POV-Ray : Newsgroups : povray.text.scene-files : isosurface & radiosity test source Server Time
15 May 2025 03:23:21 EDT (-0400)
  isosurface & radiosity test source (Message 1 to 1 of 1)
Subject: isosurface & radiosity test source
Date: 11 Jul 2001 06:09:03
Message: <3B4C263F.D2642AAB@gmx.de>
// BEGIN pov-code
// Persistence of Vision Ray Tracer Scene Description File
// File: rad_iso_01a.pov
// Desc: isosurface & radiosity test
// Date: July 2001
// Auth: Christoph Hormann
#version unofficial MegaPov 0.7;
global_settings {
  assumed_gamma 1.0
  radiosity {
    pretrace_start 0.08
    pretrace_end 0.004
    count 300
    error_bound 0.1
    recursion_limit 1
    low_error_factor .5
    gray_threshold 0.0
    minimum_reuse 0.015
    brightness 1
    adc_bailout 0.01/2
  location  <10.0, 10.0, 2.0>
  direction y
  sky       z
  up        z
  right     x*1.333333
  look_at   <0.0, 0.0, 1.0>
  angle     40.0
// Based on Kari Kivisalo's lighting configuration
// modified in both color and intensity
#macro G(Color,g)
  rgb<pow(Color.x,g),pow(Color.y,g),pow(Color.z,g)>
#declare Gamma=2.2;
#declare SkyColor=G(<132,164,255>/255,Gamma);  // @ 15000K rgb white=6500K
//#declare SunColor=G(<255,235,197>/255,Gamma);  // @ 5400K  rgb
white=6500K
#declare SunColor=G(<255,184,130>/255,Gamma);  // changed
#declare EnergyRatio=9;  // sun/sky energy ratio
#declare EQ=1.18;        // normalisation for sun-sky colors
light_source {
  <-8000.0, 8000.0, 4000.0>
  color rgb 0.5*SunColor*EnergyRatio/EQ   // changed
  area_light 90*x 90*y  5,5
  jitter
  orient
#declare Sky_Bckg_12 = texture {
     gradient z
     color_map {
       [0.40 color rgb < 0.880, 0.935, 0.976 >]
       [0.95 color rgb < 0.400, 0.500, 0.900 >]
   finish {
     diffuse 0
     ambient 1
   rotate 27*x
sphere {
  <0, 0, 0>, 1
     Sky_Bckg_12
  scale<100000, 100000, 20000>
  no_shadow
  hollow on
#declare fn_sphere=function{"sphere",<0.2>}
#declare fn_Noise=function {
    agate
    color_map {
      [0 rgb 0]
      [1 rgb 1]
    translate -0.25*z
#declare Mountains_01=
isosurface{
  function {
    ((1+0.1)
     - 0.1^(fn_sphere(x, y, z-0.3))
     - 0.1^(z)) - (fn_Noise(x*3,y*3,z*3))*0.26
  method 2
  //eval
  max_gradient 20
  accuracy 0.001
  contained_by{box{<-2.7, -2.7, -0.1>, <1.7, 1.7, 1>}}
    pigment { color rgb <0.78, 0.58, 0.42> }
    finish { ambient 0.0 diffuse 0.6 }
  scale 5
object { Mountains_01 }
// END pov-code
