POV-Ray : Newsgroups : povray.text.scene-files : Source code for the "NURBS surface" image Server Time
21 Mar 2026 12:18:15 EDT (-0400)
  Source code for the "NURBS surface" image (Message 1 to 3 of 3)
Subject: Source code for the "NURBS surface" image
Date: 7 Apr 2002 06:19:49
Message: <3CB019B8.7364047F@online.no>
-that I posted 18. March to the povray.binaries.images group:
http://news.povray.org/povray.binaries.images/23091/
I have inserted some comments into this code in order to try
and explain a little bit more about how to use the macros I've
posted so far.
Prior to rendering:
Copy all the macros that I posted in this message:
"Code for NURBS surfaces as mesh2{} objects" (25. March)
and paste them into a file named "NURBS.inc"
Here's that message:
http://news.povray.org/povray.text.scene-files/23250/161948/
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
// Copyright 2002 by Tor Olav Kristensen
// Email: tor### [at] hotmailcom
// http://www.crosswinds.net/~tok
#version 3.5;
#include "NURBS.inc"
// Number of control points in the U and V "directions"
#declare NrU = 5;
#declare NrV = 5;
// These control points and their weights will make the surface
// a flat square.
#declare CtrlPoints =
  array[NrU][NrV] {
    { <0,0,  0>, <1,0,  0>, <2,0,  0>, <3,0,  0>, <4,0,  0> },
    { <0,1,  0>, <1,1,  0>, <2,1,  0>, <3,1,  0>, <4,1,  0> },
    { <0,2,  0>, <1,2,  0>, <2,2,  0>, <3,2,  0>, <4,2,  0> },
    { <0,3,  0>, <1,3,  0>, <2,3,  0>, <3,3,  0>, <4,3,  0> },
    { <0,4,  0>, <1,4,  0>, <2,4,  0>, <3,4,  0>, <4,4,  0> }
#declare Weights =
  array[NrU][NrV] {
    {     1,         1,         1,         1,         1      },
    {     1,         1,         1,         1,         1      },
    {     1,         1,         1,         1,         1      },
    {     1,         1,         1,         1,         1      },
    {     1,         1,         1,         1,         1      }
// This is more interesting. Some points have been displaced along
// the z-axis. Each of them are "pulling" a region of the surface
// towards them.
  array[NrU][NrV] {
    { <0,0,  0>, <0,1, -2>, <0,2,  3>, <0,3, -2>, <0,4,  0> },
    { <1,0,  0>, <1,1,  0>, <1,2,  0>, <1,3,  0>, <1,4,  0> },
    { <2,0,  0>, <2,1, -2>, <2,2,  0>, <2,3,  4>, <2,4,  0> },
    { <3,0,  0>, <3,1,  0>, <3,2,  0>, <3,3,  0>, <3,4,  0> },
    { <4,0, -3>, <4,1,  0>, <4,2,  0>, <4,3,  0>, <4,4,  4> }
// These weights can be thought of as a measure for how strong the
// pull or "tension" from their corresponding points will be.
#declare Weights =
  array[NrU][NrV] {
    {    1,         1,         1,         1,         1      },
    {    1,         1,         1,         1,         1      },
    {    1,        10,         1,         1,         1      },
    {    1,         1,         1,         1,         1      },
    {    1,         1,         1,         1,         1      }
// IIRC negative values aren't really "allowed" in NURBS weights.
// (But the results are interesting.)
// Uncomment this if you want to see the grid of control points
object {
  ShowControlPoints(CtrlPoints, 0.04)
  pigment { color Yellow }
object {
  ShowControlGrid(CtrlPoints, 0.02)
  pigment { color Cyan }
// Order must be greater than or equal to 2 and less than or
// equal to the lesser of NrU and NrV. I.e. the number of control
// points above will allow you to try Order values from 2 to 5.
#declare Order = 4;
// For lower Order values, each point will "control" a smaller
// region of the surface. And higher values will make each of
// them "control" a larger region of it.
// It doesn't really matter much what you set these to here.
#declare MinUV = <0, 0>;
#declare MaxUV = <1, 1>;
// Now let a macro calculate the knots.
#declare KnotsU = OpenUniformKnotVector(Order, NrU, MinUV.u, MaxUV.u)
#declare KnotsV = OpenUniformKnotVector(Order, NrV, MinUV.v, MaxUV.v)
// Read about b-splines if you want to select the knots yourself.
// (I may make other knot macros later.)
// Anyway: Have a look at the knot "vectors".
#debug "\nU knot vector: "
printM(KnotsU)
#debug "\nV knot vector: "
printM(KnotsV)
#debug "\n"
// Assemble the 3 parametric functions needed for
// the ParametricMesh() and CylinderMesh() macros.
