POV-Ray : Newsgroups : povray.text.scene-files : Another Lightning macro Server Time
9 Oct 2026 17:00:06 EDT (-0400)
  Another Lightning macro (Message 1 to 21 of 21)
Subject: Another Lightning macro
Date: 30 Apr 2001 11:30:11
Message: <3aed8503$1@news.povray.org>
A new trend? The main problem with this macro is that changing one param.
has too great an effect on the behaviour of other params. Oh, and the bolt
is upside down.
// lightning macro w/ sample scene
#version unofficial MegaPov 0.6;
camera{location  <0.0, 0.5, -25.0> look_at   <0.0, 0.0,  0.0>}
//LArraySize = increase this if you get array error messages
//LSeed = random seed for bolt
//LWidth = width of bolt threads
//LHeight = height of whole bolt
//LSpread = spread of bolt
//LBranch = increase for more spikes
//LCutoff = start point for possible forks
//LSpike = increase for a more jagged bolt
#macro Make_Bolt(LArraySize, LSeed, LWidth, LHeight, LSpread, LBranch,
LCutoff, LSpike)
  #declare myArray = array[LArraySize]
  #declare checkCount = -1;
  #declare highCount = 0;
  #declare arrayCount = 0;
  #declare myArray[arrayCount] = <0,0,0>;
  #declare myRand = seed(LSeed);
  #declare Lightning_Bolt =
  merge{
    #while (checkCount < highCount)
      #declare checkCount = checkCount + 1;
      #declare segPosA = myArray[arrayCount];
      #declare arrayCount = arrayCount + 1;
      #declare xPlus = (rand(myRand)-0.5)*LSpread;
      #declare zPlus = (rand(myRand)-0.5)*LSpread;
      #while(segPosA.y < LHeight)
        #declare xShift = segPosA.x + ((rand(myRand)-0.5)*LSpike) + xPlus;
        #declare yShift = segPosA.y + (rand(myRand)/5);
        #declare zShift = segPosA.z + ((rand(myRand)-0.5)*LSpike) + zPlus;
        #if (yShift > LHeight)
          #declare yShift = LHeight;
        #declare segPosB = <xShift, yShift, zShift>;
        cylinder{segPosA, segPosB, LWidth}
        sphere{segPosB, LWidth + 0.0001}
        #declare segPosA = segPosB;
        #declare randNum = rand(myRand);
        #if (randNum < LBranch & segPosA.y > LCutoff)
          #declare highCount = highCount + 1;
          #declare myArray[highCount] = segPosA;
Make_Bolt(500, 7, 0.05, 6, 0.3, 0.065, 0.5, 0.5)
object{
  Lightning_Bolt
  pigment{rgbf 1}
  interior{media{emission rgb <40,40,50>} media{absorption rgb <50,50,40>}}
hollow on
  rotate x*180
  no_shadow
  translate y*6
"To stop children being afraid of the dark, try to fill their daylight hours
with as much terror as possible"
www.tomandlu.co.uk
Subject: Re: Another Lightning macro
Date: 2 May 2001 04:28:30
Message: <3aefc52e@news.povray.org>
At least you got it to make multiple branches - I'm still struggling to get
more than 3...  I'll take a deeper look into the code and see if I can
figure out how yours works.
BTW what are the file://... stuff? I got it to work without them...
It would be nice if you could have a thick main bolt with decreasingly
smaller branches :)
Nekar
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3aed8503$1@news.povray.org...
> is upside down.
> file://LArraySize = increase this if you get array error messages
> file://LSeed = random seed for bolt
> file://LWidth = width of bolt threads
> file://LHeight = height of whole bolt
> file://LSpread = spread of bolt
> file://LBranch = increase for more spikes
> file://LCutoff = start point for possible forks
> file://LSpike = increase for a more jagged bolt
Date: 2 May 2001 06:36:16
Message: <3aefe320@news.povray.org>
"Nekar Xenos" <j-p### [at] citywalkcoza> wrote in message
news:3aefc52e@news.povray.org...
get
Well, I don't know if it's applicable to your lightning macro model, but
here's a brief explanation of how I do the multiple branches (I have no idea
if this is a "standard" way of handling such things, or how efficient it
is). BTW, your lightning is looking very nice.
branch logic:
1. set counter of number of branches to 0 ("highCount")
2. set checkCount to -1 ( a kludge, it should really be 0, but we're just
about to increment it)
3. increment checkCount
4. create main branch out of joined-up cylinders
5. as each cylinder is added, use random function to decide whether to
create a fork
6. if yes, increment "highCount" and store start position for branch in
array using highCount as address (myArray[highCount] = segPosA)
7. carry on with main fork until "ground" reached
8. check if highCount > checkCount
9. if so, increment checkCount, and repeat steps 3 to 8 (this is the  #while
(checkCount < highCount) loop)
Hope that helps.
