".exr\" extension)."
Changes 3 - 10:  Replace the respective parameter declarations with the
following lines:
#ifndef (Exposure) #declare Exposure = 1.0; #end
#ifndef (Luminance) #declare Luminance = 1.0; #end
#ifndef (Exponent) #declare Exponent = 1.0; #end
#ifndef (Saturation) #declare Saturation = 1.0; #end
#ifndef (Whitepoint) #declare Whitepoint = 6504; #end
#ifndef (HDR_max) #declare HDR_max = 25; #end
#ifndef (HDR_min) #declare HDR_min = -1.0; #end
#ifndef (Use_AdobeRGB) #declare Use_AdobeRGB = off; #end
Change 11:  Search and replace all instances of npow with NPow, per
unenforced POV-Ray recommendation.
Change 12:  This section does the gamut mapping.  Replace the line "//
our canvas" and the following plane object with the following:
// pigment at full dynamic range
#declare p_Full_color = pigment
{ average
   pigment_map
     [ function
       { NPow
         (   CM[0][0] * CMF_x(x,y,z)
           + CM[0][1] * CMF_y(x,y,z)
           + CM[0][2] * CMF_z(x,y,z)
         ) * E + M
       color_map { [0 rgb <L,0,0>] [1 rgb <H,0,0>] }
     [ function
       { NPow
         (   CM[1][0] * CMF_x(x,y,z)
           + CM[1][1] * CMF_y(x,y,z)
           + CM[1][2] * CMF_z(x,y,z)
         ) * E + M
       color_map { [0 rgb <0,L,0>] [1 rgb <0,H,0>] }
     [ function
       { NPow
         (   CM[2][0] * CMF_x(x,y,z)
           + CM[2][1] * CMF_y(x,y,z)
           + CM[2][2] * CMF_z(x,y,z)
         ) * E + M
       color_map { [0 rgb <0,0,L>] [1 rgb <0,0,H>] }
#declare fn_Full_color = function { pigment { p_Full_color } }
// gamut map (See MapGamut() in CIE.inc)
#declare WtPt = xyz2RGB (ColSys2xyz (3));
#declare WtR = WtPt.red;
#declare WtG = WtPt.green;
#declare WtB = WtPt.blue;
#declare fn_P = function
{ select
   ( 0.5 - (x <= y & x <= z),
     WtR / (WtR - x),
     select
     ( 0.5 - (y <= x & y <= z),
       WtG / (WtG - y),
       WtB / (WtB - z)
#declare fn_Red = function
{ select
   ( min(x,y,z), min (max (WtR + fn_P(x,y,z) * (x - WtR), 0), 1), min (x, 1)
#declare fn_Green = function
{ select
   ( min(x,y,z), min (max (WtG + fn_P(x,y,z) * (y - WtG), 0), 1), min (y, 1)
#declare fn_Blue = function
{ select
   ( min(x,y,z), min (max (WtB + fn_P(x,y,z) * (z - WtB), 0), 1), min (z, 1)
// our canvas
plane
{ -z, 0
   pigment
   { average pigment_map
     { [ function
         { fn_Red
           ( fn_Full_color(x,y,z).red,
             fn_Full_color(x,y,z).green,
             fn_Full_color(x,y,z).blue
         color_map { [0 rgb 0] [1 red 3] }
       [ function
         { fn_Green
         color_map { [0 rgb 0] [1 green 3] }
       [ function
         { fn_Blue
         color_map { [0 rgb 0] [1 blue 3] }
   finish { ambient 0 diffuse 0 emission 1 }
I adapted the formula from CIE.inc's method 2, but for some reason, the
results of the gamut mapping appear more like method 3.  I haven't
figured out the reason for this.
Because the gamut mapping is slow, I actually keep two versions of the
file: one with all the changes (which I call SpectralComposer-gm2.inc);
and one with just the #ifndefs and no gamut-mapping changes (which I
call SpectralComposer.inc).
My typical usage is thus:
----------[BEGIN EXAMPLE]----------
#version 3.7;
#ifndef (Preview) #declare Preview = no; #end
#if (clock_on | Preview)
   #include "spectral.inc"
   // Define the scene here.
#else
   #declare FName = "MySceneFileName"
   #include "SpectralComposer-gm2.inc"
-----------[END EXAMPLE]-----------
Subject: Re: Gamut-mapped spectral rendering
Date: 15 Feb 2023 16:33:14
Message: <63ed4f9a@news.povray.org>
> [snip]
SpectralRender has recently been dedicated to the public domain, or the
legal equivalent thereof in your country.  I am therefore releasing my
complete modified files:
https://github.com/CousinRicky/POV-SpectralRender-mods
Have fun!
