This is the pigment code for the pictures posted in p.b.i.
You can play around with nearly everything in those pigments to get new
interesting results.
// Begin POV-Code
// Christoph Hormann, December 2000 <chr### [at] gmx de>
#declare P_Base_1=
spherical
scallop_wave
pigment_map {
[ 0.00 quilted
color_map {
[ 0.0 color rgb<0.100, 0.000, 0.200> ]
[ 0.3 color rgb<0.000, 0.000, 0.300> ]
[ 0.6 color rgb<0.000, 0.000, 0.000> ]
scale 0.8
[ 0.005 quilted
color_map {
[ 0.0 color rgb<0.200, 0.100, 0.500> ]
[ 1.0 color rgb<0.000, 0.000, 0.100> ]
scale 0.8
[ 0.50 quilted
color_map {
[ 0.0 color rgb<1.000, 0.456, 0.456> ]
scale 0.8
[ 0.60 quilted
color_map {
[ 0.0 color rgb<0.256, 0.230, 0.800> ]
scale 0.8
[ 0.80 quilted
color_map {
[ 0.0 color rgb<1.000, 0.800, 0.200> ]
scale 0.8
scale 5.4
#declare P_Warped_1=
P_Base_1
warp {
black_hole 0, 3
strength 1
falloff 3
warp {
black_hole 0, 4
strength 1
falloff 3
warp {
black_hole 0, 5
strength 1
falloff 3
warp {
displace {
spiral1 6
sine_wave
color_map {
[0.0 color rgb -10 ]
[1.0 color rgb 16 ]
scale 5
type 1
warp {
displace {
spiral1 6
sine_wave
color_map {
[1.0 color rgb 16 ]
scale 5
type 1
#declare P_Warped_2=
P_Base_1
warp {
displace {
spiral1 7
color_map {
[1.0 color rgb 16 ]
scale 5
type 1
warp {
displace {
spiral1 7
color_map {
[0.0 color rgb 16 ]
[1.0 color rgb -10 ]
scale 5
type 1
#declare P_Warped_3=
P_Base_1
warp {
displace {
spiral1 7
triangle_wave
color_map {
[1.0 color rgb 16 ]
rotate 180*x
scale 6
type 1
warp {
displace {
spiral1 7
color_map {
[0.0 color rgb 16 ]
scale 5
type 1
#declare P_Warped_4=
P_Base_1
scale 0.6
warp {
displace {
spiral2 5
color_map {
[0.0 color rgb -1 ]
[1.0 color rgb 16 ]
scale 5
type 1
warp {
displace {
spiral2 5
color_map {
[0.0 color rgb -1 ]
[1.0 color rgb 16 ]
scale 5
type 1
scale 1/0.6
// End POV-Code
Christoph Hormann <chr### [at] gmx de>