Ah, that's outlook adding "file:" to // if the // are followed immediately
by anything except a space. //like this. (and if you got the code to work
with the // I'm amazed.)
> smaller branches :)
Yep, it would ;)
Date: 2 May 2001 10:12:12
Message: <3af015bc@news.povray.org>
I've changed Tom Melly's version a bit and I think it's looking good.
Nekar
global_settings
  assumed_gamma 1.0
camera{location  <0, 0.5, -10.0> look_at   <2, 1.2,  0.0>}
sky_sphere
  pigment
    bozo
    color_map { [0.0 color rgb <0.1, 0.2, 0.3>] [1.0 color rgb <0.11, 0.3,
0.4>] }
 // scale <0.1, 0.01, 10>
  scale <0.1, 0.05, 100>
light_source
  0*x // light's position (translated below)
  color red 1.0  green 1.0  blue 1.0  // light's color
  translate <-30, 30, -30>
plane { y, -1 pigment { color rgb <0.7, 0.5, 0.3> }
normal{bumps
       scale 3 }
plane { y, 0  pigment {bozo
    color_map { [0.0 color rgbt <0,0,0,1>] [1.0 color rgbt <0.11, 0.3, 0.4,
0>] }
    scale 10
normal{bumps
        scale <1,1,10>}
    rotate x*180
    translate y*10
fog
 // fog_type 4
  distance 50
  color rgb 0
LCutoff, LSpike)
 // blob{ threshold 0.001 //
        merge{
     // cylinder{segPosA, segPosB, LWidth*2 + 0.0001 } //  pigment{rgbt
1}interior{media{emission<1,2,2>  }}hollow no_shadow}
      //  sphere{segPosB, LWidth + 0.0001}
        #declare LWidth = (LWidth*0.995)   ;
      #declare LWidth = (LWidth*0.9)   ;
Make_Bolt(500, 1110, 0.05, 6, 0.3, 0.01, 0.5, 0.2)
object{
  Lightning_Bolt
 pigment{rgbt 1}interior{media{emission<1,5,5>*3  }}hollow
// hollow on
  rotate x*180
  no_shadow
  translate y*6
Make_Bolt(500, 11, 0.03, 6, 0.3, 0.01, 0.5, 0.2)
object{
  Lightning_Bolt
// hollow on
  rotate x*180
  no_shadow
  translate y*6
Date: 2 May 2001 11:02:46
Message: <3af02196$1@news.povray.org>
news:3af015bc@news.povray.org...
Now, if only emitting media worked with radiosity....
Date: 2 May 2001 17:20:13
Message: <chrishuff-667E7B.16174602052001@news.povray.org>
In article <3af02196$1@news.povray.org>, "Tom Melly"
Use MegaPOV...it's required (well, used) for this macro anyway.
Christopher James Huff
Date: 3 May 2001 04:57:39
Message: <3af11d83@news.povray.org>
Replacing
merge{
with
blob{threshold 1
and adding
,1
into the cylinder statement makes it a lot faster.
I've also tried replacing  the cylinder with my own lightning and it worked well,
making it nicely scalable without any unnatural straight parts.
Nekar
"Tom Melly" <tom### [at] tomandlucouk> wrote in message news:3af02196$1@news.povray.org...
Date: 3 May 2001 05:09:14
Message: <3af1203a$1@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-667E7B.16174602052001@news.povray.org...
Hmm, well I ran this with mp (obviously), but I can't get the lightening to
light up the scene, which would seem to indicate that emitting media doesn't
contribute to radiosity. Am I missing something?
Date: 3 May 2001 05:09:57
Message: <3af12065@news.povray.org>
news:3af11d83@news.povray.org...
> Replacing
> merge{
> with
> blob{threshold 1
> and adding
> ,1
worked well, making it nicely scalable without any unnatural straight parts.
Will you post your modified version (the one using your lightning)?
Date: 3 May 2001 05:34:28
Message: <3af12624@news.povray.org>
I was going to but I had that stiffy(3.5" disk unable to read stuff) problem
again. Can't wait till I get a CDRW so that I can bring files from home...
