POV-Ray : Newsgroups : povray.text.scene-files : L*C*h(uv) functions Server Time
19 Jul 2026 09:07:00 EDT (-0400)
  L*C*h(uv) functions (Message 17 to 26 of 26)
Subject: Re: L*C*h(uv) functions
Date: 22 Nov 2016 02:45:52
Message: <5833f7b0$1@news.povray.org>
On 11/22/2016 2:44 AM, clipka wrote:
> Am 22.11.2016 um 08:33 schrieb Mike Horvath:
>>>     convertLCH2RGB_R(y*200-100,sqrt(x*x+z*z)*100,atan2(x/z)*pi/180)
>> THANK YOU!!
>> However atan2 requires two parameters and your math only has one.
> Sorry, try atan2(x,z).
Here is the whole file again with your changes. The shape I get when I
render is that of a pointy cap. I don't know if that's correct or not.
Mike
Download 'utf-8' (7 KB)
Date: 22 Nov 2016 03:31:26
Message: <5834025e$1@news.povray.org>
Am 22.11.2016 um 08:45 schrieb Mike Horvath:
>>> THANK YOU!!
How would I know -- I'm not familiar with that colour model.
Now you need to intersect that shape with the five others -- or use the
combined function:
    min(
      convertLCH2RGB_R(y*200-100,sqrt(x*x+z*z)*100,atan2(x,z)*pi/180),
      convertLCH2RGB_G(y*200-100,sqrt(x*x+z*z)*100,atan2(x,z)*pi/180),
      convertLCH2RGB_B(y*200-100,sqrt(x*x+z*z)*100,atan2(x,z)*pi/180),
      1-convertLCH2RGB_R(y*200-100,sqrt(x*x+z*z)*100,atan2(x,z)*pi/180),
      1-convertLCH2RGB_G(y*200-100,sqrt(x*x+z*z)*100,atan2(x,z)*pi/180),
      1-convertLCH2RGB_B(y*200-100,sqrt(x*x+z*z)*100,atan2(x,z)*pi/180)
should do the job, I think.
Date: 22 Nov 2016 03:43:51
Message: <58340547$1@news.povray.org>
On 11/22/2016 3:31 AM, clipka wrote:
>     min(
I think the last parameter should be atan2(x,z)*180/pi because atan2
returns radians and convertLCH2RGB_R expects degrees.
Also, here's a rough approximation of what the surface should look like.
https://commons.wikimedia.org/wiki/File:Cielch_color_solid_cylinder.png
But with smooth curves instead of blocky sections.
Mike
Date: 22 Nov 2016 03:44:21
Message: <58340565$1@news.povray.org>
>     min(
Forgot to say that the above just results in a cube.
Mike
Date: 22 Nov 2016 04:44:39
Message: <58341387$1@news.povray.org>
Am 22.11.2016 um 09:43 schrieb Mike Horvath:
>>     min(
I guess you're right about this one.
Date: 22 Nov 2016 19:59:20
Message: <5834e9e8$1@news.povray.org>
>>>     min(
I am also not sure if using atan2 is good, since that only covers 90
degrees, whereas the hue circle must use all 360 degrees.
Mike
Date: 22 Nov 2016 20:11:33
Message: <5834ecc5@news.povray.org>
>>>>     min(
> Mike
Sorry. Disregard that. It works.
Mike
Date: 22 Nov 2016 20:53:03
Message: <5834f67f$1@news.povray.org>
Am 23.11.2016 um 02:11 schrieb Mike Horvath:
>> Mike
That's the fun thing about `atan2(a,b)`: In contrast to `atan(a/b)` it
doesn't lose the information about the quadrant; it also avoids the
singularity at b=0 (provided a<>0).
Date: 23 Nov 2016 02:47:09
Message: <5835497d$1@news.povray.org>
> combined function:
>     min(
Using "min" all I got was a cube. Switching to "max" instead, I got a
shape... of some sort. I'm not sure it's the correct one. Check the
thread in p.b.i and tell me if the images show the same object.
http://news.povray.org/583548b6%40news.povray.org
Mike
Date: 23 Nov 2016 02:48:47
Message: <583549df$1@news.povray.org>
I've attached the latest version of the script.
Mike
Download 'cielch_color_solid_cylinder_isosurface.pov.txt' (9 KB)
