I looked online and found quite a useful equation for generating
gaussian random nubmers. This macro generates a random number that is
roughly between -3 and 3. The numbers will be normally distributed
(mean = 0 standard deviation 1).
This is very useful for something like randomly rotating bricks or
tiles. Using the pov-ray random function, they would all be rotated
randomly from 0 degrees to x degrees, but with this macro, about 2/3 are
between 0 and x degrees while there are a few outliers. It gives it a
more natural look.
- Rico
Here's the site in case someone wants to take a look at the second
equation (I couldn't get it to work correctly):
http://www.taygeta.com/random/gaussian.html
And here's the macro:
#declare e = 2.718281828459;
#macro gauss(RSR)
sqrt(-2*log(rand(RSR))/log(e))*cos(2*pi*rand(RSR))
> #macro gauss(RSR)
> #end
Oh yeah, in case you didn't figure it out, you have to define a seed like
this:
#declare S = seed(2003);
#declare random_number = gauss(S);
Reusser <reu### [at] chorus net> wrote:
: sqrt(-2*log(rand(RSR))/log(e))*cos(2*pi*rand(RSR))
Isn't log(e) equal to 1?
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
Not on my calculator. Perhaps you are thinking of ln(e), which is equal
to 1.
log(e) is 0.443429448....
/Ib
It depends who you ask. log BASE E of e is one, but pov-ray assumes that the
base is 10. This gives you 10^x = e, which is something like .434. I don't
know how it used to be, but now the assumed base of a log is 10. Looking at
my dad's 1970's textbook, it appears to use e.
- Rico
"Reusser" <reu### [at] chorus net> schreef in bericht
news:3B3FACCE.EB5780BF@chorus.net...
the
don't
at
In mathematics, log(10)=1 and ln(e)=1, but from the pov-ray help files
(float functions):
# log(A) Natural logarithm of A. Returns the natural logarithm base e of the
value A.
So pov-ray doesn't seem to follow the mathematical standard.
Frits van Bommel
Ib Rasmussen <ib### [at] ibras dk> wrote:
:> Isn't log(e) equal to 1?
: Not on my calculator.
I was asking about log(e) in POV-Ray.
: It depends who you ask. log BASE E of e is one, but pov-ray assumes that the
: base is 10.
Wrong. POV-Ray assumes that the base is e.
Well I stand corrected. It still works either way, so I guess you can just change
it to 1.
- Rico
Wait a minute. I made my assumption on the fact that pov-ray has a ln keyword. I
assumed that that meant there was also a natural log in which case log would be
base 10. If this is not the case, then what does ln do?
: Wait a minute. I made my assumption on the fact that pov-ray has a ln keyword. I
: assumed that that meant there was also a natural log in which case log would be
: base 10. If this is not the case, then what does ln do?
POV-Ray 3.1 doesn't have an ln() function. The log() function is used
as natural logarithm.
However, it seems that this will be changed in POV-Ray 3.5...
: Well I stand corrected. It still works either way, so I guess you can just change
: it to 1.
Or just remove it, as dividing by 1 doesn't change anything.
MegaPov .714 has a keyword "ln" that turns blue when I type it in. What does that do
if it's not a natural log function?
-Rico
Hi all,
> #macro gauss(RSR)
> #end
I tried it and Pov-Ray assumes "log" is in base e, so log(e)=1 and you don't
need it.
But the formula would stand correct if you assume log is in base 10 because
of the base change formula log BASE e(x) = log BASE 10(x) / log BASE 10(e)
Greets
Pablo Viojo.-
pvi### [at] adinet com uy
Sorry, I mailed this direct to you. I just misused Outlook...
How about this:
#macro Gauss2(RS,w)
#local i=w;
#local r=0;
#while (i>0)
#local r=r+rand(RS)/w;
#local i=i-1;
r
RS... Random Seed
w... "width" of the distribution (the higher w, the narrower the dist.)
produces values between 0 and 1, with the maximum at 0.5
Here's a simple test scene (add the above macro at the top):
#declare spectrum
=array[30]{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}
#declare i=0;
#declare R=seed(1712942);
#while(i<10000)
#declare r=Gauss2(R,2)*30;
#declare spectrum[int(r)]=spectrum[int(r)]+1/50;
#declare i=i+1;
#declare _x=0;
#while (_x<30)
box{
<_x,0,-0.5>,<_x+1,spectrum[_x],0.5>
ment{
color rgb <1,0.2,0.2>
finish{
ambient 0.2
specular 1
brilliance 0.6
roughness 0.1
#declare _x=_x+1;
location <15,50,-80>
look_at <15,30,0>
light_source {
<-20,50,-50>*100
color rgb 1
Michael Zier <zie### [at] atlantis wh2 tu-dresden de> wrote:
: #declare spectrum
: =array[30]{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}
Wouldn't it be easier to initialize that with a #while-loop? Specially
if you want a lot more items...
Warp <war### [at] tag povray org> schrieb in im Newsbeitrag:
3b46ec68@news.povray.org...
> : #declare spectrum
Sure, *g*