I'll try again tomorrow. But I think it would be better if I could
completely replace you branches with mine. That would be easy if you could
modify your version to have only straight arms without the 'jaggedness'.
Could you try that for me. I'm still rather 'new' to coding so it's not
always that easy for me to decipher what is what.
Thanks
Nekar
Date: 3 May 2001 06:28:17
Message: <3af132c1@news.povray.org>
news:3af12624@news.povray.org...
problem
> Thanks
Well, removing the jaggedness is easy enough:
#declare xShift = segPosA.x; // + ((rand(myRand)-0.5)*LSpike) + xPlus;
#declare yShift = segPosA.y + 0.5; // (rand(myRand)/5);
#declare zShift = segPosA.z; // + ((rand(myRand)-0.5)*LSpike) + zPlus;
The trouble is that all the forks then just go straight down. Is that what
you meant? (probably not).
The most significant params are LSpread and LSpike in terms of the basic
shape of the bolt.
Try these four settings:
//Make_Bolt(500, 11211, 0.03, 6, 0.3, 0.05, 0.5, 0.2) // normal (whatever
that means)
//Make_Bolt(500, 11211, 0.03, 6, 0.0003, 0.05, 0.5, 0.2)  // small LSpread -
quite nice!
//Make_Bolt(500, 11211, 0.03, 6, 0.3, 0.05, 0.5, 0.0002) // small LSpike
//Make_Bolt(500, 11211, 0.03, 6, 0.0003, 0.05, 0.5, 0.0002) // small LSpread
and LSpike
Date: 3 May 2001 06:30:20
Message: <3af1333c@news.povray.org>
news:3af132c1@news.povray.org...
Oh, Outlook....
nice
Make_Bolt(500, 11211, 0.03, 6, 0.0003, 0.05, 0.5, 0.0002) // small LSpread &
LSpike
Date: 3 May 2001 06:32:43
Message: <chrishuff-264ADB.05301703052001@news.povray.org>
In article <3af1203a$1@news.povray.org>, "Tom Melly"
> lightening to light up the scene, which would seem to indicate that
> emitting media doesn't contribute to radiosity. Am I missing
> something?
Yeah, you are. From the MegaPOV documentation, section 10.2.7,
"Miscellaneous changes & bug fixes":
"Radiosity estimation can be affected by media. To enable this feature,
add media on to the radiosity {} block within global_settings {}."
Sorry I wasn't more specific in my previous post...
PS: "lightning", not "lightening". The same error was made in the
include files...
Date: 3 May 2001 07:10:44
Message: <3af13cb4@news.povray.org>
Thanks, I'll see what I can do.
BTW a workaround for the file://problem is to  /* use these */ instead
Nekar
news:3af1333c@news.povray.org...
> Oh, Outlook....
> nice
> LSpike
Date: 3 May 2001 07:28:33
Message: <3af140e1$1@news.povray.org>
news:chrishuff-264ADB.05301703052001@news.povray.org...
Aha! Many thanks.
You are forgiven ;)
> include files...
I know, I know.... I've corrected several, but missed more. It's a word that
I habitually mispell. My mind knows how it is spelt, but my fingers
disagree...
Date: 3 May 2001 07:33:09
Message: <3af141f5@news.povray.org>
What I actually meant is it should have straight branches like the tree in
Robert J Becrafts IRTC fortress entry.(posted 2001/04/28 21:56 PM in
p.b.i.).  The number of cylinders in the whole lightning bolt should be the
same as the number of branches(stem included).  So it would look like a
'stick drawing'.
Like this:
                   /\_
                  /I I I\
Each symbol represents 1 cylinder.
As I have exact control over where to put my lightning bolt I can then just
replace each cylinder with one of my lightning bolts.
I hope this explains it better.
Thanks
Nekar
Date: 3 May 2001 08:22:18
Message: <3af14d7a$1@news.povray.org>
news:3af141f5@news.povray.org...
<snip>
Ah! Now I understand. Hmm, my first thought was that this was impossible
with the way my macro works, but I have a cunning plan....
Get back to you later...
Date: 3 May 2001 12:19:17
Message: <3af18505$1@news.povray.org>
Hey, it worked! (image in binary.images - no lights, just emitting media)
Date: 3 May 2001 18:24:55
Message: <3af1dab7@news.povray.org>
Tom Melly wrote in message <3af14d7a$1@news.povray.org>...
Try this - you only get an object stretching between junctions, you can also
use any object as your key shape.
