POV-Ray : Newsgroups : povray.text.scene-files : Merge isn't working as expected..any ideas why? Server Time
30 Apr 2025 04:08:18 EDT (-0400)
  Merge isn't working as expected..any ideas why? (Message 1 to 1 of 1)
Subject: Merge isn't working as expected..any ideas why?
Date: 22 Jan 2001 15:40:48
Message: <3A6C9A9D.9F493A39@netvision.net.il>
#version 3
#include "glass.inc"
global_settings
  assumed_gamma 1.0
camera
  location  <3.0, 0.0, -13.0>
  direction 1.5*z
  right     4/3*x
  look_at   <1.5, 0.0,  0.0>
sky_sphere
  pigment
    gradient y
    color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
light_source
  0*x // light's position (translated below)
  color red 1.0  green 1.0  blue 1.0  // light's color
  translate <-30, 30, 30>
//Parameters for Textures
#declare WallTexture = texture {pigment {color rgb <0.8,0.45,0.0>}}
#declare FloorTexture = texture {pigment {checker color rgb 1 color rgb
<0,0,1>}}
//Glasses
#declare G_Background = texture {T_Glass2}
#declare G_Foreground = texture {T_Glass1}
#declare G_Blue = texture { T_Vicksbottle_Glass }
//Parameters for the RawMaterial (fungus)
#declare toph = 4
#declare w1 = 12
#declare h1 = 22
#declare w2 = 21
#declare CheckPoint = 11
#declare h2 = (w2 * CheckPoint) / w1
#declare CenterX = 10.5
#declare CenterY = 17
#declare r = 3
#declare r1 = 2.16
//Parameters for the Room
#declare WallThickness = 3
#declare Size = 13
#declare RawMaterial =
union {
  box
    <(w2-w1)/2,0,0>  // one corner position <X1 Y1 Z1>
    <(w2+w1)/2,h1,1>  // other corner position <X2 Y2 Z2>
  intersection {
    cylinder
      0*z, 1*z, 0.43
      scale <w2,h2,1>
      translate <CenterX, CenterY,0>
    box {<-1,CheckPoint,-1>,<w2+1,CenterY,2>}
  intersection
    cylinder
      0*z, 1*z, 0.43
      scale <w2,h2-3.5,1>
    box {<-1,CenterY,-1>,<w2+1,h1,2>}
  intersection
    cylinder
      0*z, 1*z, 0.43
      scale <w2,h2-3.5,1>
  difference
    box {
      <(w2-w1)/2,h1,0>,
      <(w1+w2)/2,h1+toph,1>
    cylinder {-1*z, 2*z, r
      scale <w2/2, toph, 1>
      translate <((w2-w1)/2)-(r1*w2/2),h1+(r1*toph),0>
      translate <((w2+w1)/2)+(r1*w2/2),h1+(r1*toph),0>
#declare Room =
union {
  difference {
    box {
      <-Size,-Size,-2*Size>,
      <Size,Size,Size>
      texture {WallTexture}
    box {
      <-Size+WallThickness,-Size+WallThickness,(-Size+WallThickness)*2>,
      <Size-WallThickness,Size-WallThickness,Size-WallThickness>
  box {
    <-Size+WallThickness,-Size+WallThickness,-Size+WallThickness>,
    <Size-WallThickness,-Size+(2*WallThickness),Size-WallThickness>
    pigment {color rgb 1}
// Misc. that will be applyed on RawMaterial
#declare Depth = 0.5
#declare Gem1a = mesh {
  triangle {<0, 1,0>,< 1,0,0>,<0,0,Depth> texture {G_Blue}}
  triangle {<0,-1,0>,< 1,0,0>,<0,0,Depth> texture {G_Foreground}}
  triangle {<0,-1,0>,<-1,0,0>,<0,0,Depth> texture {G_Blue}}
  triangle {<0, 1,0>,<-1,0,0>,<0,0,Depth> texture {G_Foreground}}
#declare Gem1b = mesh {
  triangle {<0, 1,0>,< 1,0,0>,<0,0,Depth> texture {G_Foreground}}
  triangle {<0,-1,0>,< 1,0,0>,<0,0,Depth> texture {G_Blue}}
  triangle {<0,-1,0>,<-1,0,0>,<0,0,Depth> texture {G_Foreground}}
  triangle {<0, 1,0>,<-1,0,0>,<0,0,Depth> texture {G_Blue}}
#declare BigGem1 = mesh {
  triangle {<0,0,0>,<1,1,0>,<1,1/3,Depth> texture {G_Foreground}}
  triangle {<0,0,0>,<1,1/3,Depth>,<1,-1/3,Depth> texture {G_Blue}}
  triangle {<0,0,0>,<1,-1,0>,<1,-1/3,Depth> texture {G_Foreground}}
  triangle {<1,1,0>,<1,1/3,Depth>,<3,1,0> texture {G_Foreground}}
  triangle {<1,1/3,Depth>,<3,1,0>,<3,1/3,Depth> texture {G_Foreground}}
  triangle {<1,1/3,Depth>,<1,-1/3,Depth>,<3,-1/3,Depth> texture
{G_Blue}}
  triangle {<1,1/3,Depth>,<3,-1/3,Depth>,<3,1/3,Depth> texture {G_Blue}}
  triangle {<1,-1,0>,<1,-1/3,Depth>,<3,-1,0> texture {G_Foreground}}
  triangle {<1,-1/3,Depth>,<3,-1,0>,<3,-1/3,Depth> texture
{G_Foreground}}
  triangle {<4,0,0>,<3,1,0>,<3,1/3,Depth> texture {G_Foreground}}
  triangle {<4,0,0>,<3,1/3,Depth>,<3,-1/3,Depth> texture {G_Blue}}
  triangle {<4,0,0>,<3,-1,0>,<3,-1/3,Depth> texture {G_Foreground}}
// WindowGlass. uses RawMaterial and Miscs.
#declare WindowGlass =
union {
  object {RawMaterial texture {G_Background}}
  object {Gem1a translate <10.5,23,0>}
  object {Gem1b translate < 8.5,21,0>}
  object {Gem1b translate <12.5,21,0>}
  object {Gem1a translate <14.5,19,0>}
  object {Gem1a translate < 6.5,19,0>}
  object {Gem1b translate <16.5,17,0>}
  object {Gem1b translate < 4.5,17,0>}
  object {Gem1a translate <14.5,15,0>}
  object {Gem1a translate < 6.5,15,0>}
  object {Gem1b translate < 8.5,13,0>}
  object {Gem1b translate <12.5,13,0>}
  object {Gem1a translate <10.5,11,0>}
  object {BigGem1 translate <10.5,17,0>}
  object {BigGem1 rotate 180*z translate <10.5,17,0>}
  object {BigGem1 rotate 90*z translate <10.5,17,0>}
  object {BigGem1 rotate -90*z translate <10.5,17,0>}
// Actual Objects
difference {
  object {Room pigment{color rgb <1,1,1>}}
  object {RawMaterial scale <0.5,0.5,WallThickness*2> translate
<-5.25,-6.0,Size-WallThickness-1> texture {WallTexture}}
object {WindowGlass scale <0.5,0.5,0.25> translate <-5.25,-6.0,Size>}
plane
  y, -13.0
   pigment {color rgb <0.7,0.5,0.3>}
