POV-Ray : Newsgroups : povray.text.scene-files : winlogo Server Time
23 Nov 2026 03:50:08 EST (-0500)
  winlogo (Message 1 to 7 of 7)
Subject: winlogo
Date: 29 Mar 2006 16:45:30
Message: <442afffa$1@news.povray.org>
Hi all,
I'm a rather newbie in povray so... ;)
Here's some scene with simple winlogo. It's in two versions to render:
one with metallic textures and one with glass. The first one renders in
a few minutes :) and the second one in a few hours... Is there a way to
make it a little bit faster?
The biggest problem I had with textures was the environment - I've
chosen some bitmap which had to act as an environment for reflections.
Every render I tried ended with strange and obvious patterns on the
surfaces :[ I've spent hours before I've decided to change the bitmap -
and that was it :) Patterns gone away.
Then with the glassy version I had problems with the transmission
colours I wanted to achieve, I tried zillions of
fade_distance/fade_power combinations ;) in addition, I've suddenly
after next few hours I discovered that the very strong influence on that
has the roughness parameter. And thus I've found the proper values :)
The objects itself are isosurfaces. For the first time I've built them
from an extruded surface and wanted to make them have rounded edges...
but had no idea how to make for example f_rounded_box bended with sin(x)
function - one question on p.newusers and I know it already :) btw, is
there a really good tutorial on all those substitutions and so on with
isosurfaces? I'd really like to learn it thoroughly...
After making it looking good, I wanted to put some photons. Never
succeeded to make it good :( Any good tutorial somewhere?
OK, so here it goes, the scene itself:
// Persistence of Vision Ray Tracer Scene Description File
// File: MSWindows.pov
// Vers: 3.6
// Desc: MS Windows logo variation
// Date: 2006-03-23
// Auth: Piotr Borys
// +AM2 +A0.3 +R2 +FN +UA
#version 3.6;
#include "functions.inc"
#include "rad_def.inc"
#declare Photons   = off;
#declare Radiosity = on;
#declare Glass     = off;
global_settings {
   max_trace_level 16
   #if (Radiosity)
   radiosity {
     Rad_Settings(Radiosity_Normal, off, off)
   #if (Photons)
     photons {
       spacing 0.01
       autostop 0
   location  <0.6, 1, -1>*5
   look_at   <-0.25, 0.2, 0>
   angle 50
light_source {
   <8, 16, -4>
   color rgb 1.2
   spotlight
   radius 50
   falloff 70
   tightness 10
   point_at <0, 0, 0>
   area_light
   <1.8, 0, 0> <0, 0, 1.8>
   6, 6
   adaptive 1
   #if (Photons)
   photons {
     refraction on
     reflection on
light_source {
   <-10, 2, -10>
   color <0.7, 0.8, 0.9>*0.5
sphere {
   <0, 0, 0> 20
       image_map {
         jpeg "../lighting/lighting-04.jpg"
         map_type 1
     finish {
       ambient 0.3
       diffuse 0.9
       specular 0.0
       roughness 0.01
   #if (Photons)
   photons {
     collect off
   hollow
plane {
   y, 0
       color rgb <0.7, 0.8, 0.9>
     finish {
       ambient 0.1
       diffuse 0.7
       specular 0.15
       roughness 0.001
#declare T_Chrome =
     pigment { rgb <0.2, 0.2, 0.2> }
     finish {
       metallic
       ambient 0.1
       diffuse 0.6
       specular 0.9
       roughness 0.01
       reflection {
         0.35, 1.0
         fresnel on
       conserve_energy
       brilliance 1.5
#declare T_Glass =
     pigment {rgbt 1}
     finish {
       ambient 0.0
       diffuse 0.0
       specular 0.8
       roughness 0.0005
       reflection {
         0.4, 1.0
         fresnel on
       conserve_energy
#declare I_Glass =
   interior {
     ior 1.5
     fade_power 8
     fade_distance 0.02
     fade_color <0.7, 0.8, 0.9>
#declare M_RGlass =
material {
   texture { T_Glass }
   interior {
     I_Glass
     fade_color <1.0, 0.0, 0.0>
#declare M_GGlass =
material {
   texture { T_Glass }
   interior {
     I_Glass
     fade_color <0.0, 1.0, 0.0>
#declare M_BGlass =
material {
   texture { T_Glass }
   interior {