#declare xFn =
  NURBS_SurfFunction(Order, KnotsU, KnotsV, CtrlPoints, Weights, x)
#declare yFn =
  NURBS_SurfFunction(Order, KnotsU, KnotsV, CtrlPoints, Weights, y)
#declare zFn =
  NURBS_SurfFunction(Order, KnotsU, KnotsV, CtrlPoints, Weights, z)
// If you now limit the ranges that these variables defines,
// then only a part of the surface will be "meshyfied".
// (If you expand these ranges, you'll get an error.)
#declare MinUV = <0.2, 0.0>;
#declare MaxUV = <0.8, 0.9>;
// U will wary from 0.2 to 0.8
// V will wary from 0.0 to 0.9
// This will result in 50*50 squares with 2 triangles each.
#declare Resolution = <50, 50>; // Use <10, 10> if you have a slow PC.
// So there will be 50 squares in the U "direction" and 50 in
// the V "direction". I.e. you'll get 50*50*2 = 5000 triangles.
// Then you can calculate the mess and use it directly
#declare MessyMesh =
  ParametricMesh(
    function(u, v) { xFn(u, v) },
    function(u, v) { yFn(u, v) },
    function(u, v) { zFn(u, v) },
    MinUV,
    MaxUV,
    Resolution
// Or you may calculate it and save it for later use
WriteParamMesh(
  MinUV,
  MaxUV,
  Resolution,
  "NURBSmesh.txt"
// And then read it back
#declare MessyMesh = #include "NURBSmesh.txt"
// Now show this mesh2 object and let its colour vary along with
// its "depth" in the z-direction. +z is away from the camera.
object {
  MessyMesh
      gradient -z
      color_map {
        [ 0.4 color Blue ]
        [ 1.0 color Green*2 ]
    scale <1, 1, 7> // "Depth" diff. between points (in z-direction)
    translate -3*z // "Depth" of the farthest point (in z-direction)
// Alternatively you can map an image onto it. (One of the Beta
// releases of POV-Ray had problems with this IIRC).
object {
  MessyMesh
    uv_mapping
      image_map {
        png "test"
        map_type 0
        interpolate 2
//      rotate 180*y
// Uncomment the pigment statements in the CylinderMesh() macro
// to get different colouring for the 2 cylinder "types".
object {
  CylinderMesh(
    MinUV,
    MaxUV,
    Resolution
    0.01 // Cylinder radius
// Or just uncomment the line below if you
// want them to have the same colour.
//  pigment { color (Magenta + White)/4 + Red/2 }
//  pigment { color (Red + Orange)*0.8 }
// Add a light source
light_source { <2, 1, -5>*10 color White shadowless }
// And a plain camera looking at the mess from the left behind it
  location <-2.0, 1.1, -4.0>*1.1
  look_at <3.0, 2.2, 0.0>
// Also try this camera
  orthographic
  location <2, 2, -4.5>
  look_at <2, 2, 0>
// And then set all weights to 1 and try this camera again.
// U increases towards the right and V increases upwards
// (The x and y components of the control points in the array
// are chosen so that the x components will increase along with
// the U values and the y components will increase along with
// the V values.)
// And then finally add a tuch of blue to the backdrop
background { color Blue/8 }
Subject: Re: Source code for the "NURBS surface" image
Date: 8 Apr 2002 08:31:16
Message: <3cb18d94@news.povray.org>
Thank you Tor! This looks really promising. Your comments will help me a
lot. I already played with your first nurbs-code, and I see the control
points have to be in a grid. So, it's not possible to insert an extra point
in a row, without modifying all other rows.. I suppose it's very hard to get
beyond this limitation?
But I see your new code allows me to easily adjust weights .. that's a
progress. :o)  I will try nurbs to make interesting transitions between
ordinary primitives.. For example fancy edges of a box.. Next, I will try
some organic shapes.. Well, it seems many shapes could also be done with
isosurfaces (and they are not limited to a grid) but nurbs could be more
precise. I mean, the exact location of a point in a blobbed isosurface seems
very unpredictable to me.. POV-nurbs could very well develop into a useful
modelling tool!  But first I'll have to learn more.
Thanks for your work.
Best regards,
Hugo
Date: 8 Apr 2002 20:36:06
Message: <3CB233EE.7550369E@online.no>
Thank you for your comments Hugo.
Yes, I think this is one of the arguments against
NURBS surfaces when compared to subdivision of
surfaces techniques.
Here are some subdivision posts:
http://news.povray.org/search/?s=Subdivision+Surface
> progress. :o)
Unfortunately the code I posted here doesn't
contain any new macros.
I have just tried to show how to call some of the
NURBS macros "manually", instead of calling them
via the NURBS_SurfaceMesh() macro, which makes a
lot of decisions for the users. One of them is
to set all weights to 1. (I made that macro just
so that people could get started easily.)
I'm very interested in seeing your achievements.
> modelling tool!
Yes, I hope so.
You're welcome.
Tor Olav
