-that I posted 18. March to the povray.binaries.images group:
http://news.povray.org/povray.binaries.images/23091/
I have inserted some comments into this code in order to try
and explain a little bit more about how to use the macros I've
posted so far.
Prior to rendering:
Copy all the macros that I posted in this message:
"Code for NURBS surfaces as mesh2{} objects" (25. March)
and paste them into a file named "NURBS.inc"
Here's that message:
http://news.povray.org/povray.text.scene-files/23250/161948/
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
// Copyright 2002 by Tor Olav Kristensen
// Email: tor### [at] hotmail com
// http://www.crosswinds.net/~tok
#version 3.5;
#include "NURBS.inc"
// Number of control points in the U and V "directions"
#declare NrU = 5;
#declare NrV = 5;
// These control points and their weights will make the surface
// a flat square.
#declare CtrlPoints =
array[NrU][NrV] {
{ <0,0, 0>, <1,0, 0>, <2,0, 0>, <3,0, 0>, <4,0, 0> },
{ <0,1, 0>, <1,1, 0>, <2,1, 0>, <3,1, 0>, <4,1, 0> },
{ <0,2, 0>, <1,2, 0>, <2,2, 0>, <3,2, 0>, <4,2, 0> },
{ <0,3, 0>, <1,3, 0>, <2,3, 0>, <3,3, 0>, <4,3, 0> },
{ <0,4, 0>, <1,4, 0>, <2,4, 0>, <3,4, 0>, <4,4, 0> }
#declare Weights =
array[NrU][NrV] {
{ 1, 1, 1, 1, 1 },
{ 1, 1, 1, 1, 1 },
{ 1, 1, 1, 1, 1 },
{ 1, 1, 1, 1, 1 },
{ 1, 1, 1, 1, 1 }
// This is more interesting. Some points have been displaced along
// the z-axis. Each of them are "pulling" a region of the surface
// towards them.
array[NrU][NrV] {
{ <0,0, 0>, <0,1, -2>, <0,2, 3>, <0,3, -2>, <0,4, 0> },
{ <1,0, 0>, <1,1, 0>, <1,2, 0>, <1,3, 0>, <1,4, 0> },
{ <2,0, 0>, <2,1, -2>, <2,2, 0>, <2,3, 4>, <2,4, 0> },
{ <3,0, 0>, <3,1, 0>, <3,2, 0>, <3,3, 0>, <3,4, 0> },
{ <4,0, -3>, <4,1, 0>, <4,2, 0>, <4,3, 0>, <4,4, 4> }
// These weights can be thought of as a measure for how strong the
// pull or "tension" from their corresponding points will be.
#declare Weights =
array[NrU][NrV] {
{ 1, 1, 1, 1, 1 },
{ 1, 1, 1, 1, 1 },
{ 1, 10, 1, 1, 1 },
{ 1, 1, 1, 1, 1 },
{ 1, 1, 1, 1, 1 }
// IIRC negative values aren't really "allowed" in NURBS weights.
// (But the results are interesting.)
// Uncomment this if you want to see the grid of control points
object {
ShowControlPoints(CtrlPoints, 0.04)
pigment { color Yellow }
object {
ShowControlGrid(CtrlPoints, 0.02)
pigment { color Cyan }
// Order must be greater than or equal to 2 and less than or
// equal to the lesser of NrU and NrV. I.e. the number of control
// points above will allow you to try Order values from 2 to 5.
#declare Order = 4;
// For lower Order values, each point will "control" a smaller
// region of the surface. And higher values will make each of
// them "control" a larger region of it.
// It doesn't really matter much what you set these to here.
#declare MinUV = <0, 0>;
#declare MaxUV = <1, 1>;
// Now let a macro calculate the knots.
#declare KnotsU = OpenUniformKnotVector(Order, NrU, MinUV.u, MaxUV.u)
#declare KnotsV = OpenUniformKnotVector(Order, NrV, MinUV.v, MaxUV.v)
// Read about b-splines if you want to select the knots yourself.
// (I may make other knot macros later.)
// Anyway: Have a look at the knot "vectors".
#debug "\nU knot vector: "
printM(KnotsU)
#debug "\nV knot vector: "
printM(KnotsV)
#debug "\n"
// Assemble the 3 parametric functions needed for
// the ParametricMesh() and CylinderMesh() macros.
#declare xFn =
NURBS_SurfFunction(Order, KnotsU, KnotsV, CtrlPoints, Weights, x)
#declare yFn =
NURBS_SurfFunction(Order, KnotsU, KnotsV, CtrlPoints, Weights, y)
#declare zFn =
NURBS_SurfFunction(Order, KnotsU, KnotsV, CtrlPoints, Weights, z)
// If you now limit the ranges that these variables defines,
// then only a part of the surface will be "meshyfied".
// (If you expand these ranges, you'll get an error.)
#declare MinUV = <0.2, 0.0>;
#declare MaxUV = <0.8, 0.9>;
// U will wary from 0.2 to 0.8
// V will wary from 0.0 to 0.9
// This will result in 50*50 squares with 2 triangles each.
#declare Resolution = <50, 50>; // Use <10, 10> if you have a slow PC.
// So there will be 50 squares in the U "direction" and 50 in
// the V "direction". I.e. you'll get 50*50*2 = 5000 triangles.
// Then you can calculate the mess and use it directly
#declare MessyMesh =
ParametricMesh(
function(u, v) { xFn(u, v) },
function(u, v) { yFn(u, v) },
function(u, v) { zFn(u, v) },
MinUV,
MaxUV,
Resolution
// Or you may calculate it and save it for later use
WriteParamMesh(
MinUV,
MaxUV,
Resolution,
"NURBSmesh.txt"
// And then read it back
#declare MessyMesh = #include "NURBSmesh.txt"
// Now show this mesh2 object and let its colour vary along with
// its "depth" in the z-direction. +z is away from the camera.
object {
MessyMesh
gradient -z
color_map {
[ 0.4 color Blue ]
[ 1.0 color Green*2 ]
scale <1, 1, 7> // "Depth" diff. between points (in z-direction)
translate -3*z // "Depth" of the farthest point (in z-direction)
// Alternatively you can map an image onto it. (One of the Beta
// releases of POV-Ray had problems with this IIRC).
object {
MessyMesh
uv_mapping
image_map {
png "test"
map_type 0
interpolate 2
// rotate 180*y
// Uncomment the pigment statements in the CylinderMesh() macro
// to get different colouring for the 2 cylinder "types".
object {
CylinderMesh(
MinUV,
MaxUV,
Resolution
0.01 // Cylinder radius
// Or just uncomment the line below if you
// want them to have the same colour.
// pigment { color (Magenta + White)/4 + Red/2 }
// pigment { color (Red + Orange)*0.8 }
// Add a light source
light_source { <2, 1, -5>*10 color White shadowless }
// And a plain camera looking at the mess from the left behind it
location <-2.0, 1.1, -4.0>*1.1
look_at <3.0, 2.2, 0.0>
// Also try this camera
orthographic
location <2, 2, -4.5>
look_at <2, 2, 0>
// And then set all weights to 1 and try this camera again.
// U increases towards the right and V increases upwards
// (The x and y components of the control points in the array
// are chosen so that the x components will increase along with
// the U values and the y components will increase along with
// the V values.)
// And then finally add a tuch of blue to the backdrop
background { color Blue/8 }
