Subject: find edges postprocess using functions
Date: 24 Jul 2002 13:02:40
Message: <3d3eddb0@news.povray.org>
See p.b.i.
// Persistence of Vision Ray Tracer Scene Description File
// File: pp.pov
// Vers: 3.5
// Desc: find edges postprocess with pov
// Auth: Simon Adameit
// +fn16 +kff3 -a
#include"math.inc"
#declare Step=frame_number;
#declare Cam_pos=<-8,10,-12>;
#declare Cam_look_at=<0,0,0>;
#declare Scene_scale=30;
#declare Radius_Dist=2;
#declare Radius_Norm=1;
#declare Di_Dist=0.02;
#declare Di_Norm=0.01;
#declare Boden=
union{
plane{y,-2}
box{<-5,-2,-5><5,0,5>}
#declare Haus=
difference{
superellipsoid{<0.5,0.5>
translate y/2
scale 2.5
cylinder{<-3,0,0><3,0,0>,1.5 scale<1,2,1>}
cylinder{<0,0,-3><0,0,3>,1.5 scale<1,2,1>}
#declare Dach=
union{
sphere{0,3 scale<1,0.3,1> translate<0,4,0>}
sphere{0,2.3 scale<1,0.7,1> translate<0,4.5,0>}
sphere{0,1.7 translate<0,5,0>}
/* Camera for Step 1 and 2 */
#if(Step!=3)
camera{
location Cam_pos
up y
look_at Cam_look_at
angle 60
/* Step 1 */
#if(Step=1)
al_settings{
assumed_gamma 1
#declare Tex1=
texture{
pigment{rgb<1,0.4,0.1>}
finish{diffuse 1 ambient 0.5 brilliance 0.01}
#declare Tex2=
texture{
pigment{rgb<0.2,1,0.6>*0.5}
#declare Tex3=
texture{
pigment{checker rgb 1, rgb<0.2,0.19,1> scale 6}
light_source{<20,50,-10> rgb 1.4}
object{Boden texture{Tex3}}
object{Haus texture{Tex1}}
object{Dach texture{Tex2}}
/* Step 2 */
#if(Step=2)
#declare Info_Tex=
texture{
pigment{
average
pigment_map{
spherical scale Scene_scale translate Cam_pos
color_map{
[0 rgb 0]
[1 red 3]
slope{VPerp_Adjust(x,Cam_pos-Cam_look_at)}
color_map{
[0
rgb 0]
[1 green 3]
slope{VPerp_Adjust(y,Cam_pos-Cam_look_at)}
color_map{
[0 rgb 0]
[1 blue 3]
finish{diffuse 0 ambient 1}
object{Boden texture{Info_Tex}}
object{Haus texture{Info_Tex}}
object{Dach texture{Info_Tex}}
/* Step 3 */
#if(Step=3)
camera{
orthographic
location -z
right image_width*x
up image_height*y
look_at 0
plane{z,2
pigment{
image_map{
png "pp1"
translate -.5
scale <image_width,image_height,1>
#declare Ifun=
function{
pigment{
image_map{
png "pp2"
translate -.5
#declare Ifun_red_blur=
function{
#local Z1=-Radius_Dist;
#while(Z1<Radius_Dist)
#local Z2=-Radius_Dist;
#while(Z2<Radius_Dist)
Ifun(x+Z1,y+Z2,z).red+
#local Z2=Z2+1;
#local Z1=Z1+1;
0
/(Radius_Dist*Radius_Dist*4)
#declare Ifun_green_blur=
function{
#local Z1=-Radius_Norm;
#while(Z1<Radius_Norm)
#local Z2=-Radius_Norm;
#while(Z2<Radius_Norm)
Ifun(x+Z1,y+Z2,z).green+
#local Z2=Z2+1;
#local Z1=Z1+1;
0
/(Radius_Norm*Radius_Norm*4)
#declare Ifun_blue_blur=
function{
Ifun(x+Z1,y+Z2,z).blue+
#local Z2=Z2+1;
#local Z1=Z1+1;
0
#declare Ofun_Distance=
function{
select(abs(Ifun_red_blur(x,y,z)-Ifun(x,y,z).red)-Di_Dist,0,1)
#declare Ofun_Norm=
function{
max
select(abs(Ifun_green_blur(x,y,z)-Ifun(x,y,z).green)-Di_Dist,0,1),
select(abs(Ifun_blue_blur(x,y,z)-Ifun(x,y,z).blue)-Di_Dist,0,1)
plane{z,1
pigment{
function{Ofun_Norm(x,y,z)}
color_map{
[0 rgbt 1]
[1 rgb 0]
finish{ambient 1 diffuse 0}
plane{z,0
pigment{
function{Ofun_Distance(x,y,z)}
color_map{
[0 rgbt 1]
[1 rgb 0]
Subject: Re: find edges postprocess using functions
Date: 25 Jul 2002 05:38:50
Message: <3d3fc72a@news.povray.org>
> #declare Ofun_Norm=
> function{
> max
This has to be:
#declare Ofun_Norm=
function{
max
select(abs(Ifun_green_blur(x,y,z)-Ifun(x,y,z).green)-Di_Norm,0,1),
select(abs(Ifun_blue_blur(x,y,z)-Ifun(x,y,z).blue)-Di_Norm,0,1)
Date: 25 Jul 2002 06:08:02
Message: <3d3fce02@news.povray.org>
I try and I obtain a black image !?... how does it works ?
"Simon Adameit" <gom### [at] gmx de> a écrit dans le message de news:
3d3fc72a@news.povray.org...
> > #declare Ofun_Norm=
> > function{
> > max
> This has to be:
> #declare Ofun_Norm=
> function{
> max
Date: 25 Jul 2002 06:17:32
Message: <3d3fd03c@news.povray.org>
Ok, that's right now...
