POV-Ray : Newsgroups : povray.text.scene-files : blocks.inc Server Time
9 Nov 2026 15:56:43 EST (-0500)
  blocks.inc (Message 1 to 12 of 12)
Subject: blocks.inc
Date: 24 Apr 2006 16:46:48
Message: <444d3938$1@news.povray.org>
Does anybody know where to get the good old blocks.inc? Apperently it's
doesn't exist anymore (as google fails to give a working link).
Or does anybody know of another inc file that does ca the same thing?
/thomas
Subject: Re: blocks.inc
Date: 26 Apr 2006 17:10:23
Message: <pan.2006.04.26.20.21.47.824555@localhost>
On Mon, 24 Apr 2006 22:46:49 +0200, Thomas wrote:
> Hi,
> Regards,
> /thomas
What does blocks.inc do?  Is it a lego include?
to all the companies who wait until a large user base becomes
dependant on their freeware, then shafting said happy campers with
mandatory payment for continued usage. I spit on your grave.
Date: 27 Apr 2006 03:11:09
Message: <44506e8d@news.povray.org>
No. It displays some childrens wooden building blocks.
/thomash
Date: 27 Apr 2006 12:18:44
Message: <4450EEE0.70401@sbcglobal.net>
Download 'us-ascii' (8 KB)
Date: 28 Apr 2006 10:55:00
Message: <web.44522b89543f377576ba2c900@news.povray.org>
You want Lego? I know there are some great Lego bits & pieces for POV, but I
built a simple 4x2 block before I discovered these guys. Check out
http://www.kawo1.rwth-aachen.de/~witte/lego-closed.html and
http://hea-www.harvard.edu/~fine/POV/lego_4x2.html
Here's a shot of my Legos.
Download 'legoc2.jpg' (44 KB)
Preview of image 'legoc2.jpg'
Date: 28 Apr 2006 11:00:01
Message: <web.44522cc1543f377576ba2c900@news.povray.org>
And here's a close-up. The blocks are hollow, and the logo & 'pegs' can be
easily turned off when desired.
Download 'legoc0s.jpg' (18 KB)
Preview of image 'legoc0s.jpg'
Date: 28 Apr 2006 11:15:01
Message: <web.44523004543f377576ba2c900@news.povray.org>
That's odd. Both those Jpegs look worse after downloading than the originals
I just created (from .bmp).
There should be almost no visible artifacting on the second image, and only
a tiny bit on the red bricks in the first.
I hadn't noticed that happening here before. I'm using the web interface, by
the way. I wonder how it could happen???
Date: 28 Apr 2006 13:35:00
Message: <web.44525229543f3775200a56120@news.povray.org>
I'm not seeing the artifacts you're talking about.  Have you tried
right-clicking them and doing a save-as?  Maybe something's weird about
your browser. Also, I think this area's for text only.
Charles C
PS, since you mentioned the web interface, do you ever have trouble logging
on?
Date: 28 Apr 2006 13:50:00
Message: <web.445254d2543f3775200a56120@news.povray.org>
Also have a look in ~scenesadvancedblocks    There's a stacks.inc in there.
> /thomash
Date: 28 Apr 2006 14:20:00
Message: <web.44525c09543f377576ba2c900@news.povray.org>
Phew! That's fine then.
> Have you tried
Yes, but only after looking at them in the more usual way, so I suppose the
same file was pulled from the cache.
> your browser.
I believe you're quite correct, Charles. Sorry guys, but the Web interface
misled me, because it says "If posting images, please use JPEG or PNG
format" etc, down the bottom of this page. I just assumed I was in p.b.i
and didn't notice what group it was until I went to check my uploads.
> on?
Only in my early days here. But I have noticed that if I open a new browser
window to search something on this site while I'm composing a message, the
system gets confused and asks me to login again. It happened a couple of
times today, before I UL'ed those pics.
Date: 1 May 2006 11:05:01
Message: <web.4456234c543f377576ba2c900@news.povray.org>
Mystery solved! It was all my silly fault. Sorry! :)
I've just started using a dialup download accelerator with my ISP. I didn't
realize it had the option to downgrade image quality for further speed. I
wonder if it's only Jpegs, or if it converts PNGs too?
Date: 1 May 2006 11:20:00
Message: <web.4456269e543f377576ba2c900@news.povray.org>
> Hi,
As mentioned earlier, there is a blocks scene in the advanced folder, but
its not the same thing.
I've just been playing with the blocks.inc that Dave UL'ed. I noticed it
uses the pre 3.5 syntax (no semicolons at the end of declares). I also
noticed a few minor bugs.
Maybe John VanSickle designed it with a different font to the one I have,
but some of the letters (eg 'I' & 'J')are not centered correctly in the x
direction. Also 'W' is too wide to fit properly, and actually extends past
the edge of the block!
I've been working on an updated version. It's mostly done, but some other
letters could do with fine tuning.
The new version also uses other modern features: local variables, macros and
arrays for easier access.
I've also written some simple text formatting macros to work with these
blocks.
Anyone interested?
