![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
At 24. January 2002 I posted an image to povray.binaries.images.
Below is the source for it.
Here are links to that post:
http://news.povray.org/povray.binaries.images/21703/
news://news.povray.org/3C508AF7.260EBD52%40hotmail.com
The SphereSpiralsFunction() below is optimized for speed rather than
for understandability. If you wish to have a look at a more readable
version of it, you can find one within the source code in this post:
"Souce code for "The remains of an iso sphere: Take 2""
http://news.povray.org/povray.text.scene-files/20990/
news://news.povray.org/3C2D2372.3E564379%40hotmail.com
(28. Dec. 2001 to this group)
Note that when I rendered this image, a small defect appeared at the
"south pole" of the sphere. I'm not sure what causes this. (It might
be caused by the very high (or infinite) gradient for the iso-surface
function at the "poles".)
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
// Copyright 2002 by Tor Olav Kristensen, except for the textures.
// Email: tor### [at] hotmail com
// http://www.crosswinds.net/~tok
#version 3.5; // Beta 9
#include "functions.inc"
#include "rad_def.inc"
Quote from "rad_def.inc":
"DO NOT FORGET TO USE THE +QR/Radiosity=on OPTION"
global_settings {
radiosity { Rad_Settings(Radiosity_OutdoorHQ, on, off) }
#declare Nothing = 1E-10;
// Modified versions of a texture once made by Gilles Tran
#declare GillesTexMod1 =
bozo
color_map {
[ 0 color White*0.7 ]
[ 1 color White*1.1 ]
normal {
agate 0.3
scale 1.6
finish {
ambient 0
diffuse 0.8
specular 0.1
roughness 0.1
metallic
brilliance 1
scale 0.4
#declare GillesTexMod2 =
crackle solid
color_map {
[ 0 color White*0.5 ]
[ 1 color White*0.9 ]
normal {
granite 0.9
scale 3
finish {
ambient 0
diffuse 0.8
specular 0.1
roughness 0.1
metallic
brilliance 1
scale 0.4
#macro SphereSpiralsFunction(Rmaj, Rmin, PhiFn, NrOfBands, GapRatio)
#local TwoPi = 2*pi;
#local DivAngle = TwoPi/NrOfBands;
#local GapAngle = DivAngle*GapRatio;
#local HalfGapAngle = GapAngle/2;
function {
select(
mod(
atan2(z, x) - PhiFn(x, y, z) +
select(atan2(z, x) - PhiFn(x, y, z), TwoPi, 0),
DivAngle
) - GapAngle,
select(
mod(
DivAngle
) - HalfGapAngle,
f_sphere(
x - Rmaj*f_r(x, 0, z)/(Nothing + f_r(x, y, z))*
cos(
atan2(z, x) -
mod(
DivAngle
y - Rmaj*y/(Nothing + f_r(x, y, z)),
z - Rmaj*f_r(x, 0, z)/(Nothing + f_r(x, y, z))*
sin(
atan2(z, x) -
mod(
DivAngle
Rmin
f_sphere(
cos(
atan2(z, x) -
mod(
DivAngle
) + GapAngle
sin(
atan2(z, x) -
mod(
DivAngle
) + GapAngle
Rmin
abs(f_sphere(x, y, z, Rmaj)) - Rmin
#end // macro SphereSpiralsFunction
#declare NegOne = Nothing - 1;
#declare PosOne = 1 - Nothing;
#declare K = 1.8; // 2.1 // "Twisting rate"
#declare Rmajor = 3.0;
#declare Rminor = 0.1;
// A more understandable, but slower version of the macro call below.
#declare ClampFn = function(N, Min, Max) { max(Min, min(N, Max)) }
#declare yFn =
function { ClampFn(y/(Nothing + f_r(x, y, z)), NegOne, PosOne) }
#declare SphereSpiralsFn =
Rmajor,
Rminor,
function { ln(2/(1 - yFn(x, y, z)) - 1)/K },
4,
1/2
Rmajor,
Rminor,
function {
ln(
2/(1 - max(NegOne, min(y/(Nothing + f_r(x, y, z)), PosOne))) - 1
)/K
4,
1/2
isosurface {
function { SphereSpiralsFn(x, y, z) }
max_gradient 4 // 115 // 250 // 4000 // ...
// accuracy 1E-12
contained_by { sphere { <0, 0, 0>, Rmajor + Rminor + 0.01 } }
texture { GillesTexMod1 }
rotate 180*x
rotate 32*y
// no_shadow
plane {
y, -(Rmajor + Rminor + 2.5)
texture { GillesTexMod2 }
sky_sphere {
gradient y
color_map {
[ 0 White ]
[ 1 rgb <0.25, 0.46, 0.80>*0.9 ]
light_source {
<34, 29, -16>*4
color rgb <0.76, 0.62, 0.34>
area_light
2*x, 2*z,
4, 4
circular
orient
adaptive 1
jitter
location <0, 21.7, -10.5>
look_at <-2.5, 0, 0>
angle 34
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Source code for "Almost Sphere Spirals"
Date: 28 Jan 2002 04:25:12
Message: <3c5518f8@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Tor Olav Kristensen" wrote in message
Thanks. That is interesting.
I see. I've encountered the same problem in the carpet project.
That is due to 'mod' function. The first parameter of 'mod' function
should be positive in such cases.
So, the below macro will work as expected.
R. Suzuki
function {
select(
mod(
select(atan2(z, x) - PhiFn(x, y, z), TwoPi, 0) +TwoPi,
DivAngle
) - GapAngle,
select(
mod(
DivAngle
) - HalfGapAngle,
f_sphere(
cos(
atan2(z, x) -
mod(
DivAngle
sin(
atan2(z, x) -
mod(
DivAngle
Rmin
f_sphere(
cos(
atan2(z, x) -
mod(
DivAngle
) + GapAngle
sin(
atan2(z, x) -
mod(
DivAngle
) + GapAngle
Rmin
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you Ryoichi.
I have now done some quick tests on my
(much faster) PC at work.
And it seems that your suggestion to add
2*pi after some of my select() expressions
did fix the problem.
So, does this mean that the mod() function
is not working as it should ?
(Or were my math-expressions wrong ?)
Anyway, I think that I will experiment
more to see if I can get totally rid of
those 6 select() expressions.
Tor Olav
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
