POV-Ray : Newsgroups : povray.text.scene-files : CIELUV Server Time
4 Mar 2026 13:25:43 EST (-0500)
  CIELUV (Message 1 to 7 of 7)
Subject: CIELUV
Date: 6 Dec 2016 02:05:34
Message: <5846633e@news.povray.org>
I am having trouble rendering the attached scene without artifacts and
gaps in the isosurface. I already increased the scale of the scene by
200 and the max_gradient of the isosurface to 100. Anyone have any tips?
Mike
Download 'cieluv_color_solid_cube_isosurface.pov.txt' (13 KB)
Subject: Re: CIELUV
Date: 6 Dec 2016 16:51:40
Message: <584732ec$1@news.povray.org>
> Mike
If you get an error about the missing image maps, you can ignore it and
delete the polygons.
Mike
Subject: Re: CIELUV
Date: 6 Dec 2016 22:48:26
Message: <5847868a$1@news.povray.org>
> Mike
I tried with Wikipedia's conversion formula as well, with no difference
in the render.
// Wikipedia calculations
#declare funcLUV2XYZu = function(L,U,V) {U/13/L + uPrime}
#declare funcLUV2XYZv = function(L,U,V) {V/13/L + vPrime}
#declare funcLUV2XYZa2 = function(L,U,V) {XYZWhiteReference2 * select(8
- L, pow((L + 16)/116, 3), L * pow(3/29, 3))}
#declare funcLUV2XYZa1 = function(L,U,V) {funcLUV2XYZa2(L,U,V) * 9/4 *
funcLUV2XYZu(L,U,V)/funcLUV2XYZv(L,U,V)}
#declare funcLUV2XYZa3 = function(L,U,V) {funcLUV2XYZa2(L,U,V) * (12 - 3
* funcLUV2XYZu(L,U,V) - 20 * funcLUV2XYZv(L,U,V))/4/funcLUV2XYZv(L,U,V)}
Mike
Subject: Re: CIELUV
Date: 6 Dec 2016 23:55:18
Message: <58479636@news.povray.org>
Am 06.12.2016 um 08:05 schrieb Mike Horvath:
You seem to be running into /some/ kind of problem when the RGB values
get excessively low.
Clipping the C parameter of the fD function to some near-zero negative
value seems to do the trick:
    #declare fClip = function(X,A) {select(X-A,A,X)}
    #declare fD = function(C) {abs(fClip(C,-0.1)-0.5)-0.5}
This lets you get away with a max_gradient of 20.
(You still have a coincident surfaces problem between the isosurface and
the box, but I guess you can figure that one out yourself.)
Subject: Re: CIELUV
Date: 7 Dec 2016 16:19:59
Message: <58487cff$1@news.povray.org>
That helped, thanks. I still had to raise max_gradient to get rid o
every artifact though.
Mike
Subject: Re: CIELUV
Date: 7 Dec 2016 20:41:38
Message: <5848ba52$1@news.povray.org>
I changed the camera angle and the problem reappeared.
camera
//	#local cam_distance	= 40;	// render at 8192x8192
//	#local cam_planesize	= 4;	// render at 8192x8192
	#local cam_distance	= 17;
	#local cam_planesize	= 1.7;
//	#local cam_distance	= 20;	// render at 4096x4096
//	#local cam_planesize	= 2;	// render at 4096x4096
	#local cam_aspectratio	= image_width/image_height;
//	orthographic
	location	-z * cam_distance
	direction	+z * cam_distance
	right		+x * cam_planesize*cam_aspectratio
	up		+y * cam_planesize
	rotate		+x * asind(tand(30))
//	rotate		+x * 90
	rotate		-y * 045
//	rotate		+y * 180
	rotate		+y * RotateAmount
	translate	1/2
	scale		ScaleAmount
max_gradient is set to 200, and I am using your revised fD function.
Mike
Subject: Re: CIELUV
Date: 7 Dec 2016 22:43:07
Message: <5848d6cb$1@news.povray.org>
> camera
> //    orthographic
> //    rotate        +x * 90
>     rotate        -y * 045
> //    rotate        +y * 180
>     translate    1/2
>     scale        ScaleAmount
> Mike
And seen from directly above the isosurface disappears completely.
Mike