     I_Glass
     fade_color <0.0, 0.0, 1.0>
#declare M_YGlass =
material {
   texture { T_Glass }
   interior {
     I_Glass
     fade_color <1.0, 1.0, 0.0>
#declare Thickness = 0.07;
#declare WaveHeight = 0.15;
#declare Roundness = 0.1;
#declare wave_box =
isosurface {
    function { f_rounded_box(x, (y - sin(x*pi)*WaveHeight), z,
Roundness, 1, Thickness, 1) }
    contained_by { box { <-1,-0.5,-1>, < 1, 0.5, 1> } }
    max_gradient 1.1
isosurface {
   wave_box
   #if (Glass)
   material { M_YGlass }
   #else
     T_Chrome
     pigment { rgb <0.5, 0.5, 0.0> }
   #if (Photons)
   photons {
     target
     reflection on
     refraction on
     //collect off
   translate <1.1, 1.0, -1.1>
isosurface {
   wave_box
   #if (Glass)
   material { M_BGlass }
   #else
     T_Chrome
     pigment { rgb <0.0, 0.0, 0.5> }
   #if (Photons)
   photons {
     target
     reflection on
     refraction on
     //collect off
   translate <-1.1, 1.0, -1.1>
isosurface {
   wave_box
   #if (Glass)
   material { M_GGlass }
   #else
     T_Chrome
     pigment { rgb <0.0, 0.5, 0.0> }
   #if (Photons)
   photons {
     target
     reflection on
     refraction on
     //collect off
   translate <1.1, 1.0, 1.1>
isosurface {
   wave_box
   #if (Glass)
   material { M_RGlass }
   #else
     T_Chrome
     pigment { rgb <0.5, 0.0, 0.0> }
   #if (Photons)
   photons {
     target
     reflection on
     refraction on
     //collect off
   translate <-1.1, 1.0, 1.1>
Subject: Re: winlogo
Date: 29 Mar 2006 17:15:01
Message: <web.442b0566db0e0e3376d9909d0@news.povray.org>
I have to confess that i had just a rough look into your source and i hand
the questions on to more sophisticated (and less tired ;)) users. One thing
that catched my eye looking at your image was that your arealight could use
jitter. with jitter you should even be able to lower the grid size of your
arealight to only 2x2 or 3x3 with equal (or still even better) results. in
addition this should speed up the rendering quite a lot.
Hope that helpes!
Regards Roman
Date: 29 Mar 2006 20:29:18
Message: <442b346e$1@news.povray.org>
Hiya Piotr.
Gave it to POV-Ray here to render and I only saw a 3X change in render times
for the chrome and glass. I'm not sure what to suggest then, because that
seems about right for glass objects.
Something I wanted to point out about your global_settings is that you
aren't using assumed_gamma, something that has often been discussed in the
past, so you might want to check into that. Using assumed_gamma 1 is said to
be correct (unlike version 3.7 beta where that has now changed).
And for radiosity it is common practice to use ambient_light 0 to squelch
the effect of ambience and apply to the diffuse of textures.
One other thing I noticed, your chrome has fresnel reflection but that's
applied based on ior (refraction), yet it hasn't any refraction; although,
you may add that if you wish.
Bob H  www.3digitaleyes.com
http://3digitaleyes.com/imagery/
Date: 31 Mar 2006 12:20:00
Message: <web.442d647cdb0e0e3376e868250@news.povray.org>
Piotr 'utak3r' Borys <pio### [at] gmailcom> wrote:
> Hi all,
> ...btw, is
Hi, Piotr!
Take a look at Friedrich Lohmueller's *excellent* series of tutorials and
#include files, for all things POV, at
http://www.f-lohmueller.de/pov_tut/pov__eng.htm
Ken
Date: 13 Apr 2006 10:21:27
Message: <443e5e67$1@news.povray.org>
Hi Kenneth,
Wow, great link, thanks :))
Piotr
Date: 13 Apr 2006 10:28:50
Message: <443e6022@news.povray.org>
Hi Bob,
Huh?... hmm, my Athlon64 3000+ chokes on this... will have to
investigate that.
I was always adding assumed_gamma, but this time I was rendering it with
3.7 beta :)
Och, I forgot that... I'm using radiosity for a short period of time.
Indeed, it'd be better.
O, have to check it out... :) thanks!
cheers,
Piotr
Date: 13 Apr 2006 10:30:04
Message: <443e606c$1@news.povray.org>
Hi Roman,
Yeah, you're right. With those current settings I have shadow-banding :/
Thanks!
cheers
Piotr
