// Persistence of Vision Ray Tracer Scene Description File
// File: projector.pov
// Vers: 3.1
// Desc: Slide projector
// Auth: Ingo Janssen
// Modified by Mike Andrews to show media photons
// 25th May 2001
#version unofficial MegaPov 0.7;
#include "glass.inc"
#macro create_spectrum(nelems,bright)
#local elem=1;
color_map{
#while(elem<=nelems)
/* h goes from 0 at red end to 1.0 at blue end */
#local h = (elem-1)/(nelems-1);
/* co-h goes from 1.0 at red end to 0.0 at blue end */
#local coh = 1.0 - h;
#local Huered = 0.9 - (h/0.5);
#local Hueblue = 1.0 - (coh/0.6);
#if (Huered < 0.0) #local Huered = 0.0; #end
#if (Hueblue < 0.0) #local Hueblue = 0.0; #end
#local Huered=1.0 - (1.0-Huered)*(1.0-Huered);
#local Hueblue=1.0 - (1.0-Hueblue)*(1.0-Hueblue);
#local Huegreen = 1.0 - Huered - Hueblue;
#if (h>0.85)
#local Huered = 4*(h-0.85);
#local ybulge = -4.0*(h-0.1)*(h-0.6);
#if (ybulge<0) #local ybulge=0; #end
#local Huered = Huered+ybulge;// * 0.5; // added * 0.5
#local Huegreen = Huegreen+ybulge;
[bright, color rgb<Huered,Huegreen,Hueblue>]
//#debug
concat("<",str(Huered,0,3),",",str(Huegreen,0,3),",",str(Hueblue,0,3),">\n")
#local elem=elem+1;
#end // while
#end // macro
global_settings {
assumed_gamma 1.0
max_trace_level 10
photons {
spacing 0.01
gather 60, 100
media 25, 1
autostop 0
jitter 1
media on
background{rgb 0.25}
location < 5, 2,-15.0>*7
look_at <-5, 0, 0.0>
angle 25
light_source{
<14, 0, 0>
color <1,1,1>*6
area_light y*0.1, z*0.1, 7, 7
circular
fade_distance 5
fade_power 2
create_spectrum(8,6)
#declare S = 8;
#declare X = 2*(10/6)/S;
#declare Y = sqrt(sqr(X)-sqr(X-.1));
#declare Lens = intersection { // f=5 units
sphere{-(X-.1)*x,X}
sphere{(X-.1)*x,X}
texture{T_Glass1}
interior{ior 1.5 dispersion 1.05}
bounded_by { box {-<.1,Y,Y>,<.1,Y,Y>} }
scale S
#declare C = 4;
object { //condensor
Lens
photons {
target 1.0
refraction on
ignore_photons
translate <C,0,0>
#declare P = -6;
object { // projection lens
Lens
photons {
refraction on
ignore_photons
translate <P,0,0>
#declare L = -<30,8,6>;
#declare H = <15,8,6>;
#declare R = 0.15;
box { L-R*x, <L.x+R,H.y,H.z>
pigment {rgb 1}
union {
// frame
sphere { <L.x,L.y,L.z>, R }
sphere { <L.x,L.y,H.z>, R }
sphere { <L.x,H.y,H.z>, R }
sphere { <L.x,H.y,L.z>, R }
sphere { <H.x,H.y,L.z>, R }
sphere { <H.x,H.y,H.z>, R }
sphere { <H.x,L.y,H.z>, R }
sphere { <H.x,L.y,L.z>, R }
cylinder { <L.x,L.y,L.z>, <L.x,L.y,H.z>, R }
cylinder { <L.x,L.y,L.z>, <L.x,H.y,L.z>, R }
cylinder { <L.x,L.y,L.z>, <H.x,L.y,L.z>, R }
cylinder { <L.x,L.y,H.z>, <L.x,H.y,H.z>, R }
cylinder { <L.x,L.y,H.z>, <H.x,L.y,H.z>, R }
cylinder { <L.x,H.y,L.z>, <L.x,H.y,H.z>, R }
cylinder { <L.x,H.y,L.z>, <H.x,H.y,L.z>, R }
cylinder { <H.x,L.y,L.z>, <H.x,L.y,H.z>, R }
cylinder { <H.x,L.y,L.z>, <H.x,H.y,L.z>, R }
cylinder { <L.x,H.y,H.z>, <H.x,H.y,H.z>, R }
cylinder { <H.x,L.y,H.z>, <H.x,H.y,H.z>, R }
cylinder { <H.x,H.y,L.z>, <H.x,H.y,H.z>, R }
// lens mounts
torus { Y*S, R rotate 90*z translate 4*x }
torus { Y*S, R rotate 90*z translate -6*x }
cylinder { <C,Y*S,0>, <C,H.y,0>, R }
cylinder { <C,-Y*S,0>, <C,L.y,0>, R }
cylinder { <C,H.y,L.z>, <C,H.y,H.z>, R }
cylinder { <C,L.y,L.z>, <C,L.y,H.z>, R }
cylinder { <P,Y*S,0>, <P,H.y,0>, R }
cylinder { <P,-Y*S,0>, <P,L.y,0>, R }
cylinder { <P,H.y,L.z>, <P,H.y,H.z>, R }
cylinder { <P,L.y,L.z>, <P,L.y,H.z>, R }
cylinder { <H.x,L.y,0>, <H.x,H.y,0>, R }
// light mount
difference {
cylinder { <H.x-1,0,0>, <H.x,0,0>, R*5 }
sphere { <H.x-1,0,0>, R }
torus { R*3, R*2 rotate 90*z translate (H.x-1)*x }
pigment { rgb <1,.8,.6>*0.6 }
normal { dents 0.5 scale 0.5}
finish {
ambient 0 diffuse 0.4
specular 0.8 metallic
brilliance 10 roughness 0.01
reflection_min 0.2
reflection_max 0.8
reflect_metallic
conserve_energy
photons { ignore_photons }
box {L, H
pigment { rgbt 1 }
finish { ambient 0 diffuse 0 }
interior{
media{
intervals 1
scattering { 4, rgb 0.04*<.1,.5,1> extinction 2}
samples 50, 50
method 3
aa_threshold .1
aa_level 2
jitter .4
hollow
photons { ignore_photons pass_through}