// use any object as your building block (needs to take 2 co-ords)
#macro Cylinder_Object(CStart, CEnd, CWidth)
  cylinder{CStart, CEnd, CWidth}
#macro Box_Object(BCorner1, BCorner2)
  box{BCorner1, BCorner2}
//plane{y, 0 pigment{checker Gray, Green}}
LCutoff)
  merge{
      #declare segPosB = segPosA;
      #declare no_base = true;
      #while(segPosB.y < LHeight)
        #declare xShift = segPosB.x + xPlus;
        #declare yShift = segPosB.y + (rand(myRand)/5);
        #declare zShift = segPosB.z + zPlus;
        #if (randNum < LBranch & segPosB.y > LCutoff) // we only need a new
cylinder here
          Cylinder_Object(segPosA, segPosB, LWidth)
//          Box_Object(segPosA, segPosB)
          #declare no_base = false;
      #if(no_base & segPosB.y < LHeight)
      #declare LWidth = (LWidth*0.9);
//#macro Make_Bolt(LArraySize, LSeed, LWidth, LHeight, LSpread, LBranch,
LCutoff)
Make_Bolt(500, 11211, 0.03, 6, 0.5, 0.05, 0.5)
object{
  Lightning_Bolt
  pigment{rgbt 1}
  interior{media{emission<3,3,5>*5}}
  hollow
  rotate x*180
  no_shadow
  translate y*5
Date: 4 May 2001 02:05:15
Message: <3af2469b@news.povray.org>
Thanks.
I probably won't be here again before Monday. I'll post the result then.
Nekar
#version unofficial MegaPov 0.7;#local Q=seed(7);#local S=<-2,2,5>;#local
E=<2
,-2,5>;#local B=S;#while(vlength(B-E)>.1)#local
B=(B+(<rand(Q),rand(Q),rand(Q)
>/20));#local B=B-(2*(B-S))*((vlength(B-E)>vlength(S-E)));#local
S=B;glow{//NX
location S size.1 radius.07}glow{location S size.1 radius.07 rotate
z*90}#end
Date: 6 May 2001 06:03:20
Message: <3af52168@news.povray.org>
I've added my lightning in but there are empty spaces between the branches.
I'm not quite sure why.
Nekar
camera{location  <0.0, 0.5, -10.0> look_at   <2, 1,  0.0>}
// plane{y, 0 pigment{checker Gray, Green}}
#macro Bolt (LightnStart, LightnEnd, Scale,Seed)
#ifndef (Seed)
  #local Seed=seed(0)                     ;
#ifndef (LightnStart)
  #local LightnStart=<0,0,0>         ;
#ifndef (LightnEnd)
  #local LightnEnd=<0,0,0>      ;
#ifndef (Scale)
  #local Scale=0.05        ;
// #ifndef (Color)
//  #local Color=<1,1,1>        ;
// #end
#local Seed = seed(Seed);
#local BlobPosition =  LightnStart   ;
blob{
  threshold 1 // 0.6
  sphere { <0,0,0>, 0.1, 0.1
  scale Scale
   translate LightnStart
   /////     Add random blob closer to lightnEnd
     #while (vlength(BlobPosition - LightnEnd) > 0.1)
     #local Rx=rand(Seed);  #local Ry=rand(Seed); #local Rz=rand(Seed);
             #local BlobPosition = ( BlobPosition + (<0.5-Rx, 0.5-Ry,
0.5-Rz> * 0.04 ) )   ;
         #if ( ( vlength(BlobPosition - LightnEnd) >  vlength (LightnStart -
LightnEnd) ))
                #local BlobPosition = (BlobPosition - ( 2*(BlobPosition -
LightnStart) )) ;
         #local LightnStart = BlobPosition ;
   sphere { <0,0,0>, 1, 1
      scale Scale
      scale Scale
      translate LightnEnd }
 //  pigment{rgbt 1}interior{media{emission Color }}hollow
LCutoff)
  merge{
cylinder here
        // Bolt (LightnStart, LightnEnd, Scale, Seed)
        Bolt (segPosA, segPosB,LWidth,myRand)
        //  Cylinder_Object(segPosA, segPosB, LWidth*2)
      #declare LWidth = (LWidth*0.95);
// #macro Make_Bolt(LArraySize, LSeed, LWidth, LHeight, LSpread, LBranch,
LCutoff)
Make_Bolt(500, 11, 0.05, 6, 0.1, 0.06, 0.5)
object{
  Lightning_Bolt
  pigment{rgbt 1}
  interior{media{emission<3,4,5>}}
  hollow
  rotate x*180
  no_shadow
  translate y*5
