POV-Ray : Newsgroups : povray.text.scene-files : edge_pigment02.inc (a proximity pattern) Server Time
23 Nov 2026 03:24:03 EST (-0500)
  edge_pigment02.inc (a proximity pattern) (Message 1 to 14 of 14)
Subject: edge_pigment02.inc (a proximity pattern)
Date: 24 Aug 2009 03:50:57
Message: <4a924661@news.povray.org>
The promise of having a shorter render time by using my fast proximity
pattern macros was, in a sense, a sham. They might render faster, but
the parsing is... painfully slow.
Here is a pattern that will parse more quickly. It might be a little
slower to render, but consider the trade-off: by increasing the render
time a small amount you can save time parsing. But more importantly you
gain a level of detail you can only achieve with object patterns.
And of course you can never use this with meshes. That is, not until
somebody figures out how to convince POV into turning a mesh into a
bona-fide object pattern...
Sam
Download 'edge_pigment02.inc.txt' (9 KB)
Subject: Re: edge_pigment02.inc (a proximity pattern)
Date: 24 Aug 2009 04:00:30
Message: <4a92489e$1@news.povray.org>
You mean, like adding an "inside_vector" statement to the mesh? :-P
Date: 24 Aug 2009 04:57:57
Message: <4a925615@news.povray.org>
Have you /actually/ gotten that to work?
Date: 24 Aug 2009 05:04:22
Message: <4a925796$1@news.povray.org>
Oh crap, /I/ just got it to work! When did this start being possible??
Oh cool :)
Date: 24 Aug 2009 09:06:57
Message: <4a929071@news.povray.org>
> Oh cool :)
Phew - I just was about to confess that no, I never actually tested it
with the inside() function ;-)
(But I'd have been surprised if the SDL inside() function would used any
other mechanism than the very same inside test that's used in CSG, which
I knew works fine with inside_vector.)
Date: 24 Aug 2009 13:50:00
Message: <web.4a92d28499d0b70cffeb02cf0@news.povray.org>
> > Oh cool :)
Which kind of makes me wonder why inside_vector doesn't have a default value.
It seems like the direction rarely matters that much, but if you forget to
specify it...
-Reactor
Date: 24 Aug 2009 15:44:52
Message: <4a92edb4$1@news.povray.org>
http://tinyurl.com/kvww3t
Date: 24 Aug 2009 16:05:41
Message: <4a92f295@news.povray.org>
> specify it...
  My guess is that specifying inside_vector makes the rendering of the
mesh slower in some situations (probably eg. when there's media or fog
around), which is why it's turned off by default.
Date: 24 Aug 2009 17:15:22
Message: <4a9302ea@news.povray.org>
Awesome image! I'm guessing that beautiful chalice is a mesh?
I have tried making meshes into object patterns in the past, but without
success. Even after defining an inside_vector, I received errors.
Date: 24 Aug 2009 18:08:18
Message: <4a930f52$1@news.povray.org>
I don't remember anymore, it's so long ago. I do remember that I got the
idea from you, when you rounded the corners off a cube by jittering it
inside a intersection block, I believe.
Date: 24 Aug 2009 19:29:56
Message: <4a932274$1@news.povray.org>
> specify it...
Backward compat I suppose: Until the introduction of inside_vector, I
assume intersecting a mesh with a solid would give you the same result
as clipping the mesh by that object, and some scenes might have relied
on this effect; defaulting to a proper inside_vector would obviously
break such scenes.
Then again, I guess it would be not much of a problem to default to
inside_vector y (for instance) unless a #version statement is used to
request compat with 3.6 or lower. And a warning could be given even
then, suggesting to use clipped_by instead.
Date: 24 Aug 2009 19:35:24
Message: <4a9323bc@news.povray.org>
I don't think so. Media would only be computed inside a mesh if the
"hollow" keyword is also used anyway.
The only place where it should make a difference is when used with CSG
intersection: In that case, performing proper inside tests instead of
just returning "not inside" would be faster of course.
Anyway, the speed issue could be mitigated by allowing to explicitly
specify "inside_vector <0,0,0>" (or, being equivalent yet more talktive,
"inside_vector no") to disable inside tests.
Date: 25 Aug 2009 11:01:32
Message: <4a93fccc@news.povray.org>
  Except that meshes have no inside and thus no insideness is computed for
them. (Except if inside_vector is specified, of course.)
  That might break existing scenes, especially those which use *open* meshes
and assume that meshes have no inside.
Date: 25 Aug 2009 20:03:06
Message: <4a947bba$1@news.povray.org>
... which is exactly the difference we're discussing here: Whether
having meshes to default to a valid inside_vector would make a difference.
That's what I already mentioned in the first place, and commented on
possible solutions, in case you didn't notice. Here I just focused on
the speed issues.
