POV-Ray : Newsgroups : povray.text.scene-files : edge_pigment02.inc (a proximity pattern) Server Time
10 Jun 2024 09:01:00 EDT (-0400)
  edge_pigment02.inc (a proximity pattern) (Message 1 to 10 of 14)
Subject: edge_pigment02.inc (a proximity pattern)
Date: 24 Aug 2009 03:50:57
Message: <4a924661@news.povray.org>
The promise of having a shorter render time by using my fast proximity
pattern macros was, in a sense, a sham. They might render faster, but
the parsing is... painfully slow.
Here is a pattern that will parse more quickly. It might be a little
slower to render, but consider the trade-off: by increasing the render
time a small amount you can save time parsing. But more importantly you
gain a level of detail you can only achieve with object patterns.
And of course you can never use this with meshes. That is, not until
somebody figures out how to convince POV into turning a mesh into a
bona-fide object pattern...
Sam
Download 'edge_pigment02.inc.txt' (9 KB)
Subject: Re: edge_pigment02.inc (a proximity pattern)
Date: 24 Aug 2009 04:00:30
Message: <4a92489e$1@news.povray.org>
You mean, like adding an "inside_vector" statement to the mesh? :-P
Date: 24 Aug 2009 04:57:57
Message: <4a925615@news.povray.org>
Have you /actually/ gotten that to work?
Date: 24 Aug 2009 05:04:22
Message: <4a925796$1@news.povray.org>
Oh crap, /I/ just got it to work! When did this start being possible??
Oh cool :)
Date: 24 Aug 2009 09:06:57
Message: <4a929071@news.povray.org>
> Oh cool :)
Phew - I just was about to confess that no, I never actually tested it
with the inside() function ;-)
(But I'd have been surprised if the SDL inside() function would used any
other mechanism than the very same inside test that's used in CSG, which
I knew works fine with inside_vector.)
Date: 24 Aug 2009 13:50:00
Message: <web.4a92d28499d0b70cffeb02cf0@news.povray.org>
> > Oh cool :)
Which kind of makes me wonder why inside_vector doesn't have a default value.
It seems like the direction rarely matters that much, but if you forget to
specify it...
-Reactor
Date: 24 Aug 2009 15:44:52
Message: <4a92edb4$1@news.povray.org>
http://tinyurl.com/kvww3t
Date: 24 Aug 2009 16:05:41
Message: <4a92f295@news.povray.org>
> specify it...
  My guess is that specifying inside_vector makes the rendering of the
mesh slower in some situations (probably eg. when there's media or fog
around), which is why it's turned off by default.
Date: 24 Aug 2009 17:15:22
Message: <4a9302ea@news.povray.org>
Awesome image! I'm guessing that beautiful chalice is a mesh?
I have tried making meshes into object patterns in the past, but without
success. Even after defining an inside_vector, I received errors.
Date: 24 Aug 2009 18:08:18
Message: <4a930f52$1@news.povray.org>
I don't remember anymore, it's so long ago. I do remember that I got the
idea from you, when you rounded the corners off a cube by jittering it
inside a intersection block, I believe.
